Local Time 11:34 02 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.07.00RC1 - Getting closer :-)
     Page 3 of 4
KeepIS
Posted: 01:08am 16 Jun 2021
  Volhout said
Are the options lost on every power cycle, or just during firmware update.?
Apology for missing your post, No I expect the options to be lost when reprogramming, this is with a power cycle, even a fast off - on, and as noted above, reverting back to earlier FM fixed options being lost.
NANO Inverter: Full download - Only Hex Ver 8.1Ks
Posted: 05:59am 16 Jun 2021
Hi Keepis,
Version RC1 holds the options correctly. I am running 504Mhz, so I have one option more than you in option list. Maybe it is in rc2 only.
KeepIS
Posted: 06:19am 16 Jun 2021
That's correct, as noted, I changed back to previous version and of course all options are fine.
Fortunately I have my own Win program that detects the platform and automatically sets all options with one click, sends files with a single click, and launches any returns from any programmer SW I need, so swapping Firmware, interrogating any option or pin status and testing code is painless, fast and simple.
Posted: 07:59am 16 Jun 2021
I can't repeat the fault here using my options and RC2.
I tested on two different machines and they both hold options correctly.
KeepIS
Posted: 08:27am 16 Jun 2021
Well, in that case I'll try downloading the ZIP again and having a 3rd go at seeing if it holds options, nothing changed but the firmware, and each time it fails to hold Options on the last Test version from peter?
I'll be back, hopefully with good news?
KeepIS
Posted: 08:38am 16 Jun 2021
Downloaded again and installed - it holds the options, unbelievable, the dam Bin file must be damaged, I really don't know how this can be as there was no error in unzip and to only affect the Options on power cycle???.
I'll compare the two and install the first download as soon as I get a chance and see what's going on.
Jim, thanks again for confirming that the version worked for you, BIG help.
KeepIS
Posted: 08:59am 16 Jun 2021
I've deleted this post as I believe I've suffered from a caching issue on the first day I downloaded the file (twice).
Edited 2021-06-16 19:22 by KeepIS
KeepIS
Posted: 11:42am 16 Jun 2021
I was wrong again, when I removed the backup battery after flashing both the RC2 downloads, then reload the options, the CMM2 looses the options over a power cycle.
When I use CMM2V5.07.00b24 everything is perfect. I can remove and install battery to reset all options, enter initialisation prompts, set options and they stick with a power cycle.
Go back to RC2 and they loose all options again over a power cycle, if I have a faulty CMM2 then it's a strange fault that ONLY follows RC2 to the death. (new battery)
Posted: 12:09pm 16 Jun 2021
@keepis
Could you check with a multimeter is the connection between the battery and the actual pin on the STM32 is good. Since current consumption should be low, a bad connection may be able to hold the data unreliable. Measure the actual pin, not the pad.
Posted: 12:29pm 16 Jun 2021
There is a problem. It was caused by trying to allow the overclock to be an option. I'll look at it ASAP
Posted: 06:08pm 16 Jun 2021
CMM2V5.07.00RC3 posted
This should solve the "options-getting-lost" issue.
Please erase the entire chip before programming. You should then get the initialisation dialogue.
Other changes form Geoff's latest release:
Bug fix for STATIC variables as reported by thwill
Much improved performance for reading DATA statements
Posted: 06:26pm 16 Jun 2021
Sorry, something different now funny with options:
> option list
CURRENT VGA mode 800x600 RGB332
OPTION USBKEYBOARD UK
> option usbkeyboard uk,1
> option ram
Initial setup - all parameters can be changed later
Keyboard type: 1=UK, 2=US, 3=DE , 4=FR, 5=ES , 6=BE ? 1
Enter time (24hr clock) HH:MM:SS ? 19:26:00
400MHz Colour Maximite 2/06/21
MMBasic Version 5.07.00RC3
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> option list
CURRENT DISPLAY 50,100
> option ram
Enter time (24hr clock) HH:MM:SS ? 19:27:00
> option list
Edited 2021-06-17 04:28 by thwill
Posted: 06:30pm 16 Jun 2021
... and DATA now appears to be borked:
> list "data_bug.bas"
Print "Hello"
Read h%
Print h%
Data &h1
> run "data_bug.bas"
Hello
Error in line 5: Type prefix
Can I interest you in the wonders of automated unit-testing yet ?
Edit: STATIC does appear to be fixed as far as my test coverage goes though.
Edited 2021-06-17 04:36 by thwill
KeepIS
Posted: 10:43pm 16 Jun 2021
  Volhout said  @keepis
If you look back a few posts you will see that I have a DSO on the Vbat pin on the CPU, it is perfect, and as now been revealed, there was a problem with options, I wonder if everyone trying the RC2 firmware was indeed removing the battery to reset the CMM2 to the start up initialisation screen, IE asking for keyboard and time/date?
KeepIS
Posted: 10:52pm 16 Jun 2021
  thwill said  Sorry, something different now funny with options:
Yes, this appears to be the problem I was having, and it's still there on the FW update.
Edited 2021-06-17 10:43 by KeepIS
Posted: 09:22am 17 Jun 2021
CMM2V5.07.00RC4 posted
Fixes option ram and data read issue (would have worked with &H1 but not &h1)
String for F11 and F12 increased to 64 characters
String for search path increased NB: maximum total length of full filename including path is 128 characters.
NB: Options are now stored in flash memory so will not be lost when battery is removed.
Fixes caching bugs in VAR SAVE/RESTORE
Edited 2021-06-17 19:22 by matherp
KeepIS
Posted: 09:40am 17 Jun 2021
Everything working great now
Posted: 10:15am 17 Jun 2021
@Peter,
Have you been able to discover what is wrong with the FFT ? This issue is brought up in the pi-pico thread but is the same for CMM2.
Posted: 10:28am 17 Jun 2021
  Quote  Have you been able to discover what is wrong with the FFT ?
Next on the list.
Please provide a text file with 1024 sample values to use as input (1 per line)  together with what you think are the correct FFT real and imaginary values
Posted: 10:43am 17 Jun 2021
  matherp said  CMM2V5.07.00RC4 posted ...
Options seem to be fixed, however I'm not sure if it significant but on first restart after installing the new firmware my 400 MHz box reported itself as 504 MHz, however once the time & date are set it corrected itself.
My unit-tests, Z-MIM and SAAINT all work fine with this version with default, BASELINE and OVERCLOCK.
Will try to smoke-test "The Welcome Tape" as the dayjob permits this afternoon, probably only with OVERCLOCK option since I assume that is the most likely to be troublesome.
  Quote  NB: Options are now stored in flash memory so will not be lost when battery is removed.
I thought you'd tried that early in development and dismissed it? Does this mean there is potentially more OPTION space (I have nothing in mind at the moment) ?
     Page 3 of 4
© JAQ Software 2025
