Local Time 02:25 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic, Subroutine Recursion
apam
Posted: 01:06am 22 May 2021
Hi
I'm looking at code someone else has written...
They have things like:
Sub ThisSub
 print "Doing Stuff"
 ThisSub
End Sub
The intention there is so it will go back to the start of the sub after doing stuff. Is that going to cause infinite recursion and exhaust the stack?
I'm new in MMBasic, so not sure if it behaves differently to something like C
Andrew
vegipete
Posted: 01:15am 22 May 2021
On a CMM2, if you run this:
ThisSub 1
end
sub ThisSub n
  Print "Doing Stuff",n
  ThisSub n+1
end sub
you get:
> run
Doing Stuff      1
Doing Stuff      2
Doing Stuff      3
Doing Stuff      4
Doing Stuff      5
[many lines chopped out]
Doing Stuff      99
Doing Stuff      100
Error in line 5: Too many SUB and FUN
Posted: 05:55am 22 May 2021
It's infinite recursion.
Some compilers cope (tail recursion optimising) but that's just hiding the fact.
CaptainBoing
Posted: 05:56am 22 May 2021
Welcome
  apam said  Hi
<snip>
Yes. if you invoke the Sub name that will start a new "instance" of it, stack, local variables and all. Soon run out of resources doing that. Could probably do something clever with a Static variable (on the right platform) to keep track of it all but why break your back?
If the intention is to simply go back to the top of the code inside then structuring with a Do/Loop etc. is probably the best method as they are easy to jump out of and look cute - I doubt the user wants to stay in the Sub forever. You could be a free-thinker and use a GoTo
Edited 2021-05-22 16:02 by CaptainBoing
MustardMan
Posted: 06:04am 22 May 2021
I'm guessing that the sample snippet has some terminating condition inside it which has not been shown, otherwise it does not make programmatic sense.
Recursion is a stack-heavy (and compute heavy) way of performing things, but sometimes it is the best way. One example that springs to mind is filling an odd-shaped polygon by specifying a point inside and then recursively stepping further and further out to an edge, and then dropping back to the previous level, and repeat until filled.
Cheers,
apam
Posted: 09:06am 22 May 2021
Thanks all,
I modified the code to use loops.
I just didn't want to assume it was an error given that I am new to MMBasic.
