Forum Index : Microcontroller and PC projects : CMM2: V5.07.00RC1 - Getting closer :-)
| Page 1 of 4 |
V5.07.00RC1 now available - getting closer http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip This update will erase all previous options and force re-initialisation Minor changes: Overclocking to 504MHz is now enabled with OPTION OVERCLOCK ON and disabled with OPTION OVERCLOCK OFF In addition you can also force the CMM2 to run at 400MHZ irrespective of which chip is installed using OPTION BASELINE ON This is disabled with OPTION BASELINE OFF Option overclock and option baseline are mutually exclusive and setting one will cancel the other as required |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 653 |
Fantastic! Thanks once again! |
| Plasmamac Guru Joined: 31/01/2019 Location: GermanyPosts: 620 |
Wow , thanks a lot Matherp & Geoff. Plasma |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4398 |
Not working as intended on my 400 MHz: > 504MHz Colour Maximite 2 MMBasic Version 5.07.00RC1 Copyright 2011-2021 Geoff Graham Copyright 2016-2021 Peter Mather > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION BASELINE ON OPTION OVERCLOCK ON OPTION RAM ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option baseline off > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION BASELINE ON OPTION OVERCLOCK ON OPTION RAM ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option overclock off > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION BASELINE ON OPTION OVERCLOCK ON OPTION RAM ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> Looks like the OFF's are non-functional and the mutual-exclusiveness is non-existent ![]() Sorry, Tom Edited 2021-06-05 03:41 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Also OPTION RESET is not consistently clearing all options: > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK OPTION RAM ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /magic/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option reset > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK OPTION F12 chdir "/sptools/src"<crlf> MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Please download and try again - I think I posted the wrong version |
Initially that seemed to be doing better, until: > 504MHz Colour Maximite 2 MMBasic Version 5.07.00RC1 Copyright 2011-2021 Geoff Graham Copyright 2016-2021 Peter Mather > option reset > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION OVERCLOCK ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option overclock off > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION OVERCLOCK ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option baseline on > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION OVERCLOCK ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option baseline off > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION OVERCLOCK ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> > option reset > option list CURRENT VGA mode 800x600 RGB332 CURRENT DISPLAY 50,100 OPTION USBKEYBOARD UK, 1 OPTION OVERCLOCK ON OPTION KEYBOARD REPEAT 200,50 OPTION SEARCH PATH /bin/ OPTION F11 chdir "/zmim/src"<crlf> OPTION F12 chdir "/sptools/src"<crlf> I suppose it's possible caching means I still haven't got the correct version installed, but I don't think so, do you have an MD5 ? I'll try and find time to play more later. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Something very wrong - Option Reset isn't clearing the options I thought I'd found a way of reading the options before setting the clocks but something isn't right - don't waste any time on it |
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 514 |
Matherp should my hardware switch I use during boot to overclock still work? They call me Shai-Hulud (The maker) |
Try again - bloody caching http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
@thwill Are you actually running a 400Mhz chip at 504Mhz? Water cooling? I ask, since mine is also 400Mhz. I normally would never have tried that... 480 maybe, but 504.... ![]() Edit: tried it, it works. Gonna run some reliability tests tomorrow... Edited 2021-06-05 07:01 by Volhout PicomiteVGA PETSCII ROBOTS |
Hi @Volhout, I believe 504 MHz is the only overclocking game in town, or at least the only one that @matherp has sanctioned for both the 400 & 480 MHz CMM2 and he hasn't suggested any additional cooling. However I'm only doing this for the purposes of testing the Release Candidate, after that I will return to 400 MHz, more than fast enough, or if it isn't then I can switch to C and get a > 10x performance boost. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| yock1960 Senior Member Joined: 18/08/2020 Location: United StatesPosts: 167 |
I've been running at 504 for some time now...months...no issues...yet. Warm time is here though...so...we'll see. Steve |
No: This was always a temporary solution and is generally a bad idea because it limits pin use for connected devices. As there has also been a requirement to run 480MHz devices at 400MHz for compatibility testing I needed to bite the bullet and try and find a mechanism that would allow options to be read before the main clocks are set up. This version should do that if I have finally ironed out the wrinkles - Tom? |
Sorry Peter, I should have some time after lunch to test. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Hi Peter, - Overclock/Baseline/Reset options all seem to be working with latest RC1 download. - All my unit-tests are working with RC1 (except known issue with Static variables). - Z-MIM smoke-test passed with RC1. - Smoke-tests of Bill and my new Scott Adams Adventure Interpreter [Coming Soon] passed with RC1. - Smoke-tests of all programs on The Welcome Tape passed with RC1 - though I did find a couple of what I believe were pre-existing issues with Mandelbrot Explorer (https://github.com/thwill1000/cmm2-welcome/issues). I am not proposing to do anything about these, but if @Sasquatch is still active on TBS or someone else wants to take a look then I am happy to update The Welcome Tape with their efforts. So, looks good to me, thanks again Peter. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Tom Thanks for your testing - it is really very much appreciated |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1772 |
Hi Peter, the new way to set overclocking by software is a great invention! Even better my good old GAME OF LIFE still works flawlessly (6ms/generation for demo1). An observation: in very early versions of the CMM2 firmware, I noticed a huge difference in execution time between RAM and ROM mode (ca. 10%). This difference has disappeared for some time. Is there still a difference between RAM and ROM mode at all? MM.INFO(CPUSPEED) should be updated in the manual. Thanks a lot! Best regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
I'm very happy with what we've got, but I wonder if there is any merit in these new options being set via: OPTION CPUSPEED 400|480|504|BASELINE|DEFAULT|OVERCLOCK Where: - BASELINE is equivalent to 400 - OVERCLOCK is equivalent to 504 - DEFAULT is equivalent to 400 or 480 depending on the processor - 480 is not valid on the 400 processor And then replacing or supplementing MM.INFO(CPUSPEED) with MM.INFO(OPTION CPUSPEED) which would return the numeric value rather than the string equivalent. If nothing else this would leave more maneuvering room should other speed options become available in the future. Best wishes, Tom Edited 2021-06-06 08:44 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
V5.07.00RC2 http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip improves the timing of the pause command |
| Page 1 of 4 |
