Local Time 18:14 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows/DOS question
Turbo46
Posted: 04:17am 06 Jan 2022
I have two programs for Windows/DOS MMBasic and I want the first program to RUN the second one.
The trouble is, I want the second program to know if it has been RUN by the first and if so, get the parameters from a file. If not, then I want it to ask for them to be input via the keyboard.
I also want these programs to work in the same way for the CMM2.
The method I have come up with is for the second program to check for the parameter file and use it if it exists, process the data using the parameters from the file, then delete the file. The first program must therefore create the file each time it RUNs the second one.
When the second program is RUN by another means and the parameter file does not exist then it will ask for them.
I'd rather not create and delete the parameter file every time because the data it contains will vary infrequently. Having said that, the second program will create a new version of an existing file and over-write it each time it is run.
Is there a better way that will work for both MMBasic for Windows and the CMM2?
Bill
Edit: Maybe I should add: there is only one parameter at this stage - an integer.
Edited 2022-01-06 15:03 by Turbo46
Posted: 05:23am 06 Jan 2022
Does the CHAIN command still exist in the DOS version?
I seem to recall that CHAIN would run another program, preserving all the variables.
I THINK that CHAIN is still in the DOS version, but I would have to check.
Turbo46
Posted: 05:56am 06 Jan 2022
No it doesn't thanks Grogster. Not in the CMM2 either. I need to RUN the second program or clear all of the variables, there are large arrays in both programs. I believe CHAIN saves all of the variables for the chained program.
Bill
Posted: 06:03am 06 Jan 2022
commandline parameters
whatever you want when initiating from first program,
blank when starting manually.
JIm
Turbo46
Posted: 06:18am 06 Jan 2022
Thanks Jim, I know that works for the CMM2 but the Windows version only has:
RUN [file$]
The Windows version also has:
SYSTEM command-line$
But  that exits to DOS and executes the command line then returns to the original program. Not sure that would work and I don't want to return to the original program.
I know I can test for which device the program is running on and do one thing or the other, but I don't think it does what I want.
Bill
Posted: 06:37am 06 Jan 2022
Yes, you will need SYSTEM for the DOS version but a simple device test to work out what you are running on will handle that.
If you put 'END' immediately after the SYSTEM line, you will exit to MMBasic prompt or 'QUIT' to totally exit MMBasic.
Turbo46
Posted: 06:53am 06 Jan 2022
Thanks Jim, I think that should work. I hadn't noticed the QUIT command either. I don't know how much memory the Windows version reserves for one instance but I think I ran out of memory at one stage. As long as each program has its own environment that should be OK.
Bill
