Local Time 17:14 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: suggestion regarding making named pins easier
Posted: 10:06am 30 Oct 2021
I would like to be able to do things like this:
Const BATTERY_PIN% = GP26
SetPin BATTERY_PIN%, AIN
battery! = Pin(BATTERY_PIN%)
And then if I want to change the pin connected to the battery voltage I just need to change the BATTERY_PIN% constant.
This doesn't work because in this context GP26 is interpreted as an undefined variable.
Assuming you agree this is desireable, perhaps (space permitting) something like this might suffice:
Const BATTERY_PIN% = Mm.Info(PIN GP26)
or
Const BATTERY_PIN% = Pin(Index GP26)
Or alternatively allow string variables to be used for specifying the pin in SETPIN and PIN.
YMMV,
Edited 2021-10-30 20:14 by thwill
Posted: 10:56am 30 Oct 2021
Doesn't sound unreasonable as
Const mypin = 1
Setpin mypin,din
a = Pin(mypin)
Print a
works fine but
Const mypin = GP0
Setpin mypin,din
a = Pin(mypin)
Print a
doesn't.
Saved 53 bytes
[2] SetPin mypin,din
Error : Pin 0 is reserved on startup
Edited 2021-10-30 20:59 by Mixtel90
Posted: 11:16am 30 Oct 2021
You are late to the game Mick, Peter implemented the MM.INFO based approach within 10 minutes of me suggesting it .
Posted: 11:33am 30 Oct 2021
I saw that just after I'd posted. lol
I like my way better though. :)
Edited 2021-10-30 21:35 by Mixtel90
Posted: 11:37am 30 Oct 2021
  Mixtel90 said  I like my way better though. :)
What's your way? If it was for this to work:
Const mypin = GP26
then that would require one function slot for each GP constant.
Edited 2021-10-30 21:54 by thwill
Posted: 12:00pm 30 Oct 2021
I didn't say my way was better, just that I like it more. :) It's not practical, I don't think (but the conversion does take place elsewhere).
