Local Time 16:01 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - Pimorini IPS screen
JonathanWo
Posted: 11:38pm 06 Jan 2022
Hi All,
So Geoffs videos kicked me to look at the PicoMite - I have the smaller IPS display:
https://shop.pimoroni.com/products/pico-display-pack
But tried this afternoon to set options, which I have done, but I get a message that the display isn't configured - can anyone share the options they have used (I matched vs the pinout of the screen. (the pinouts are on the above link)
I have these options, and note the NULL - which is why I suspect its not playing but they were set (shown below)
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 133000
OPTION SYSTEM SPI GP10,GP11,GP28
OPTION LCDPANEL ST7789_135, LANDSCAPE,NULL,NULL,NULL
I set the LCDPANEL as follows:
OPTION LCDPANEL ST7789_135, L, GP21, GP30, GP22
Error : Display already configured
> option list
but keeps coming back with NULL.
I assume I am missing something blatantly obvious so if anyone has done this and can share it would be appreciated.
Jonathan
Posted: 11:55pm 06 Jan 2022
Try
OPTION LCDPANEL DISABLE
before each attempt to set it up.
Might not help but costs nothing.
JonathanWo
Posted: 12:17am 07 Jan 2022
Between the disable and getting the right GP pins - that got me further - Thanks Phil
Jonathan
JonathanWo
Posted: 04:39pm 07 Jan 2022
OK I was wrong, I am not sure how to set the reset pin as on pico its RUN set in options, but will keep tinkering
hitsware2
Posted: 04:45pm 07 Jan 2022
I have found some of the dislay options
have to be set in the proper order .
Even if later they ' list ' in a different
order .
my site
Posted: 04:57pm 07 Jan 2022
This is a very badly pinned display as they use the logical MISO pin for the backlight
Try
OPTION RESET
OPTION SYSTEM SPI 24,25,6
OPTION LCDPANEL ST7789_135,L,21,30,22,26
Depending on how they have wired the backlight try backlight 99 and backlight 1
Edited 2022-01-08 03:19 by matherp
JonathanWo
Posted: 06:01pm 07 Jan 2022
No - I have submitted defeat and ordered a 'normal' LCD panel, the one in the manual - so hopefully that will help :)
Thanks for the input though all, much appreciated.
Jonathan
Posted: 06:29pm 07 Jan 2022
  Quote  No - I have submitted defeat
Did you try my settings?
JonathanWo
Posted: 05:28pm 09 Jan 2022
I did Pete - i spent a while faffing - got a ILI3941 screen and boom worked instantly - so I am chuffed now - I might review the other screen at some point, but this one is a larger one anyway :)
Bleep
Posted: 10:27am 10 Jan 2022
Hi Peter,
I have, using the Pimoroni Display Pack 2, which is I believe the same pin out.
It doesn't work, because of pin 30.
> option reset
Error : Pin 30 is invalid
I had already used the same settings, but using pin 29 (as a dummy) instead of 30, which works fine, except, presumably I can't do a software reset of the screen, but that's fine. In fact I actually use the GP numbers, so:-
OPTION SYSTEM SPI GP18,GP19,GP4
OPTION LCDPANEL ST7789_320, L,GP16,GP22,GP17,GP20
However I have found a problem with BLIT, either BLIT READ, or BLIT. If I use these the copied rectangle is always white, so for example if I use:-
BLIT READ 1, 0, 0, 8, 8
and then later
BLIT WRITE 1, 100, 100, 8, 8
or even
BLIT 10, 10, 100, 100, 8, 8
Using my setup, the pasted square is always white, whatever colour the original copy area was.
Any Ideas?  To be honest, the only reason I was doing this was to see if using BLIT was faster than say filling a rectangle of the same size with black, for faster animation, so I currently don't need it.
Regards, Kevin.
Posted: 10:34am 10 Jan 2022
This display doesn't have a connection for LCD MISO. Therefore BLIT, transparent test and the pixel function can't work. The display that does work is the Waveshare 2.8" 320x240
Bleep
Posted: 12:02pm 10 Jan 2022
  matherp said  This display doesn't have a connection for LCD MISO. Therefore BLIT, transparent test and the pixel function can't work. The display that does work is the Waveshare 2.8" 320x240
Ok, fair enough, in that case could I get BLIT working by hacking the board, to bring out MISO on the defined pin GP4? I can't do this at the moment, I'm away from any of my tools, but presumably it should work?
Regards Kevin.
Posted: 01:32pm 10 Jan 2022
  Quote  in that case could I get BLIT working by hacking the board, to bring out MISO on the defined pin GP4?
I theory yes, In practice I doubt it. Looking at the schematic they are not even bringing that signal out to the FPC connector so you would have to find it on the display and the controller may not be accessible and looks like it is probably a COB
Most likely outcome based on my experience trying these type of things is a dead display
PS have you posted your solar system code on here? I'm sure there would be interest
Edited 2022-01-11 00:31 by matherp
Bleep
Posted: 04:00pm 10 Jan 2022
Having now had a closer look at the display board, I think you're right, oh well never mind. I can do a post here on the Solar system clock, but it may no be for a week or two, as I'm away, though I could probably download pictures from the other posts & re-do them here, I'll look into it. :-)
Regards Kevin
