Local Time 17:08 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/PicoMiteVGA V5.07.04 release candidate(s)
     Page 1 of 3
Posted: 09:58am 06 Apr 2022
V5.07.04RC1
This brings together the minor 5.07.04 beta changes on the PicoMite thread and the major changes in the colour handling thread on the PicoMiteVGA
This version will reset all flash and options so backup as required before loading
Edited 2022-04-06 19:59 by matherp
Posted: 10:11am 06 Apr 2022
IGNORE for the moment - error in upload
Posted: 12:33pm 06 Apr 2022
Should be OK to download now
Rickard5
Posted: 02:11pm 06 Apr 2022
matherp,
OK Here is the Dummest STFF question You will get all day, but is the uf2 file I've been using to play with Picomite while I'm waiting to Build my Picomite VGA 1.3 Board (Waiting on parts from Newerk) the same as the Picomite VGA uf3 file ?
Posted: 02:22pm 06 Apr 2022
  Quote   but is the uf2 file I've been using to play with Picomite while I'm waiting to Build my Picomite VGA 1.3 Board (Waiting on parts from Newerk) the same as the Picomite VGA uf3 file ?
No, there are two uf2 files in the download appropriately named
led-bloon
Posted: 10:51pm 06 Apr 2022
@matherp
Unable to build the code on github as MAXRESTORE is not defined anywhere.
(temporarily placed #define MAXRESTORE 100 in Commands.h and all compiled OK)
For interest:
README for PicoMite VGA Edition still states PicoMiteVGA V5.07.03b3.
Maybe remove this completely and rely on the main PicoMite README for
version?
led
Miss you George
Rickard5
Posted: 11:08pm 06 Apr 2022
Cool Thanks
Posted: 08:59am 08 Apr 2022
V5.07.04RC2
Fixes bug where the system would lock up on booting if OPTION RTC AUTO was enabled but the RTC was missing. Now a warning will be printed and the option disabled.
Posted: 10:24am 08 Apr 2022
That's a nice solution. Thanks, Peter. :)
BishopXXL
Posted: 12:30pm 08 Apr 2022
Hi Peter,
I think there is still the older version RC1 from 06.04
Posted: 01:04pm 08 Apr 2022
Should be OK now
Posted: 09:12am 10 Apr 2022
I've just updated RC2 to fix a tiny bug Jim found in MM.INFO(FILESIZE
Same bug was also in MM.INFO(MODIFIED
No version change as it was just removing a spurious error check from a cut-and-paste
led-bloon
Posted: 10:17am 20 Apr 2022
@matherp
V5.07.04RC2 (PicoMiteVGA)
Font problems when doing certain tasks:
Mode 1 has the default font of 1 - ok
Change to mode 2 and font defaults to 1 - ok but BIG font for screen
Change to font 7 - ok font now reasonable for screen
Proceed into the editor and font reverts back to 1
Exit editor, font remains at 1
Now change font back to 7 - ok
Type 'new' (program in memory or not) and font reverts to 1!
Run any program and font reverts to 1.
led
Miss you George
Posted: 01:12pm 21 Apr 2022
Hi Peter,
Is it possible for the PicoMite VGA to support KEYDOWN() on its PS/2 keyboard ? I think it's a pre-requisite to support multiple players on a single keyboard, unless there is another way I don't know about ?
EDIT: Actually turns out I'm not that bothered, you can pick-up multiple keys being pressed consecutively but not released (subject to how naff your keyboard matrix is) by using INKEY$ and/or ON KEY - you just can't tell when they are released, which for my current use-case I don't think I need.
Edited 2022-04-22 00:41 by thwill
Posted: 07:20pm 22 Apr 2022
Dear Peter,
Can I ask for one modification to the picomite software.
Setpin xx, PIN measures period of the input signal.
Based on the execution time of the associated value reading
a=pin(xx)
I assume this is reading the value from a hardware timer, and converting it to a value in ms.
The request is: can this value be a float, not an integer ? For the programming challenge I am reading input signal in the range of 1200Hz....1900Hz and want to distinguish between them. The FIN function cannot do it becuase it uses minimal 10ms. And the PIN function response is an integer in ms. If it was a float that would not disconnect with earlier MMBasic implementations, but add the functionality I need.
Edited 2022-04-23 05:22 by Volhout
Posted: 12:28am 23 Apr 2022
Would it be possible to adapt Peter's Pico CSUB LOG to do this? It records durations in uS.
PS.  CSUB LOG fills an array and generates a software interrupt. Rather than using a interrupt subroutine I use a DO loop to test for a change in the last element of the array.
The reason for this is I found no way out of the interrupt subroutine other than ending the program from within the sub (as Peter does in his example program).
When using LOG to measure the period of a cycle I get consistently accurate results when using the interval between falling edges. When using the rising edges there are occasional glitches of up to 16uS.
Edited 2022-04-23 14:24 by phil99
Posted: 06:14am 23 Apr 2022
Hi Phil99,
Maybe Csub log van be used but I may not have the time to do iT.
Let me explain. I am investigating SSTV.
Video pixels are sent over an audio channel. Similar to fax.
In color sstv you have 1ms per pixel.
The  PIN mode readout is 0.04ms (het data from timer register). On the VGA pico painting a pixel is fast (not on the pico with LCD). So the minimal math required and the timing overhead could " just " make iT possible. May need CPU overclocking.
But I need a readout of the fractions of ms from the period measurement.
FYi the period measurement is non blocking, iT just returns the last value seen. And that is exactly what I need.
Posted: 07:09am 23 Apr 2022
PIN is just the inverse of FIN. It does return a float but as per the manual
  Quote  For accurate measurement of signals less than 10 Hz it is generally better to measure the period of the signal.
When set to this mode the PicoMite will measure the number of milliseconds between sequential rising edges
of the input signal. The value is updated on the low to high transition so if your signal has a period of (say) 100
seconds you should be prepared to wait that amount of time before the PIN() function will return an updated
value.
What about using PULSIN?
Edited 2022-04-23 17:13 by matherp
Posted: 10:02am 23 Apr 2022
Peter,
Please advise.
I apply a frequency of 1900Hz. 0.5ms.
When I read the period of the pin every 2ms, then I would get the value of 0.5 each time I guess?
Even if I read the value into  pre defined float, I get 1 or 0 reading.
What is going wrong.?
Posted: 11:00am 23 Apr 2022
The PIN command is only accurate to the millisecond as specified
  Quote  PicoMite will measure the number of milliseconds between sequential rising edges
Same as every other MMbasic port and the original MM2
Pulsin is accurate to the microsecond
     Page 1 of 3
