Forum Index : Microcontroller and PC projects : picomite gp15 problem
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5930 |
Did anybody experience any problems with GP15 ? Or did Peter have a fix already ? GP15 missing in python PicomiteVGA PETSCII ROBOTS |
I think it's only a problem if it's allocated to an internal peripheral (I2C2 or SPI2). Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Hi Mick,, On Peters VGApicomite it looks like GP15 is connected to an I2C header, or the RTC, or I have seen wrong... Regards, Volhout Edited 2022-01-22 01:30 by Volhout PicomiteVGA PETSCII ROBOTS |
That doesn't mean that he's using the internal I2C module though. He might be bit-banging the PS/2 and just happens to be using that pin. It works nicely anyway. :) The problem seems to have been that it was used by a patch to the USB system during startup and wasn't being freed off properly. Or something like that, I didn't delve into it too far. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
