Forum Index : Microcontroller and PC projects : CMM2: Line continuation character, SWAP
| bar1010 Senior Member Joined: 10/08/2020 Location: United StatesPosts: 197 |
FreeBASIC uses the underscore character for line continuation. Do we have something similar to use in the editor? If not, could we have this functionality added? Also I have seen a SWAP command in QuickBASIC which swaps the values of two variables. Could we have this functionality added? |
I will save Peter some time: Line continuation: see http://www.thebackshed.com/Forum/ViewTopic.php?TID=12819 SWAP: probably not as the 128 tokens available for MMBasic commands has been reached on the CMM2 - it's an architectural limitation. Best wishes, Tom Edited 2021-06-08 05:31 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Note that because parameters are pass by reference you could write SUBroutines to provide your own SWAP, you'd need one per type and unfortunately you'd have to pay a significant performance penalty over an inbuilt command. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
I think, that is correct. But it's easy to make your own: For example, you might define a subroutine to swap two values, as follows: (CMM2 manual p27) SUB Swap a, b LOCAL t t = a a = b b = t END SUB ... or write a short CSUB Regards Michael causality ≠ correlation ≠ coincidence |
it is likely you will only ever use SWAP in one or two places in any given program. The overhead of a SUB makes for a very slow SWAP. If you are doing it in tight loops (e.g. in a sort function), better to do it inline for big increase in speed. All things speed-wise are relative of course |
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 582 |
There is a nice old challenge with the swap function. How can we do it without creating a third variable? ![]() Edited 2021-06-08 09:19 by LeoNicolas |
Does it work with floating point, not to mention strings... LOL John |
Now there's a thought ... Swap the variable pointers, not the variables. Edited 2021-06-08 16:40 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
