Forum Index : Microcontroller and PC projects : CMM2: Aklabeth - possible Christmas project for someone
| Page 1 of 2 |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4405 |
Hi folks, I'm kind of busy otherwise I would probably have jumped at this, it's the "proto-Ultima" CRPG and appears to be only 1000 lines of legacy BASIC: https://github.com/JustinBaldock/X16-Akalabeth Best wishes, Tom Edited 2021-11-25 20:23 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9202 |
I wasn't aware of that at all. I've never played any of the Ultima series either. Hmmm... mono wireframe. Could this be the first proper game for the VeGAmite, I wonder? It should be green. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6171 |
The sinclair QL version seems portable. Single BAS file. Haven't seen (browsing through) any things the CMM2 could not handle. Is full of goto's though. To get that neat, involves pretty much a re-write. Volhout PicomiteVGA PETSCII ROBOTS |
I couldn't really argue with something that looks like it has a Hercules monitor running a program full of GOTOs. :) Wouldn't do for the CMM2 though. lol Mick Zilog Inside! nascom.info for Nascom & Gemini |
I thought this would be a quick simple port. Turns out de-spaghetti-ing 42 year old Applesoft Basic takes a bit of effort. Over 150 GOTOs and GOSUBs to vanquish... Here's a quick preview AkalabethPreview showing the monsters. I've taken some liberties and coloured them a bit, but they should be very true to their original shape. (This is a stripped down preview, my working code is getting close to complete.) Visit Vegipete's *Mite Library for cool programs. |
Neat work Pete, glad (if somewhat jealous) that somebody took up the challenge. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Nice done Pete ![]() Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
Dear Vegipete, Great you started the port !. I myself had postponed this for the christmas holidays (it's gonna be sh*tty weather, rain, rain, rain, rain and wet snow...). But now you beat me to it. !! Great work, it looks very structured now Volhout PicomiteVGA PETSCII ROBOTS |
Thanks! It's getting closer. I'm working through the subtleties of the player attacking monsters in the dungeon. After that, monsters attacking and moving and it should be done. Structure wise, I may be abusing DO : LOOP along with multiple EXIT LOOPs to accomplish some of the spaghetti GOTOs operations. This forces me to try to understand exactly what the original code is doing... sort of. It does explain why some people loath BASIC so much. Tangled messes of program flow were the potential hallmark of old-school BASIC and rightly should be deplored. But modern structured BASIC can be used much like any other structured language. GOTO hunting continues... Visit Vegipete's *Mite Library for cool programs. |
Great Scott! What a slog... Here's the original Applesoft monster move/attack/retreat/heal code: 4000 FOR MM = 1 TO 10: IF MZ%(MM,0) = 0 THEN 4999 It's kind of amazing what all is hidden in there. There _may_ even be a bug that erases monsters, although I don't think the relevant IF statement is ever true. (Line 4055)4010 RA = SQR ((PX - ML%(MM,0)) ^ 2 + (PY - ML%(MM,1)) ^ 2) 4011 IF MZ%(MM,1) < IN * LP THEN 4030 4020 IF RA < 1.3 THEN 4500 4025 IF MM = 8 AND RA < 3 THEN 4999 4030 X1 = SGN (PX - ML%(MM,0)):Y1 = SGN (PY - ML%(MM,1)) 4031 IF MZ%(MM,1) < IN * LP THEN X1 = - X1:Y1 = - Y1 4035 IF Y1 = 0 THEN 4045 4040 D = DNG%(ML%(MM,0),(ML%(MM,1) + Y1 + .5)): IF D = 1 OR D > 9 OR D = 2 THEN 4045 4042 X1 = 0: GOTO 4050 4045 Y1 = 0: IF X1 = 0 THEN 4050 4046 D = DN%((ML%(MM,0) + X1 + .5),ML%(MM,1)): IF D = 1 OR D > 9 OR D = 2 THEN X1 = 0: GOTO 4081 4050 DNG%(ML%(MM,0),ML%(MM,1)) = DNG%(ML%(MM,0),ML%(MM,1)) - 10 * MM 4055 IF ML%(MM,0) + X1 = PX AND ML%(MM,1) + Y1 = PY THEN 4999 4060 ML%(MM,0) = ML%(MM,0) + X1:ML%(MM,1) = ML%(MM,1) + Y1 4080 DNG%(ML%(MM,0),ML%(MM,1)) = (DNG%(ML%(MM,0),ML%(MM,1)) + 10 * MM + .5) 4081 IF X1 < > 0 OR Y1 < > 0 THEN 4999 4082 IF MZ%(MM,1) < IN * LP AND RA < 1.3 THEN 4500 4083 IF MZ%(MM,1) < IN * LP THEN MZ%(MM,1) = MZ%(MM,1) + MM + IN 4499 GOTO 4999 4500 IF MM = 2 OR MM = 7 THEN 4600 4509 PRINT "YOU ARE BEING ATTACKED": PRINT "BY A ";M$(MM) 4510 IF RND (1) * 20 - SGN (PW(3)) - C(3) + MM + IN < 0 THEN PRINT " MISSED": GOTO 4525 4520 PRINT "HIT":C(0) = C(0) - INT ( RND (1) * MM + IN) 4525 IF PA = 1 THEN PRINT "-CR- TO CONT. ";: INPUT Q$ 4530 GOTO 4999 4600 IF RND (1) < .5 THEN 4509 4610 IF MM = 7 THEN PW(0) = INT (PW(0) / 2): PRINT "A GREMLIN STOLE SO ME FOOD": GOTO 4525 4620 ZZ = INT ( RND (1) * 6): IF PW(ZZ) < 1 THEN 4620 4630 PRINT "A THIEF STOLE A ";W$(ZZ):PW(ZZ) = PW(ZZ) - 1: GOTO 4525 4999 NEXT : RETURN Add to that variable naming fun - Applesoft names are only significant to 2 characters, so DNG%() and DN%() are the same. Among others... Here's my rewrite of the above - much less compact, but hopefully much easier to understand: ' Handle each possible monster on level - there could be one of each. sub MonsterHandle local n% for n% = 1 to 10 if mz%(n,0) then MonsterAction(n%,ML%(MM,0),ML%(MM,0)) next n end sub ' Let monster n, located at mx,my, do it's thing. ' Weak monsters will try to run away, unless cornered. ' Distant strong monsters will try to move closer to the player. ' A monster up close to (beside) the player will attack. ' A thief or a gremlin might steal something instead of attacking. ' Mimics won't move closer if near (within 3 of) the player - sneaky critters! ' note: mx & my are passed by reference so that changes are returned sub MonsterAction(n,mx as integer,my as integer) local integer dx,dy local float ra ra = sqr((px - mx) ^ 2 + (py - my) ^ 2) ' distance to player dx = sgn(px - mx) ' direction toward player dy = sgn(py - my) ' -1/0/1 for x and y axes if mz%(n,1) < dngLevel*skill then ' all weak monsters try to run away dx = -dx ' change direction to dy = -dy ' away from player MonsterMove(n,mx,my,dx,dy) elseif ra < 1.3 then ' attack if beside player MonsterAttack(n) elseif n = 8 and ra < 3 then exit sub ' strong mimic doesn't move closer if within 3 else ' far away from player so try to move closer MonsterMove(n,mx,my,dx,dy) endif end sub ' Monster n at mx,my will try to move in direction dy, then try dx. ' A weak monster, if unable to move away, will attack if close - ie cornered ' note: mx & my are passed by reference so that changes are returned sub MonsterMove(n,mx as integer,my as integer,dx,dy) local integer d if dy <> 0 then '4045 ' no y-move so check for x-move d = dng%(mx,(my + dy + .5)) ' What's in the y direction? if d = 1 or d = 2 or d > 9 then dy = 0 ' can't move that way because wall, trap or another monster is there else dx = 0 ' : goto 4050 ' perform a y-move only endif endif if dx <> 0 then '4045 ' no y-move so check for x-move d = dng%((mx + dx + .5),my) ' What's in the x direction? if d = 1 or d = 2 or d > 9 then dx = 0 ' can't move that way because wall, trap or another monster is there endif endif if dx = 0 and dy = 0 then ' monster couldn't move if mz%(n,1) < dngLevel*skill then ' weak monster couldn't run if ra < 1.3 then ' desparation attack if beside player MonsterAttack(n) else mz%(n,1) = mz%(n,1) + n + dngLevel ' heal monster endif endif else ' movin, movin, movin, let's get that monster movin if mx + dx = px and my + dy = py then exit sub ' should never be true dng%(mx,my) = dng%(mx,my) - 10 * n ' erase monster at old location mx = mx + dx:my = my + dy ' passed by reference, must propagate back dng%(mx,my) = (dng%(mx,my) + 10 * n + .5) ' replace monster at new endif end sub ' Monster attacks! ' Unless it's a thief or gremlin, in which case there is ' a 50% chance it will steal something instead sub MonsterAttack(n) local integer t if n = 2 and rand(1) < .5 then ' yes, it's stealin thief time do t = int(rand(1) * 6) while pw(t) < 1 ' find something to steal print "A thief stole a ";w$(t) pw(t) = pw(t) - 1 if pa = 1 then print "-CR- to cont. ";: input q$ ' pause mode exit sub endif if n = 7 and rand(1) < .5 then ' yes, it's food stealin gremlin time print "A gremlin stole some food" pw(0) = int(pw(0) / 2) if pa = 1 then print "-CR- to cont. ";: input q$ ' pause mode exit sub endif print "You are being attacked by a ";m$(n) if rand(1) * 20 - sgn(pw(3)) - c(3) + n + dngLevel < 0 then print "Missed" else print "Hit!" c(0) = c(0) - int(rand(1) * n + dngLevel) endif if pa = 1 then print "-CR- to cont. ";: input q$ ' pause mode end sub Visit Vegipete's *Mite Library for cool programs. |
OK folks, it's release time. All the GOTOs are gone. It's snowing outside but nice and cozy inside as I put this together for your entertainment! Visit my site listed below to find Akalabeth for the Colour Maximite 2. Let me know what you find, or if something doesn't work right. Known issues: ==> Text when you kill a monster with a long name will likely be unclear. This can be fixed if it's a problem. ==> Pause mode not implemented. I see no purpose for this as the game waits for your input anyways. Also, there's no Save Game function. Would people really like this? Enjoy! Visit Vegipete's *Mite Library for cool programs. |
Signatures seen to be kaput at the moment so no link visible. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Working for me, Tom. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4386 |
Working for me, too. (Laptop with Linux.) John Edited 2021-12-27 19:34 by JohnS |
Right you are, it's the mobile site that doesn't show them, and my phone was misbehaving when I was telling it to show me the desktop site. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Well done Pete, all I can say is that "they don't make them like that any more". Are you planning to: 1. Send a link to CMM2.fun ? 2. Do any further work on it ? - I think the UI could do with some modernisation and the CMM2 could easily fill those polygons. Thanks for doing this, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
I'm undecided what more to do with it. I do have a maintenance update in the works - a minor bug fix due to variable names, plus some layout alterations. I have thought of integrating my One Page Contest entry 3D maze engine. Ideally the monsters could then be shown as actual graphic images. I just don't have the skill to draw such images. If an artist out there wants to volunteer... Toggling between original and 'modernized' would be possible. For other UI improvements, I'm open to suggestions. I suppose a mouse to select items for purchase is 'modern'. I don't want to go too overboard or too CMM2 specific as ports to other *mites are still easy to do. Vegipete's Maximite Programs, including Akalabeth Visit Vegipete's *Mite Library for cool programs. |
It would be rather nice to keep the "flavour" of the original, even if some modern touches were to be added. I'm not in favour of a mouse as that's very CMM2-specific (unless it can be easily bypassed anyway). It would be an anachronism almost as bad as playing it with a nunchuk! Edited 2021-12-31 08:46 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
I've posted an update with some bug fixes and a wider field of view. Enjoy. Also, here is quick experiment ... The Next Step Visit Vegipete's *Mite Library for cool programs. |
That's very neat, have you got actual Ultima 1 source, or is it a "workalike" ? Best wishes, Tom Edited 2022-01-04 21:10 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Page 1 of 2 |
