Local Time 22:26 15 Aug 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows - alphas
     Page 2 of 12
Pluto
Posted: 09:45pm 17 Feb 2022
revision a1
I have encountered problems when editing in MMB4W. When copying program lines from Notepad and pasting into program in MMB4W by using CTRL+V, the paste seems in first place to work correctly. Trying to run the program reveals that the copy-paste operation has done also other unintended changes to the program. Sometimes the pasted line has also been added (and overwriting) at other places in the program. The "overwritten" line can jump to a completely different position in the program.
May be that I am doing something stupid.
My Copy-Paste procedure:
1. Normal copy in Notepad
2. In MMB4W I put the cursor to desired location
3. The "pasting" by CTRL+V
Have anybody else had similar observations?
Posted: 10:38pm 17 Feb 2022
  Quote  I get such an error
The radials are not allowed to be the same (modulus 360). You need to check for this in Basic
Michal
Posted: 11:03pm 17 Feb 2022
Though:
if y1%=x1% then y1%=x1%+1
Michal
panky
Posted: 12:37am 18 Feb 2022
When an error is encountered in a program,entering EDIT at the command line would take you to the line the error was on. Now it just takes you to the last line that was edited.
With all the GUI commands available (terrific), is there any way to emulate the GUI PAGE (it differs from the CMM2 PAGE command) ?
IRETURN appears twice in LIST COMMANDS
Doug.
Plasmamac
Posted: 01:30am 18 Feb 2022
ive tested
i found only one error in 30 tests.
i found 2 green background colored chars  in the soure after extreme  pasting.
cant repeat , sry
Plasma
Goksteroo
Posted: 01:46am 18 Feb 2022
Fonts 1 and 4 only contain the 95 ASCII characters and not the extended 7F to FF characters that the CMM2 have.
Plasmamac
Posted: 01:55am 18 Feb 2022
test your "atomsprite demo"
frame problems
if box disabled all looks ok
option explicit
option default none
'option console serial
mode 9
page write 1
'brownian motion demo using sprites
dim integer x(64),y(64),c(64)
dim float direction(64)
dim integer i,j,k, collision=0
dim string q$
for i=1 to 64
direction(i)=rnd*360 'establish the starting direction for each atom
c(i)=rgb(rnd*255,rnd*255,rnd*255) 'give each atom a colour
circle 10,10,14,1,,rgb(white),c(i) 'draw the atom
sprite read i,6,6,19,19 'read it in as a sprite
next i
cls
box 0,0,mm.hres,mm.vres
k=1
for i=mm.hres\9 to mm.hres\9*8 step mm.hres\9
for j=mm.vres\9 to mm.vres\9*8 step mm.vres\9
sprite show k,i,j,1
x(k)=i
y(k)=j
vector k, direction(k), 0, x(k), y(k) 'load up the vector move
k=k+1
next j
next i
do
for i=1 to 64
vector i, direction(i), 1, x(i), y(i)
sprite show safe i,x(i),y(i),1
if sprite(S,i)<>-1 then
break_collision i
endif
next i
page copy 1 to 0
loop
Sub vector(obj As integer, angle As float, distance As float, x_new As integer, y_new As integer)
Static float y_move(64), x_move(64)
Static float x_last(69), y_last(64)
Static float last_angle(64)
If distance=0 Then
x_last(obj)=x_new
y_last(obj)=y_new
EndIf
If angle<>last_angle(obj) Then
y_move(obj)=-Cos(Rad(angle))
x_move(obj)=Sin(Rad(angle))
last_angle(obj)=angle
EndIf
x_last(obj) = x_last(obj) + distance * x_move(obj)
y_last(obj) = y_last(obj) + distance * y_move(obj)
x_new=Cint(x_last(obj))
rem Graphics Programming on the Colour Maximite 2 45/66
y_new=Cint(y_last(obj))
Return
' keep doing stuff until we break the collisions
sub break_collision(atom as integer)
Local integer j=1
local float current_angle=direction(atom)
'start by a simple bounce to break the collision
If sprite(e,atom)=1 Then
'collision with left of screen
current_angle=360-current_angle
Else If sprite(e,atom)=2 Then
'collision with top of screen
current_angle=((540-current_angle) Mod 360)
Else If sprite(e,atom)=4 Then
'collision with right of screen
Else If sprite(e,atom)=8 Then
'collision with bottom of screen
Else
'collision with another sprite or with a corner
current_angle = current_angle+180
endif
direction(atom)=current_angle
vector atom,direction(atom),j,x(atom),y(atom) 'break the collision
sprite show atom,x(atom),y(atom),1
'if the simple bounce didn't work try a random bounce
do while (sprite(t,atom) or sprite(e,atom)) and j<10
do
direction(atom)= rnd*360
j=j+1
loop until x(atom)>=0 and x(atom)<=MM.HRES-sprite(w,atom) and y(atom)>=0 and y(atom)<=MM.VRES-sprite(h,atom)
loop
' if that didn't work then place the atom randomly
x(atom)=rnd*mm.hres-sprite(w,atom)
y(atom)=rnd*mm.vres-sprite(h,atom)
vector atom,direction(atom),0,x(atom),y(atom) 'break the collision
loop
End Sub
Edited 2022-02-18 12:01 by Plasmamac
Plasma
Pluto
Posted: 08:14am 18 Feb 2022
Thanks Plasmamac for testing. You were more successful than me with the Copy-Paste. I think I need to take a break with MMB4W until a manual is available. I am sorry for taking time from more relevant development issues.
Kind regards Fred
Posted: 09:32am 18 Feb 2022
  Quote  I am sorry for taking time from more relevant development issues.
Please don't give up. Every report is useful and the more info the better. It is highly likely there is a bug in paste as this is new code that is completely different from the CMM2.
  Quote  frame problems
Thanks for the report - found it and will fix in next version
  Quote  Fonts 1 and 4 only contain the 95 ASCII characters and not the extended 7F to FF characters that the CMM2 have.
The font files are the same but not being read the same - will investigate
  Quote  Though:
Hmmm - will investigate
  Quote  When an error is encountered in a program,entering EDIT at the command line would take you to the line the error was on. Now it just takes you to the last line that was edited.
This is work-in-progress pending introduction of include files
  Quote  With all the GUI commands available (terrific), is there any way to emulate the GUI PAGE (it differs from the CMM2 PAGE command) ?
GUI PAGE - same as CMM2 - not tested
  Quote  IRETURN appears twice in LIST COMMANDS
will investigate
Posted: 09:42am 18 Feb 2022
  Pluto said  Thanks Plasmamac for testing. You were more successful than me with the Copy-Paste. I think I need to take a break with MMB4W until a manual is available. I am sorry for taking time from more relevant development issues.
Kind regards Fred
It's not easy producing a manual for something that's still in alpha. This I know from experience. :)
Would it help if I went over the work so far and tried to put some sort of resource together like I did for the PicoMite? I've not really been following MMB4W.
Plasmamac
Posted: 09:58am 18 Feb 2022
He Pluto !
You can't give up because i found a ghost char after your suggestion.
Maybe a video from you to show us the Problem?
Plasma
Romeo
Posted: 12:40pm 18 Feb 2022
Definitively YES. But it could be an everyday work and a pain to do, big THANKS if you decide to do it anyway.
Posted: 01:54pm 18 Feb 2022
Here it is then.
If the updates aren't quite as fast as Peter's I'm sure you'll not be too hard on me. lol
RTF format, alpha releases start on page 12.
MMBasic For Windows 1802.zip
Plasmamac
Posted: 02:02pm 18 Feb 2022
Great! Thx Mixtel
Plasma
Tinine
Posted: 03:24pm 18 Feb 2022
Cheers, Mick. You are a much appreciated and huge asset to the community
Craig
Tinine
Posted: 03:40pm 18 Feb 2022
PDF Version
MMBasic_For_Windows.pdf
Posted: 05:52pm 18 Feb 2022
V5.07.03a3
MMBasic.zip
Fixes fonts 1 and 4 output of chars above ascii 127
Fixes bug in sprites overlapping screen edge
Gets rid of duplicate IRETURN
LIST command updated to support
LIST FILE fname$
LIST FILE ALL fname$
LIST PAGES
BIG CHANGE - SOUND NOW SUPPORTED
PLAY TONE
PLAY MODFILE
PLAY MODSAMPLE
PLAY FLAC
PLAY WAV
PLAY MP3
PLAY SOUND
PLAY PAUSE
PLAY RESUME
PLAY STOP
PLAY VOLUME
Differences from CMM2:
Playing all the music files in a directory not currently supported (trivial to do with Basic)
WAV, FLAC and MP3 playback only support 44100Hz stereo
PLAY TTS not implemented
PLAY EFFECT not implemented
Please note the sound system sets up yet another thread with a callback every 1/88200 seconds so let me know if you see performance issues starting up etc.
  Quote  Though:
This stops the radii being the same it doesn't stop the radials being the same
You need "if els = ela then ela = ela + 1"
Edited 2022-02-19 03:56 by matherp
Michal
Posted: 07:25pm 18 Feb 2022
Hi matherp,
  matherp said  This stops the radii being the same it doesn't stop the radials being the same
I did it too, but it still throws errors:
 mode 9
 nbx%=1000
 maxx=1024
 maxy=768
 For i%=1 To nbx%
   x%=Rnd()*maxx
   y%=Rnd()*maxy
   x1%=Rnd()*maxx
   y1%=Rnd()*maxy
   c%=Rnd()*&hffffff
   els=rnd()*360
   ela=rnd()*360
if els=ela then ela=ela+1
   Arc x%,y%,x1%,,els,ela,c%
 Next i%
 pause 1000
 For i%=1 To nbx%
   x%=Rnd()*maxx
   y%=Rnd()*maxy
   x1%=Rnd()*maxx+1
   y1%=x1%+(Rnd()*30)
   c%=Rnd()*&hffffff
   els=rnd()* 360
   ela=rnd()* 360
   Arc x%,y%,x1%,y1%,els,ela,c%
 Next i%
Michal
Posted: 07:30pm 18 Feb 2022
Make els and ela integers and it will work. You are testing for equality between floats - never a good idea
Michal
Posted: 07:48pm 18 Feb 2022
  matherp said  Make els and ela integers and it will work. You are testing for equality between floats - never a good idea
The fact is, it works.
Michal
     Page 2 of 12
