Forum Index : Microcontroller and PC projects : PicoMite VGA Edition beta releases
matherp Guru ![]() Joined: 11/12/2012 Location: United KingdomPosts: 10273 |
http://geoffg.net/Downloads/picomite/PicoMite_Beta.zip PicoMiteVGAV5.07.02b7 now included with the normal PicoMite Beta in the download from Geoff's site Fixes bug that added an extra space after a REM command each time the program was edited. Fixes bug in ON KEY keyno,int NEW subcommands for SETTICK SETTICK PAUSE, myint [,tickno] ' pauses the tick so that the interrupt is delayed but the current count is maintained SETTICK RESUME, myint [,tickno] ' resumes the tick after a pause NEW subcommands for FLASH FLASH LIST no [,all] ' lists in full the program held in the flash slot FLASH EXECUTE no ' runs the program in the flash slot direct from the flash memory without overwriting the main program Increases drive level for SDcard output pins (CD, MOSI and CLOCK) which MAY improve SDcard reliability when the SPI bus is loaded with additional devices (LCD and/or touch) Reduces maximum file name length to 63 characters but increase maximum files that can be listed with FILES command to 1000 Fixed memory leak caused by ctrl-C out of FILES command |
flasherror Senior Member ![]() Joined: 07/01/2019 Location: United StatesPosts: 159 |
Thanks for the pause/resume commands (and FILES fix). Now if my ordered Pico could just hurry up and get here... When you say "outline spec" do you mean from the programmer's point of view (i.e. what new MMbasic commands, how they would work etc) or the gory implementation details? I have noticed that the Espressif documentation on the AT commands is rather poorly done and doesn't match the AT command firmware exactly. I have had more luck in setting up a test access point with deliberately poor signal quality so I can see what firmware does. Edited 2021-12-19 09:25 by flasherror |
Yes, exactly that |
Just had a thought - should there be a way to disable/resume ALL timers with a single MMBasic command to make it more "atomic" / global timer interrupt disable? i.e. SETTICK PAUSE _ALL_ ? One reason for disabling all interrupts is that you might be trying to modify vars/flags used by multiple timer interrupts and disabling one by one might still have the chance that an interrupt fires before all of them are disabled? |
