Local Time 18:15 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico programming
lew247
Posted: 12:20pm 13 Nov 2021
I have a slight problem
It's probably a simple answer to this but I've got a Pico that I've been programming with MM Edit
So far it's been flawless
However today I removed the SD card reader from the Pico as I don't need an SD card for my project
When I try and program the Pico I get this error
Starting process...
Chat closed
File manager closed
Connection Handle: 142280368 0
sending NEW
Clearing...
Checking device...
PRINT MM.DEVICE$
PicoMite
Checking version...
print mm.ver
5.070106
CMM2
MMBasic Version V  5.0701 detected
Sending C:\Users\lew24\OneDrive\Desktop\temp.bas
Blocks:88
XMODEM RECEIVE "TEMP.BAS"
Error : SDcard not configured
Failed to start
Saving program
How can I program it without the SD card
The built in editor would take too long to type it all out and cut and paste into the editor doesn't work
Posted: 01:07pm 13 Nov 2021
Hi Lewis,
You'll have to check the manual but there is a way to use XMODEM RECEIVE without a filename which will save it into RAM and then another mechanism to save from RAM into one of the "flash" slots. If you are using MMEdit then this is probably automated in some way, maybe you need a newer version?
Posted: 01:18pm 13 Nov 2021
You can use
XMODEM RECEIVE
to load text or BAS files into the PicoMite over USB.
Also, you can use
AUTOSAVE
then paste a text or BAS file into the PicoMite, finish with a Ctrl-Z to save the program or Ctrl-C to abort. (You'll almost certainly need a decent line delay in the terminal for this to work).
I tend to cut & paste chunks of program in Notepad, XMODEM it into the MMBasic platform and tweak it in the editor. You don't need to go to these lengths on the CMM2.
Once you have it you can save to a flash slot using
FLASH SAVE <slotnumber>
The CMM2 needs the SD card as you are editing the ASCII file on it. The PicoMite doesn't need it as the ASCII file is held in RAM during editing. I'm confused by the text you are seeing, particularly the reference to CMM2. I don't use MM Edit. I wonder if you've left the OPTION SDCARD in and it's confused?
Edited 2021-11-13 23:20 by Mixtel90
lew247
Posted: 01:56pm 13 Nov 2021
Thanks everyone
I got it by changing MM Edit to the Pi
It doesn't have a setting for the Pico
Posted: 08:48pm 13 Nov 2021
There are many different devices in the maximite family and almost as many different requirements for transferring data to/from them.
If you don't have a SDcard on the system, you cannot use a configuration that expects a file storage system.
Lew has worked that out already so problem resolved (for now)
The new version of MMEdit will make it easier to resolve issues like this but you will still need to know if your device has a SDcard fitted and if it can run without one.
Personally, I only use XMODEM as a last resort when transferring to the 'mite. AUTOSAVE is much tidier and that is what the new MMEdit uses by default.
You will still need to know about SDcard or not.
The file manager is the last part of MMEdit to get incorporated into MMEdit V5 but it will happen (eventually).
V5 has drag and drop, so to transfer a file to the 'mite, open Windows explorer, drag the BAS file onto the MMControlCentre (or shortcut) and it's done.
Edited 2021-11-14 06:53 by TassyJim
