Forum Index : Microcontroller and PC projects : How do you compose MOD music for the CMM2?
| danielkos Newbie Joined: 10/07/2021 Location: AustraliaPosts: 25 |
Sorry if there's already a thread on this. I couldn't find one. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9136 |
No idea. Tell us. :) MMBasic can play them using PLAY MODFILE and PLAY MODSAMPLE, but I'm not aware of a MOD file composer for MMBasic. Mick Zilog Inside! nascom.info for Nascom & Gemini |
I used to use Soundtracker, NoiseTracker Octamed etc. back in my Amiga days. Install WinUAE (or other emulator) and snag that code. Should be up an running in 10-20 mins (but the supplied samples are a bit "dated" so you'll spend longer finding nice ones - plenty of libraries about) to whet your appetite https://www.youtube.com/watch?v=0fGsVs0o4As (warning: total shoite content, unless you are a 90s raver) Edited 2021-11-22 18:20 by CaptainBoing |
Try this this link Daniel. There's also a full archive of mod files here. Greg |
Making MOD files The above helps with embedding sounds in a MOD file. OpenMPT can be used for composing too. A MIDI to MOD program would be quite useful - then you could play your digital piano and directly generate MOD files. This is all software on the PC side of things though, not running on a CMM2. Edited 2021-11-23 03:53 by vegipete Visit Vegipete's *Mite Library for cool programs. |
