Forum Index : Microcontroller and PC projects : CMM2: Bug/unexpected behaviour wien Sub called by SetTick
| Page 1 of 2 |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4398 |
Possibly this is "by design", but > 480MHz Colour Maximite 2 G2 MMBasic Version 5.07.00 Copyright 2011-2021 Geoff Graham Copyright 2016-2021 Peter Mather > list "bug.bas" Option Explicit SetTick 1000, foo Do : Loop Sub foo(a%) Print a% End Sub > run "bug.bas" Error in line 7: A is not declared I would have expected parameter a% to have the value 0 as it would if "foo" were called without any arguments from elsewhere in the code. This isn't a made up case, I was hoping to reuse the "foo" function with non-zero arguments elsewhere. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4380 |
What an interesting test case! John |
Despite the thread title "... behaviour wein Sub ..." this is not a question about Vienna, I would have capitalised it if that were the case ![]() Edited 2021-07-10 04:19 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
It beat the 700 lines of actual code - not all within the SetTick/interrupt I hasten to add.Best wishes, Tom Edited 2021-07-10 04:16 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Thanks for the report. That does not seem correct. I cannot check it at this time as I am away for most of the month but when I get back I will look into it and report back. In the meantime could you try it without the brackets in the definition, ie: Sub foo a% It should not make any difference. Geoff Edited 2021-07-10 05:39 by Geoffg Geoff Graham - http://geoffg.net |
It didn't make a difference, the same error is reported. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6606 |
A workaround so Geoff can continue his holiday in peace: Jim VK7JH MMedit |
So you want an interrupt to call a subroutine that is also called by the main code. What do you think will happen if the program flow is in this routine when the timer interrupt triggers? Visit Vegipete's *Mite Library for cool programs. |
I do it often. Use SETTICK to set up the main calls and then use a direct call to run the SUB the first time instead of waiting 10 seconds (or more) for something to happen. Jim VK7JH MMedit |
Thanks Jim, I was already using that workaround before you posted. @Vegipete my understanding is that these interrupts can only happen between statements so in theory it should be possible to concoct some sort of lock to prevent the interrupt running the body of foo() if the main thread of control is already in there. I say "in theory" because I have spent my evening trying to do just that and don't think I succeeded. I will need to experiment some more on Sunday. Best wishes, Tom Edited 2021-07-10 09:02 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3381 |
"I do it often. Use SETTICK to set up the main calls and then use a direct call to run the SUB the first time instead of waiting 10 seconds (or more) for something to happen." Ditto. To get data from sensors etc. in the setup before the main loop. |
Sounds to me that you have ensured that no clash will occur because you do not access the routines once the ISR is running. Here's a silly contrived example that shows the occasional clash (at least on my 400MHz CMM2.) > list dim s,a(50) settick 499, foo do foo if s mod 50 <> 0 then print s pause 1 loop sub foo local i s = 0 for i = 1 to 50 a(i) = a(i) + 1 s = s + a(i) next i end sub No surprise really. Seems like some sort of 2 stage flag could solve this. Foo must not run from the ISR if it is currently running from the main routine. Instead, the ISR request needs to be held until after foo returns to the main routine. Alas, I can't think of a suitable interlock this evening... maybe I'll dream a solution. Visit Vegipete's *Mite Library for cool programs. |
The recommended way of using interrupts is to keep them short. Just set a flag and let the main program loop handle the work. That way, having the flag set by two different triggers will not cause any grief. If the timing is slow, a long sub is OK but for rapid timing, having the main loop get the sequence right is better. Jim VK7JH MMedit |
I'm using the "interrupt" to flash a cursor but need to handle the main "thread" moving the cursor after it has been drawn but before it has been restored. Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9136 |
How about just toggling a "cursor lit" flag in the ISR, Tom? Don't do anything else - you really need to handle the cursor in the main body of the program anyway. You can temporarily disable the ISR & force the cursor on or off while you do something specific then re-enable the ISR. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Mick, I don't see any particular reason why I can't handle rendering of the cursor in the ISR, otherwise my approach is similar to that you suggest. For me this has now become less about the final result, there are other ways to achieve that, and more about learning how to protect against race conditions between the main "thread" and ISRs, which basically means determining what can be used atomically to implement a guard. It is also possible I have already implemented the guard correctly, but missed somewhere in my code that it needed to be checked/cleared. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
So good it got posted twice? :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Generally you should not call interrupt subs from the main code. It is OK if you are sure that the interrupt will not fire while you are doing that - like calling a SETTICK sub straight after starting the SETTICK. If you do call an interrupt sub from the main code and the interrupt fires strange things can happen. This includes corrupted STATICs, LOCALs, FOR loops, DO loops, etc as well as turning your hair prematurely grey. On re reading the CMM2 manual I discovered that this warning is missing from it (it is in the Micromite manuals). I will fix this omission on the next release. Geoff Geoff Graham - http://geoffg.net |
I was using a STATIC to implement a lock under the misapprehension that they were implemented as strangely scoped globals. Geoff could you clarify what operations can be considered to be atomic and what can be interrupted by an ISR ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Page 1 of 2 |
