Local Time 20:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Possible bug in pixel() function?
William Leue
Posted: 09:45pm 14 Jul 2021
When drawing color using 32-bit color on a Gen 2 unit and reading back the pixels using x = pixel(), I am surprised to find that there are only a few bits set at the least significant bits and all zeros above that.
This does not happen in 8, 12, and 16-bit color modes: pixel() works fine for all the bit depths except 32.
I am running 5.07.00b26 firmware. Is this a known problem fixed in a later beta? Or am I just nuts?
Thanks!
-Bill
Posted: 11:13pm 14 Jul 2021
I don't se any problems.
mode 1,8
pixel 100,100, rgb(white)
print hex$(pixel(100,100),8)
pixel 100,101, rgb(green)
print hex$(pixel(100,101),8)
do:loop until inkey$ <>""
mode 1,32
00FFFFFF
0000FF00
0FFFFFFF
0F00FF00
Can you post some code that demonstrates the issue?
William Leue
Posted: 09:43am 15 Jul 2021
Nope, when I changed from my large program to a simple one to demonstrate the "bug" I could not reproduce the problem. My bad.
-Bill
