Forum Index : Microcontroller and PC projects : CMM2 Firmware 5.05.05: XMODEM only over serial console
| Vampire05 Regular Member Joined: 06/12/2020 Location: GermanyPosts: 88 |
Hi Guys, my CMM2 has the Firmware 5.05.05 and i try to send and receive files over XMODEM protocol. Does the XMODEM SEND / RECEIVE commands only work over the USB (Serial Console) and NOT over COM1 on the 40 Pin IDE connector? If yes, has that changed in newer firmware? |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11452 |
You need at least 5.6 to do this so I suggest you update to 5.7. See the latest manual for the syntax Edited 2021-08-09 03:57 by matherp |
Ok, thank you very much . I will update today and retry again |
Ok it works now over the COM1 Port. Thank you. Is the CMM2 XMODEM SEND implementation able to work with CRC instead of Checksum? In my case, the receiver sends an "C" instead of <NAK>. Is the CMM2 able to handle that correctly? |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6535 |
The Maximites are strictly the original XMODEM protocol only. No CRC and no 1k blocks. Jim VK7JH MMedit |
Thank you very much TassyJim Now it is clear to me why it does not work for me! |
