Forum Index : Microcontroller and PC projects : CMM2: how to calculate MD5 in MMBasic
Just in case anyone wanted to ... ' Author: Thomas Hugo Williams, 2021 ' For Colour Maximite 2, MMBasic 5.07 ' MD5 algorithm taken from https://en.wikipedia.org/wiki/MD5 Option Explicit On Option Default None Option Base 0 ' Gets the upper-bound that should be used to dimension an array of the given ' capacity, irrespective of OPTION BASE. ' ' e.g. To create a string array that can hold 10 elements: ' Dim my_array$(array.new%(10)) Function array.new%(capacity%) array.new% = capacity% + Mm.Info(Option Base) - 1 End Function ' Calculates the MD5 hash of bytes held in a buffer. ' ' To calculate the MD5 hash of a string s$: ' crypt.md5$(Peek(VarAddr s$) + 1, Len(s$)) ' ' To calculate the MD5 hash of a long string ls%(): ' crypt.md5$(Peek(VarAddr ls%()) + 8, LLen(ls%())) ' ' @param ad% address of the buffer. ' @param size% number of bytes to process. ' @return MD5 hash, 128-bit little-endian value formatted as hex. Function crypt.md5$(ad%, size%) Local chunk%(array.new%(64)) Local chunk_addr% = Peek(VarAddr chunk%()) ' Storage for hash, each element treated as 32-bit unsigned integer. Local h%(array.new%(4)) ' Storage for constants, each element treated as 32-bit unsigned integer. Local r%(array.new%(64)) Local k%(array.new%(64)) Local cur% = 0, num% Do ' Process chunks of 64 bytes / 512 bits at a time. num% = Min(size% - cur%, 64) Memory Set chunk_addr%, 0, 64 Memory Copy ad% + cur%, chunk_addr%, num% If num% < 64 Then ' Append '1' bit to chunk%, the remainder will already be padded with zeros. Poke Byte chunk_addr% + num%, &h80 If num% > 55 Then crypt.md5_chunk(chunk%(), h%(), r%(), k%()) Memory Set chunk_addr%, 0, 64 EndIf ' Last 64-bits of chunk% should be data length in bits as a 64-bit little-endian integer. Poke Integer chunk_addr% + 56, size% * 8 EndIf crypt.md5_chunk(chunk%(), h%(), r%(), k%()) Inc cur%, 64 Loop While num% = 64 Local i% Local h_addr% = Peek(VarAddr h%()) For i% = 0 To 31 ' Note we are only interested in the bottom 4-bytes of each Integer. If (i% Mod 8) < 4 Then Cat crypt.md5$, Hex$(Peek(Byte h_addr% + i%), 2) Next crypt.md5$ = LCase$(crypt.md5$) End Function ' Calculates the MD5 hash of a file. ' ' @param fd% file-descriptor for a file Open For Input. ' @return MD5 hash, 128-bit little-endian value formatted as hex. Function crypt.md5_file$(fd%) Local chunk%(array.new%(64)) Local chunk_addr% = Peek(VarAddr chunk%()) ' Storage for hash, each element treated as 32-bit unsigned integer. Local h%(array.new%(4)) ' Storage for constants, each element treated as 32-bit unsigned integer. Local r%(array.new%(64)) Local k%(array.new%(64)) Local s$, num%, size% Do s$ = Input$(64, #fd%) num% = Len(s$) Inc size%, num% Memory Set chunk_addr%, 0, 64 Memory Copy Peek(VarAddr s$) + 1, chunk_addr%, num% If num% < 64 Then ' Append '1' bit to chunk%, the remainder will already be padded with zeros. Poke Byte chunk_addr% + num%, &h80 If num% > 55 Then crypt.md5_chunk(chunk%(), h%(), r%(), k%()) Memory Set chunk_addr%, 0, 64 EndIf ' Last 64-bits of chunk% should be file length in bits as a 64-bit little-endian integer. Poke Integer chunk_addr% + 56, size% * 8 EndIf crypt.md5_chunk(chunk%(), h%(), r%(), k%()) Loop While num% = 64 ' Format the hash as a string. Local i% Local h_addr% = Peek(VarAddr h%()) For i% = 0 To 31 ' Note we are only interested in the bottom 4-bytes of each Integer. If (i% Mod 8) < 4 Then Cat crypt.md5_file$, Hex$(Peek(Byte h_addr% + i%), 2) Next crypt.md5_file$ = LCase$(crypt.md5_file$) End Function ' @param chunk%() 512-bit chunk to process (64 elements). ' @param h%() hash-values (4 elements). ' @param r%() per-round shift amounts (64 elements). ' @param k%() binary integer part of the sines of integers (Radians) as constants (64 elements). Sub crypt.md5_chunk(chunk%(), h%(), r%(), k%()) Const BASE% = Mm.Info(Option Base) ' Note that all variables should be treated as unsigned 32-bit integers ' and wrap modulo 2^32 when calculating. ' Initialise hash and constants if this is the first call. If r%(BASE%) = 0 Then Local data_addr% = Peek(CFunAddr crypt.md5_data) Memory Copy data_addr%, Peek(VarAddr h%()), 64 Memory Copy data_addr% + 32, Peek(VarAddr r%()), 512 Memory Copy data_addr% + 544, Peek(VarAddr k%()), 512 EndIf ' Split chunk into 16 x 32-bit words. Local chunk_addr% = Peek(VarAddr chunk%()) Local i%, w%(array.new%(16)) For i% = 0 To 15 w%(i% + BASE%) = Peek(Word chunk_addr% + 4 * i%) Next ' Main loop. Local a% = h%(base%), b% = h%(base% + 1), c% = h%(base% + 2), d% = h%(base% + 3), f%, g%, tmp% For i% = 0 To 63 Select Case i% Case 0 To 15 f% = d% Xor (b% And (c% Xor d%)) g% = i% Case 16 To 31 f% = c% Xor (d% And (b% Xor c%)) g% = (5 * i% + 1) Mod 16 Case 32 To 47 f% = b% Xor c% Xor d% g% = (3 * i% + 5) Mod 16 Case Else: f% = c% Xor (b% Or (d% Xor &hFFFFFFFF)) g% = (7 * i%) Mod 16 End Select tmp% = d% d% = c% c% = b% b% = (a% + f%) And &hFFFFFFFF b% = (b% + k%(i% + base%)) And &hFFFFFFFF b% = (b% + w%(g% + base%)) And &hFFFFFFFF b% = (b% << r%(i% + base%)) Or (b% >> (32 - r%(i% + base%))) b% = (b% + c%) And &hFFFFFFFF a% = tmp% Next ' Add this chunk's hash to the result. h%(base%) = (h%(base%) + a%) And &hFFFFFFFF h%(base% + 1) = (h%(base% + 1) + b%) And &hFFFFFFFF h%(base% + 2) = (h%(base% + 2) + c%) And &hFFFFFFFF h%(base% + 3) = (h%(base% + 3) + d%) And &hFFFFFFFF End Sub ' Not a real CSUB, this provides data for initialising constant arrays in crypt.md5(). CSub crypt.md5_data() 00000000 ' 4 x 8 byte values to initialise hash 'h' 67452301 00000000 EFCDAB89 00000000 98BADCFE 00000000 10325476 00000000 ' 64 x 8 byte values for 'r' 00000007 00000000 0000000C 00000000 00000011 00000000 00000016 00000000 00000007 00000000 0000000C 00000000 00000011 00000000 00000016 00000000 00000007 00000000 0000000C 00000000 00000011 00000000 00000016 00000000 00000007 00000000 0000000C 00000000 00000011 00000000 00000016 00000000 00000005 00000000 00000009 00000000 0000000E 00000000 00000014 00000000 00000005 00000000 00000009 00000000 0000000E 00000000 00000014 00000000 00000005 00000000 00000009 00000000 0000000E 00000000 00000014 00000000 00000005 00000000 00000009 00000000 0000000E 00000000 00000014 00000000 00000004 00000000 0000000B 00000000 00000010 00000000 00000017 00000000 00000004 00000000 0000000B 00000000 00000010 00000000 00000017 00000000 00000004 00000000 0000000B 00000000 00000010 00000000 00000017 00000000 00000004 00000000 0000000B 00000000 00000010 00000000 00000017 00000000 00000006 00000000 0000000A 00000000 0000000F 00000000 00000015 00000000 00000006 00000000 0000000A 00000000 0000000F 00000000 00000015 00000000 00000006 00000000 0000000A 00000000 0000000F 00000000 00000015 00000000 00000006 00000000 0000000A 00000000 0000000F 00000000 00000015 00000000 ' 64 x 8 byte values for 'k' D76AA478 00000000 E8C7B756 00000000 242070DB 00000000 C1BDCEEE 00000000 F57C0FAF 00000000 4787C62A 00000000 A8304613 00000000 FD469501 00000000 698098D8 00000000 8B44F7AF 00000000 FFFF5BB1 00000000 895CD7BE 00000000 6B901122 00000000 FD987193 00000000 A679438E 00000000 49B40821 00000000 F61E2562 00000000 C040B340 00000000 265E5A51 00000000 E9B6C7AA 00000000 D62F105D 00000000 02441453 00000000 D8A1E681 00000000 E7D3FBC8 00000000 21E1CDE6 00000000 C33707D6 00000000 F4D50D87 00000000 455A14ED 00000000 A9E3E905 00000000 FCEFA3F8 00000000 676F02D9 00000000 8D2A4C8A 00000000 FFFA3942 00000000 8771F681 00000000 6D9D6122 00000000 FDE5380C 00000000 A4BEEA44 00000000 4BDECFA9 00000000 F6BB4B60 00000000 BEBFBC70 00000000 289B7EC6 00000000 EAA127FA 00000000 D4EF3085 00000000 04881D05 00000000 D9D4D039 00000000 E6DB99E5 00000000 1FA27CF8 00000000 C4AC5665 00000000 F4292244 00000000 432AFF97 00000000 AB9423A7 00000000 FC93A039 00000000 655B59C3 00000000 8F0CCC92 00000000 FFEFF47D 00000000 85845DD1 00000000 6FA87E4F 00000000 FE2CE6E0 00000000 A3014314 00000000 4E0811A1 00000000 F7537E82 00000000 BD3AF235 00000000 2AD7D2BB 00000000 EB86D391 00000000 End CSub ' Returns a copy of s$ with leading and trailing spaces removed. Function str.trim$(s$) Local st%, en% For st% = 1 To Len(s$) If Peek(Var s$, st%) <> 32 Then Exit For Next For en% = Len(s$) To 1 Step -1 If Peek(Var s$, en%) <> 32 Then Exit For Next If en% >= st% Then str.trim$ = Mid$(s$, st%, en% - st% + 1) End Function ' If s$ both begins and ends with " then returns a copy of s$ with those characters removed, ' otherwise returns an unmodified copy of s$. Function str.unquote$(s$) If Peek(Var s$, 1) = 34 Then If Peek(var s$, Len(s$)) = 34 Then str.unquote$ = Mid$(s$, 2, Len(s$) - 2) Exit Function EndIf EndIf str.unquote$ = s$ End Function Dim filename$ = str.unquote$(str.trim$(Mm.CmdLine$)) If filename$ = "" Then Error "No file specified" Open filename$ For Input As #1 Print crypt.md5_file$(1) Close #1 Example run: > *md5sum.bas md5sum.bas e5dd1c4319a62a47f6a6097ae3f68a70 Zip file: md5sum.zip Best wishes, Tom Edited 2021-05-23 23:34 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Did you mean to leave the copyright in and no other wording? John |
Ugh. I believe I still have the copyright on the implementation but since I've published it on TBS it can be used according to whatever Creative Commons license material on TBS is covered. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
History edited using nefarious tactics to remove my (c) message ![]() MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1752 |
But not in the zip file! Thanks a lot for the contribution! Regards Michael causality ≠ correlation ≠ coincidence |
I'll take more care when I publish my XXTEA encryption code of which this was just part. In the meantime all my tool lunacy can be found here https://github.com/thwill1000/sptools/tree/develop-r1b3 along with the relevant MIT LICENSE file. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
Using CSUB as a data container is a cool hack. Are CSUBs guaranteed 64-bit aligned? i.e. would it be possible to directly peek at an array of integers or floats in there, without a memory copy? Epsilon CMM2 projects |
