Forum Index : Microcontroller and PC projects : CMM2: Calculate factorial
bar1010
Posted: 09:55pm 25 May 2021
Calculate factorial results using arbitrary precision math (bignum math).
The results contain more digits than usual with an integer datatype.
'Arbitray precision math: calculating factorials
'Idea is to perform calculations with more precision than is normal with integer and float datatypes
option base 0
const limit = 65536 'maximum number of digits
const tbase = 10
dim string  tdigit$(9) = ("0", "1", "2", "3", "4", "5", "6", "7", "8", "9")
dim integer digit(limit)  'the big number
dim integer carry, d      'assistants during multiplication
dim integer last, i       'indices to the big number's digits
const fl = 47             'target factorial to solve
for i = 1 to limit
 digit(i) = 0
next i
digit(1) = 1  'the big number starts with 1
last = 1      'it's highest-order digit is number 1
for n = 1 to fl
 carry = 0
 for i = 1 to last  'step along every digit
   d = digit(i) * n + carry
   digit(i) = d mod tbase  'the low-order digit of the result
   carry = d \ tbase  'Note: MUST use \ for integer division, not /, the carry to the next digit
 next i
 do while carry > 0 'store the carry in the big number
   if last >= limit then print "Overflow!")
   inc last
   digit(last) = carry mod tbase
   carry = carry \ tbase
 loop
 for i = last to 1 step -1
   print tdigit$(digit(i));
 next i
 print " ="; n; "!"
next n
do : loop
new calculate factorial.zip
Posted: 01:24am 26 May 2021
It's about 30 times faster than the code I wrote for the original maximite in 2012
Back then we only have 32 bit floats, no integers and many commands like INC not available.
https://www.thebackshed.com/forum/ViewTopic.php?TID=4653&PID=46596#46596#46590
Edited 2021-05-26 11:29 by TassyJim
bar1010
Posted: 03:29am 26 May 2021
  TassyJim said  It's about 30 times faster than the code I wrote for the original maximite in 2012
Thanks for sharing that link.
I will see if can use that code for calculating pi and e using bignum math
showing the values with each iteration.
William Leue
Posted: 04:14pm 26 May 2021
Nice! Now if we could convince Geoff and Peter to include bignums as a base type in MMBasic..... Nah!
-Bill
toml_12953
Posted: 05:19pm 26 May 2021
Is the right parenthesis an error?
Posted: 09:23am 27 May 2021
Looks like it is.
vegipete
Posted: 06:02pm 27 May 2021
Interesting fun.
Here's my quickie take on many digit integer math.
Setup to calculate Fibonacci numbers up to 102 digits, although changing 'bigsize' would allow many more digits.
(Press a key for each new number.)
Main difference from bar1010 is I'm storing 6 digits per array element.
This ought to be changed to 8 digits for better storage - 8 digits to ensure no overflow if multiplication were to be implemented.
Plus I was lazy and didn't code multiplication, or check for overflow.
' Many Digit Math for Integers  - quick test by vegipete
' Digits are stored in arrays
' The following uses base 1,000,000: this way, 6 decimal digits are stored in each element
' to do:
'   multiplication/division
'   decide how to represent negative numbers
bigsize = 16    ' (bigsize + 1) * 6 = number of digits
dim a(bigsize)
dim b(bigsize)
dim c(bigsize)
print "Fibonacci Numbers - each number is the sum of the previous 2. Fib0 = 0, Fib1 = 1."
a(0) = 0
b(0) = 1
do
 PrintLong c()
 AddLong a(),b(),c()
 CopyLong b(),a()
 CopyLong c(),b()
 do : loop until inkey$ <> ""
loop
sub AddLong x(),y(),z()
 local i,tmp,c=0
 for i = 0 to bigsize
   tmp = c + x(i) + y(i)
   z(i) = tmp MOD 1000000
   c = tmp \ 1000000
 next i
end sub
sub MultLong x(),y(),z()
 ' exercise left to the reader
end sub
sub CopyLong x(),y()
 local i
   y(i) = x(i)
 next i
end sub
sub PrintLong x()
 local i,lead=0
 for i = bigsize to 0 step -1
   if x(i) or lead then
     print right$(string$(lead,"0")+str$(x(i)),6);
     lead = 6
   endif
 next i
 if not lead then print "0";
 print
end sub
Paul_L
Posted: 07:31pm 27 May 2021
If you take this a little bit further you wind up rewriting the BCD math routines that Wayne Ratliff incorporated in Vulcan > cBase > Clipper > FoxBase etc where numbers are treated as very long strings of characters and you use look up tables to multiply and manually carry remainders just like you would on paper.
It would seem to be MUCH slower than doing it in binary but it really isn't because you don't have to convert back and forth between binary for calculation and decimal for input and display. COBOL, in its earliest incarnations, had BCD routines which it could call.
Paul in NY
bar1010
Posted: 10:46pm 27 May 2021
  vegipete said  Interesting fun.
' to do:
dim a(bigsize)
dim b(bigsize)
dim c(bigsize)
a(0) = 0
b(0) = 1
do
 PrintLong c()
 AddLong a(),b(),c()
 CopyLong b(),a()
 CopyLong c(),b()
loop
 local i,tmp,c=0
   c = tmp \ 1000000
 next i
end sub
end sub
 local i
   y(i) = x(i)
 next i
end sub
sub PrintLong x()
 local i,lead=0
     lead = 6
   endif
 next i
 print
end sub
Nice.  Has anyone wrote a bignum program capable of adding, subtracting, multiplying, and dividing floats?
