Local Time 18:07 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: RTC oddness.....
Posted: 06:51am 04 Apr 2022
DS3231 RTC chip NOT fitted, just using the on-board RTC.
Got this email from a client today about oddness with the RTC:
  My client said
I received the Colour MaxiMite 2 Gen2 unit last week and I have been
testing it. I also have a CMM2 Gen1 computer for comparison.
First I inserted a CR1220 battery. For the power source I used a 5V, 2A
USB plug pack. VGA output is connected to 15.6" monitor The keyboard is
a Mini Starkey Multimedia Keyboard. The mouse is a basic Microsoft
optical mouse. I inserted an SD card with music, and some programs I had
written using CMM2 Gen1 unit.
Switching power on very quickly displayed MaxiMite start-up screen on
the monitor. The bottom line on the screen displayed:
05:09:45   05 - 14 - 2025.
I proceeded to set the current time and date:
TIME$ = "20:45:30" and DATE$ = "31/03/22"
These were now diplayed correctly on the monitor.
I typed FILES <ENTER>. I used mouse, which was working OK,to select and
run a program "bubbles.bas". This program ran fine. When I returned
to a screen with the prompy (>), the bottom line was
displaying:
 A:/bubbles.bas  05:07:42   05 - 19 - 2025
I reset the current time and date again. The bottom line displayed the
correct information.
I decided to request a printout for time and date:
PRINT TIME$ gave 45:85:85
PRINT DATE$ gave 45 - 25 - 2165
NOT WORKING CORRECTLY!
I've never seen or heard of that kind of odd RTC behaviour.  Anyone else see that or can anyone comment on why he would be seeing such strange results?
Posted: 06:58am 04 Apr 2022
I am surprised that he/she didn't see the initial startup where you have to set the keyboard and date etc.
I suggest reset all options and start over again, including removing the battery if needed.
Posted: 07:22am 04 Apr 2022
Yes, I am wondering about that myself.
I have suggested that he:
1) Power off the unit
2) REMOVE the 1220 battery
3) Power up the unit
4) Select the keyboard layout, and set the date and time
5) Replace the 1220 battery
6) Cycle power and see if the RTC settings stay correct then.
I am wondering if putting in the 1220 battery BEFORE power-up and setting of the RTC, is somehow corrupting the ARM's internal RTC module or something.
Posted: 11:30pm 04 Apr 2022
Further to this, got this reply:
Thank you for your quick response.
I followed your instructions as far as I could,
I replaced the power source by Samsung 5V, 2A Travel Adaptor.
- Battery removed
- Power up
- Monitor glowing softly, green LED lit
- Pressed reset button on CMM board
       Red and green LEDs lit
       MicroMite Screen displayed
       Asking to specify keyboard layout - I selected 2 for US
       Entered numbers for time 19:05:40
       Entered numbers for date 04/04/22
       Inserted the battery
Bottom line on the screen:
  A:/bounce.bas     05:17:42  05 - 19 - 2025
  Note: ~bounce.bas was one of the programs I ran yesterday
        ~seconds are counting up
Switched off and on again
MicroMite screen (and)
< (prompt)
  A:/bounce.bas      05:05:53  05 - 19 - 2025
- Set time and date
    time$ = "19:20:22"
    dates = "04/04/22"
  A:/bounce.bas      19:20:35  04 - 04 - 2022
  [I didn't repeat PRINT time$ and date$]
- Switched off and on again
MicroMite screen with the prompt and crazy time and date reappear
This is very odd.  I have never seen this before in the hundreds of unit I have sold.
I told him to take the battery out again, and OPTION RESET, cycle power, re-enter the keyboard layout, date/time, put battery back in again and see if that helps.
I have no idea where the 2025 and 2165 year references are coming from....that is very strange indeed.
Posted: 11:43pm 04 Apr 2022
OPTION RESET is not the same as pressing the reset button. He mentions pressing the reset.
You also need a few minutes of no battery and power off to discharge backup power supplies.
Peter can advice on the correct method of clearing the system fully.
Posted: 04:06am 05 Apr 2022
OPTION RESET did seem to fix this issue, so you were right to suggest it a few posts back.
OPTION LIST
CURRENT VGA mode 800.600 RGB332
CURRENT DISPLAY 50.100
OPTION DS3231 ON (that was me yesterday)
OPTION USERKEYBOARD US
OPTIOM MOUSE 0.0
OPTION RESET <ENTER>
   Blank screen (faint glow)
- CMM off/on
- Insert battery
    MAXIMITE screen
    Select Keyboard Type 2
    Time 11:02:40
    Date 05/02/22
 A:/bounce.bas    11:02:50  05-04-2022
LOOKS GOOD!
OPTION LIST
- CMM off/on
  A:/bounce.bas    11:23:26  05-04-2022
OPTION MOUSE 0 <ENTER>
OPTION LIST
OPTION MOUSE 0.0
- CMM off/on
  MAXIMITE screen
 A:/bounce.bas    11:41:09  05-04-2022
> files
files displayed
Selected (with mouse) Perm.bas
 Ran OK
A:/Perm.bas.bas    11:44:55  05-04-2022
HOOOREY, IT WORKS!
Your suggestion worked, thank you!
OPTION RESET did something. I can't see what?
