Local Time 18:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: On Key Escape fun and games
Posted: 02:58pm 26 Oct 2021
Noticed this in MMB4L and it's present on the CMM2 too:
> list "on_key_test.bas"
On Key 27, do_quit
Sub do_quit
 End
End Sub
Run this and press one of the cursor keys, the program will end and display the remaining ANSI code for the cursor key without the leading escape character.
e.g. press [UP] and you get
[A
Possibly it's fixable, but might be simpler and not too limiting to add restrictions to valid ASCII codes for ON KEY ?
Edited 2021-10-27 00:59 by thwill
Posted: 03:05pm 26 Oct 2021
  Quote  but might be simpler and not too limiting to add restrictions to valid ASCII codes for ON KEY ?
Doesn't need fixing IMHO - buyer beware
There are good reason why non-ascii are useful
OPTION BREAK 4
on key 3, tidyexit
sub tidyexit
' close things as required
option break 3
end sub
Posted: 03:14pm 26 Oct 2021
OPTION BREAK 4
on key 3, tidyexit
sub tidyexit
option break 3
end sub
Yes, I've done that myself on your suggestion, but ON KEY 27 is going to catch more than the [Escape] key and it screws up a bunch of other keys which is why I'm wondering if it either needs guarding against or handling better ... though the latter would be messy.
Posted: 04:35pm 26 Oct 2021
Not that I imagine you would change it, but is there a second use case for either ON KEY <code>, or OPTION BREAK <code>?
If not then couldn't they be replaced with ON BREAK ?
Edited 2021-10-27 02:51 by thwill
jirsoft
Posted: 06:06pm 26 Oct 2021
Hi Tom,
I'm using ON KEY 157, NCprintScreen for screenshots...
Jiri
Posted: 11:55pm 26 Oct 2021
I assume you are using a terminal program, not a connected keyboard.
the up arrow VT code is esc [ A so your program is working as programmed.
If you cater for terminal programs, you will have to wait for a time after the esc to see if any characters follow before treating it as escape alone.
Goksteroo
Posted: 02:34am 27 Oct 2021
  jirsoft said  I'm using ON KEY 157, NCprintScreen for screenshots...
Why didn't I think of that - DOH!
Posted: 10:06am 27 Oct 2021
  TassyJim said  I assume you are using a terminal program, not a connected keyboard.
Thanks Jim,
On the CMM2 "yes", and it doesn't usually happen if you use a USB keyboard ... though very occasionally I do seem to get it , presumably a timing thing.
On MMB4L the keyboard is connected, but MMBasic does run inside a local terminal and thus sees the VT codes rather than reading directly from the keyboard; MMB4L currently has no KEYDOWN function for this reason.
  Quote  the up arrow VT code is esc [ A so your program is working as programmed.
Yes, I know, I understand, and that happens in the general keyboard input case, but MMB4L (like the CMM2) runs the code for intercepting/handling ON KEY <code> before the code that identifies and combines VT escape codes from the input into single bytes.
No action from anyone expected, just building up my knowledge.
