Local Time 03:36 16 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A PicoMite CSUB to  timestamp pin changes (Manchester code?)
Posted: 04:15pm 14 Jan 2022
As part of the work I've been doing to shakedown the CSUB functionality in the PicoMite I thought I'd write a logger that can timestamp changes to an input pin very accurately (nearest micro-second).
This also shows the power of the CSUB on the PicoMite. You need V5.07.03RC14 or greater to run this code
Hopefully the comments in the code will be self-explanatory
Option explicit
Option default none
Interrupt myint 'set up an interrupt that can be triggered by the CSUB
SetPin gp6,cin,3 'set pin 9 (GP6) to cause a H/W interrupt on both edges
Dim a%(100) 'array to receive the timestamps
Dim b%=100 'maximum number of transitions to receive
Dim c%=20000000 'timeout of the CSUB in microseconds
log a%(),b%,c% 'initialise the logging
Do :Loop  'loop continuously
Sub myint 'subroutine that is triggered when the non-blocking CSUB terminates
 local integer i
 Do While a%(i) 'read all valid data
   Print i,a%(i) 'print it out
   Inc i 'increment the loop counter
 Print "end"
 Pause 200
 End  'terminate the program
End Sub
' This CSUB logs activity on GP6, each transition of the pin is
' logged to the nearest microsecond. The timestamp is positive for positive
' going transitions and negated for negative going ones
' The parameters are:
' an integer array to hold the timestamps
' an integer with the number of samples to take (the array must be at least this big)
' an integer giving a timeout in microseconds for the CSUB to terminate
' if the number of sample requested is not reached
' when either the timeout occurs or the number of samples is reached the
' CSUB triggers an interrupt to let the Basic program know
CSub log
0000002F
'timout
4B0CB570 4B0C681D 4798681B 428B6A6B D10DD303 42836A2B 4B08D20A 2300681A
4A076013 60136812 681B4B06 601A2201 46C0BD70 10000388 100003A8 10000384
100003C4 100003CC
'intprog
4B16B570 6825681C 3B016923 2B006123 4B13DD0E 2009681B 28004798 4B11D014
4798681B 60696028 33086823 BD706023 681A4B0D 60132300 68124A0C 4B0C6013
2201681B E7E4601A 681B4B06 23004798 418B4242 606B602A 46C0E7E6 10000388
10000328 100003A8 10000384 100003C4 100003CC
'main
0015B570 681B4B0C 447A4A0C 4B0C601A 4A0C681B 601A447A 681C4B0B 680B6020
4B0A6123 4798681B 686B682A 414B1812 62636222 46C0BD70 100003C4 FFFFFF7F
10000384 FFFFFF2D 10000388 100003A8
End CSub
#include "PicoCFunctions.h"
// uSecTimer returns a 64-bit integer giving the number of microseconds since system boot
// CFuncRam is 256 bytes of RAM that aren't touched by Basic
// PinRead gives the status of a pin specified by the number (pin9 = GP6)
// CFuncInt1 is the address of a function to be called when a H/W interrupt occurs on COUNT pin 1
// CFuncmSec is the address of a function to be called every millisecond by trhe main clock interrupt
// Interrupt is a variable that tells Basic that the INTERRUPT specified in the Basic code has been triggered
static void timout(void){ //routine called every millisecond
unsigned long long int *endtime=(unsigned long long int *)&CFuncRam[8];
if(uSecTimer()>*endtime){ //  timeout triggered
CFuncmSec=0; //disable the millisecond interrupt
CFuncInt1=0; //disable the H/W pin change interrupt
Interrupt=1; //trigger the Basic ionterrupt
static void intprog(void){ //routine called every change on GP6
unsigned int *array=(unsigned int *)&CFuncRam[0];
int *count=(int *)&CFuncRam[4];
unsigned int d=*array;
*count=*count-1; //decrement the event counter
if(*count<=0){ //count satisfied
Interrupt=1; //trigger the Basic interrupt
if(PinRead(9))*(long long int *)d=uSecTimer();
else *(long long int *)d=-uSecTimer();
*array=*array+sizeof(long long int);
void main(long long int *basicarray, long long int *samplecount, long long int *timout){
CFuncInt1=(unsigned int)&intprog; //set up the address for the H/W interrupt
CFuncmSec=(unsigned int)&timout; //Set up the address for the millisecond timer
unsigned int *array=(unsigned int *)&CFuncRam[0]; //get a pointer to a permanent location to store a global pointer to the array
int *count=(int *)&CFuncRam[4]; //get a pointer to a permanent location to store the count of the samples required
unsigned long long int *endtime=(unsigned long long int *)&CFuncRam[8]; //get a pointer to a permanent location to store the timeout value
*array=(unsigned int)basicarray;
*count=(int)*samplecount;
*endtime=uSecTimer()+ *timout;
Edited 2022-01-15 02:45 by matherp
twofingers
Posted: 05:01pm 14 Jan 2022
Pretty cool!
Posted: 09:16pm 14 Jan 2022
Thanks Peter this is excellent. All manner of devices with odd serial formats can now be read without need of a unique function or driver. With the stream captured processing can readily be done in basic. Perfect companion to BITBANG BITSTREAM for two way interaction.
Posted: 04:35am 15 Jan 2022
While playing with RC14 and the above CSub I noticed an odd thing. Using PWM as a signal source the difference between timestamps sometimes seemed wrong - double, expected value. What's wrong isn't the CSub, that is excellent but PWM. A CRO shows that at 3900 Hz and above the frequency divides by 2. It starts out at 3900 then instantly jumps to 1950 Hz. At PWM 100kHz sometimes it is 25kHz actual.
Incase the CSub had upset something I tried turning it off then on, made no difference, nor did changing PW %
Reducing CPU speed also had no effect.
PicoMite MMBasic Version 5.07.03RC14
Copyright 2011-2021 Geoff Graham
Copyright 2016-2021 Peter Mather
> setpin 4,pwm1a
> pwm 1,1000,25     ok
> pwm 1,3800,25     ok
> pwm 1,3900,25     not ok
> option cpuspeed 126000
> setpin 4,pwm1a
> pwm 1,1000,25     ok
After returning to:-
> option cpuspeed 252000
> setpin 4,pwm1a
> pwm 1,20000,50     ok
> pwm 1,4000,25     ok
> pwm 1,200000,25     ok
> pwm 1,4000,25     ok
all speeds work properly.
Spoke too soon, divide by 2 again.
Tried another Pico with RC13
PicoMiteVGA MMBasic Version 5.07.03RC13
> setpin 4,pwm1a
> for n=3500 to 4500 step 100 : pause 2000 : pwm 1,n,50 : next
And got the same result, at 3800 it divides by 2.
>setpin 4,pwm1a : setpin 9,fin
> for n=3500 to 4100 step 50 : pause 100 : pwm 1,n,50 : pause 1500 : :? n,pin(9) : next
3500    3002
3550    3550
3600    3600
3650    3640
3700    3700
3750    3730
3800    3800
3850    1925
3900    1945
3950    1975
4000    1990
4050    2025
4100    2050
Edited 2022-01-15 17:32 by phil99
Posted: 09:27am 15 Jan 2022
Please try the attached to confirm if I've fixed it
PicoMite.zip
Posted: 11:32am 15 Jan 2022
> UPDATE FIRMWARE
3500    3500
3550    3539
3600    3600
3650    3628
3700    3699
3750    3750
3800    3788
3850    1925
3900    1939
3950    1974
4000    2000
4050    2019
4100    2050
Still something odd. retrying after a CLEAR FLASH seems to have fixed it
> UPDATE FIRMWARE
Error : Cannot find a matching FOR
> OPTION DISPLAY 50, 240
3500    2722
3550    3550
3600    3579
3650    3648
3700    3700
3750    3738
3800    3800
3850    3828
3900    3898
3950    3951
4000    3987
4050    4050
4100    4078
Thanks for your help.
I will see if it stays that way when I restore the other Options.
Edit
> OPTION SYSTEM SPI GP18,GP19,GP16
> OPTION SYSTEM I2C GP0,GP1
> OPTION CPUSPEED 252000
> OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13
> OPTION TOUCH GP12,GP11
> GUI CALIBRATE 0, 3912, 3831, -897, -650
> OPTION SDCARD GP22
> OPTION RTC AUTO ENABLE
3500    3500
3550    3534
3600    3600
3650    3650
3700    3693
3750    3750
3800    3784
3850    1925
3900    1950
3950    1972
4000    2000
4050    2017
4100    2050
Its back to the same /2 above 3800.
I will remove Options to find which one dos it.
Edited 2022-01-15 21:50 by phil99
Posted: 11:45am 15 Jan 2022
How are you measuring? I'm using a counter/timer and getting correct results now independent of CPU speed. Was certainly wrong in original RC14
Posted: 12:11pm 15 Jan 2022
I was using a scope which gave the same results as FIN and your new CSub.
Removing all the options one at a time ( cpu restart each time) made no difference, but now CPU SPEED does.
OPTION CPUSPEED 126000
> cpu restart
> for n=3700 to 4000 step 50 : pause 100 : pwm 1,n,50 : pause 1500 : :? n,pin(9) : next
3700    2284
3750    3750
3800    3800
3850    3841
3900    3900
3950    3931
4000    4000
3700    3788
3750    3750
3800    3775
3850    3845
3900    3900
3950    3935
4000    4000
3700    2558
3750    3750
3800    3800
3850    2138
3900    1950
3950    1967
4000    2000
3700    3700
3750    3742
3800    3800
3850    3832
3900    3900
3950    3950
4000    3992
Posted: 12:45pm 15 Jan 2022
Re did clear flash and updated again then tried a few different CPU speeds. All ok up to 233000 at which point it died. No USB connection showing in Device Manager.
> UPDATE FIRMWARE
3700    3700
3750    3750
3800    3792
3850    3850
3900    3882
3950    3950
4000    4000
> option cpuspeed 200000
3700    2587
3750    3750
3800    3800
3850    3845
3900    3900
3950    3934
4000    4000
> option cpuspeed 210000
3700    3700
3750    3750
3800    3792
3850    3850
3900    3882
3950    3950
4000    4000
> option cpuspeed 233000
Posted: 01:52pm 15 Jan 2022
  Quote  All ok up to 233000 at which point it died.
I would suspect power supply to the Pico or similar. All my Picos run happily at 252MHz and PWM is now correct in all cases
Posted: 08:29pm 15 Jan 2022
Got it going again with a couple of hold button - plug in USB - clear flash - re-flash cycles.
At 133000
3700    3219
3750    3750
3800    3783
3850    3850
3900    3900
3950    3943
4000    4000
3700    3442
3750    3750
3800    3787
3850    1925
3900    1938
3950    1974
4000    2000
Edit
240000 seems ok
> option cpuspeed 250000
3700    2109
3750    3749
3800    3800
3850    2365
3900    1950
3950    1964
4000    1999
> option cpuspeed 240000
3700    2761
3750    3750
3800    3777
3850    3847
3900    3900
3950    3937
4000    4000
3700    3700
3750    3731
3800    3800
3850    3850
3900    3891
3950    3950
4000    3982
Edited 2022-01-16 06:40 by phil99
Posted: 09:08pm 15 Jan 2022
I can confirm Phil's observation
> option list
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL ILI9341, LANDSCAPE,GP7,GP8,GP9
OPTION TOUCH GP14,GP15
GUI CALIBRATE 0, 250, 504, 925, 747
OPTION SDCARD GP13
speed 200000 is OK
speed 250000 gives the half speed PWM.
Definitively PWM, not frequency measurement.
using firmware post earlier in this thread.
PicoMite.uf2 15/01/2022 0925
Posted: 09:25pm 15 Jan 2022
** Jump to Edit 4
Now it has infected FIN. FIN now shows double the frequency that I get on the CRO.
3700    5817   <--3700 actual
3750    7500
3800    7558
3850    3920   <--1925 actual
3900    3900
3950    3939
4000    4000   <--2000 actual
3700    6149
3750    7500
3800    7600
3850    4495   <--1925 actual
3900    3900
3950    3931
Edit
After power off
> ? mm.info(cpuspeed)
252000000
3700    7400   <--3700 actual
3750    7468
3800    7600
3850    3850
3900    3894
3950    3950
4000    3983   <--2000 actual
> ? mm.info(cpuspeed)
240000000
3750    7500
3800    7589
3850    7700
3900    7768
3950    7900
4000    8000   <--4000 actual
Edit 2 FIN showing double measured freq. at all CPU speeds, despite re-flashing.
> update firmware
> setpin 4,pwm1a : setpin 9,fin:for n=3700 to 4000 step 50 : pause 100 : pwm 1,n,50 : pause 1500 : :? n,pin(9) : next
3700    6646
3750    7500
3800    7569
3850    7700
3900    7800
3950    7889
4000    8000
> option cpuspeed 125000
3700    6649
3750    7501
3800    7569
3850    7701
3900    7800
3950    7889
4000    8000
> option cpuspeed 48000
3700    6643
3750    7500
3800    7569
3850    7700
3900    7801
3950    7888
4000    8000
Edit 3 Further observations.
Returned to this Pico after some time testing another (same PWM symptoms) and found FIN back to normal. It seems a brief power off / on is insufficient for a proper reset. If others also find this it may be worth a mention in the manual.
> With OPTION CPUSPEED 240000 PWM is fine up to 100kHz. Not sure what the upper limit is.
If PWM is set too high, relative to CPU speed MMBasic freezes though the heartbeat LED continues to blink. Only power off / on restores it.
Edit 4 Supply filtering
Added 10uF to +5v and 47uF to +3.3V and now PWM works to 200kHz at top CPU speed.
> pwm 1,200000,50 : pause 1500 : ? pin(9)
200659
> ? pin(9)
200712
> ? pin(9)
200777
CRO shows 200.3kHz, multimeter shows 199.9kHz.
Edit 5 It has reverted to the original problem, so the capacitors aren't the answer.
Edit 6
"V5.07.03RC15"
Many thanks Peter so far it is working perfectly.
> pwm 1,200000,50 : pause 2500 : ? pin (9)
199987
> ? pin (9)
199984                          measured 199.9kHz
> ? pin (9)
199976
> pwm 1,250000,50 : pause 2500 : ? pin (9)
248987                          measured 249.9kHz
Edited 2022-01-17 07:46 by phil99
Posted: 09:03am 16 Feb 2022
hi phil99,
Is this topic closed now ? From reading through it there seem to be different behaviour using the FIN and the CSUB, and you mentioned HW changes (adding capacitors) that was revoked later.
Is the fix in the SW the solution, or incidental ?
From the testing in the thread, I fear that the ARM can run at 252MHz, but that the peripherals (or synchronization on the bus) may become critical above 200MHz. Hence double and half readings (simply missing half of the events).
Any other info from this ?
Posted: 12:01pm 16 Feb 2022
Peter's fix in V5.07.03RC15 solved the problems for all the Picos I have, but mileage may vary for others as 252MHz is above spec.
disco4now
Posted: 11:59pm 18 Sep 2022
The LOG CSUB compiled with the new header file as required from V5.07.05 Beta13 onwards.
CSUB LOG
00000041
'timout
B082B580 4B10AF00 3320681B 4B0F607B 4798681B 681A687B 4299685B D10ED803
D8004290 4B0AE00B 2200681B 4B09601A 2200681B 4B08601A 2201681B 46C0601A
B00246BD 46C0BD80 1000038C 100003AC 10000388 100003C8 100003D0
'intprog
B085B590 4B22AF00 60FB681B 681B4B20 60BB3310 681B68FB 68BB607B 1E5A681B
601A68BB 681B68BB DC0B2B00 681B4B19 601A2200 681B4B18 601A2200 681B4B17
601A2201 681B4B16 47982009 D0081E03 681B4B14 00024798 6879000B 604B600A
4B10E00C 4798681B 000B0002 42502100 687C4199 000B0002 60636022 681B68FB
001A3308 601A68FB 46BD46C0 BD90B005 1000038C 10000388 100003C8 100003D0
1000032C 100003AC
'main
B088B580 60F8AF00 607A60B9 681B4B16 447A4A16 4B16601A 1D3A681B 4B15601A
61FB681B 681B4B13 61BB3310 681B4B11 617B3320 69FB68FA 68BB601A 685B681A
601A69BB 681B4B0C 00024798 6879000B 68496808 414B1812 600A6979 46C0604B
B00846BD 46C0BD80 100003C8 FFFFFF43 10000388 1000038C 100003AC
End CSUB
F4 H7FotSF4xGT
Posted: 08:27am 19 Sep 2022
Hi disco4now,
In the manchester thread Phil99 indicated the re-compiled version does not work on 5.07.05b18. Any idea ? Is there a new change in header file ?
I want to evaluate this code, so would appreciate if you could have help to make it work.
Maybe we could ask Peter to set up a teams meeting where he gives a demo/instructs (interested) forum members how to make CSUB's. Or maybe a short Youtube? I remember there was a thread earlier about this topic. I would definitely be interested in the ability to create CSUB's. I'll try to find this thread an see if I can understand from the writeup.
However... my skillset may be just the most dangerous one, knowing not enough (capable of a blink routine in Arduino) but being stubborn enough not to accept this flaw.
Edited 2022-09-19 18:27 by Volhout
Posted: 09:31am 19 Sep 2022
A web search like
CSUB site:www.thebackshed.com/forum
may be useful.
E.g. I found
https://www.thebackshed.com/forum/ViewTopic.php?TID=14126&P=1
https://www.thebackshed.com/forum/ViewTopic.php?TID=12289&P=1
For the Pico you may first want to follow the RPi doc to set up its tools.
Once you can build the pico sdk / tools (for which you don't need to know any C), you can write a CSUB with a pretty basic grasp of C - just stay simple - and ask here for tips etc.
Edited 2022-09-19 19:33 by JohnS
disco4now
Posted: 12:07pm 19 Sep 2022
I think this one works for B13 upwards.
CSUB LOG
00000041
'check_timer
'intprog
1000032C 100003AC
'main
B088B580 60F8AF00 607A60B9 681B4B16 447A4A16 4B16601A 4A16681B 601A447A
681B4B15 4B1461FB 3310681B 4B1261BB 3320681B 68FA617B 601A69FB 681A68BB
69BB685B 4B0D601A 4798681B 000B0002 68086879 18126849 6979414B 604B600A
46BD46C0 BD80B008 100003C8 FFFFFF43 10000388 FFFFFEDD 1000038C 100003AC
End CSUB
Source has one little fix.
static void check_timer(void){ //routine called every millisecond
CFuncmSec=(unsigned int)&check_timer; //Set up the address for the millisecond timer
F4 H7FotSF4xGT
Posted: 01:02pm 19 Sep 2022
This one is perfect.
