Forum Index : Microcontroller and PC projects : High Accuracy RTC? CMM2
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 509 |
Hi all. I got my GEN2 unit from https://micromite.org/ and it is very nicely made. He has included the 2 resistors for the PS2 mouse function and it seems he has populated the High Accuracy RTC but when I issue the Option DS3231 command it returns "Invalid Command" Not sure what is happening there. If the chip is not functional is that why that command does not work? Otherwise, did I miss some change on that function or any issues with it? Thanks PS. I am on Beta 4 Edited 2021-08-05 05:36 by mclout999 They call me Shai-Hulud (The maker) |
See the post "OPTION Errors". Someone has what seems to be a similar problem, fixed by making OPTION DS3231 the last option set up. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
OPTION DS3231 ON You need the ON It will cause a reboot Jim VK7JH MMedit |
Yes after OPTION RESET and the ON it works just fine. I have got to reread the new user guide all the way through again. I Just put it on my kindle. It is very nice of Phil to include the chip. Thanks. Edited 2021-08-05 12:24 by mclout999 They call me Shai-Hulud (The maker) |
