Local Time 18:21 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Bug with Mm.ErrMsg$
Posted: 08:57am 08 Oct 2021
I've been seeing this one for a while - and it's been p**sing me off in my unit-test framework - but I struggled to reproduce it until I had a poke around the source:
480MHz Colour Maximite 2 G2
MMBasic Version 5.07.01
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> list "error_test.bas"
On Error Skip 1
Error "foo"
Print "[ERRORMSG]" Mm.ErrMsg$ "[/ERRORMSG]
Print " ";
On Error Skip 1
Error "bar"
Print
> run "error_test.bas"
[ERRORMSG]Error in line 2: foo[/ERRORMSG]
[ERRORMSG]
Error in line 7: bar[/ERRORMSG]
Basically the formatting of the Mm.ErrMsg$ string (whether it starts with a CRLF) depends on the horizontal position of the cursor when the message is generated .
I think the offending bytes are probably Src/MMBasic.c#2495:
if(CurrentLinePtr < ProgMemory +  PROG_FLASH_SIZE) {
   if(MMCharPos > 1)MMErrorString("\r\n"); // <================= HERE
   MMErrorString("Error in ");
   char *ename;
This should probably include a check on the value of OptionErrorSkip, or better yet the whole CRLF business should move to where uncaught errors are rendered instead of where there messages are constructed.
Also note lines 2468 and 2471 which also seem to be prefixing "\r\n" on error strings (though these do check OptionErrorSkip) ... not sure why has to be done/checked 3 times .
Peter I know it's a minor issue, but any chance of fixing it if the other bugs I've reported are going to require a 5.07.02 alpha/beta anyway ?
Edited 2021-10-08 19:11 by thwill
Posted: 09:20am 08 Oct 2021
I think you are the only person who ever uses mm.errmsg$ but will fix in next beta.
Posted: 09:29am 08 Oct 2021
  matherp said  I think you are the only person who ever uses mm.errmsg$ but will fix in next beta.
Probably Peter. Thank you.
It's nice if it works well though. After all, *I* might need it someday and I'd get all flustered and confused. Even more so than usual, that is. :)
