Forum Index : Microcontroller and PC projects : Picomite VGA 1.3 power
| Rickard5 Guru Joined: 31/03/2022 Location: United StatesPosts: 463 |
I'm building the Picomite VGA 1.3 board and in my Newark Order I was backordered the TC1264 low dropout regulator Farnell 1852189. my question is can I power the Picomite VGA from USB Though the Pico? what kind of P/s supply is it really wanting ? I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
| al18 Senior Member Joined: 06/07/2019 Location: United StatesPosts: 238 |
The PicoMiteVGA should work OK when powered from the MicroUSB connector on the Pico. |
You almost certainly can if the 3V3EN pin hasn't been pulled low on the board. I can't remember how Peter arranged it now. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
| Amnesie Guru Joined: 30/06/2020 Location: GermanyPosts: 757 |
You can power the pico (vga) through USB, no problem.I tested this because the TC1264 in Germany is out of stock, too. I built me an adaptor board for the AMS1117 3.3 V LDO and it perfectly works. This part is more widely available. Even for the level shift transistors there are no parts in europe, so I used the 2N7000 instead (PINOUT!!!!). Greetings Daniel Edited 2022-04-09 21:16 by Amnesie |
FYI the TC1264-3.3VAB is in stock at Mouser for $1.33 I would NOT recommend the LM1117T-3.3 regulator as an alternate because the pinout is different. |
I ordered BST72A's (as Peter designed it for) from Farnell. Maybe I had the last stock ? Volhout PicomiteVGA PETSCII ROBOTS |
The problem with Mouser here: TC1264-3.3VAB 1off 1.02 UKP (on 8 weeks delivery though) Delivery (cheapest) 12.00 UKP Fine if you happen to want over 30 UKP's worth of stuff, otherwise don't bother. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Any TO220 LDO 3.3V regulator will do as long as it has the standard 7805 style pinout. Edited 2022-04-10 03:53 by matherp |
Mick The Problem with Mouser here is: if I order it for $1.33 it will take 10-12 days to get here on a Slow boat across the west Texas Desert Via USPS and that will drive me mad, so I'm going to drive the 70 miles each way to the $1.33 part with Gas @ near $4.50 / Gallon in a Truck that gets 20 MPG _$12 each way in tolls and a waste of 2 hours of my Valued time The Real problem is I'm just dumb enough to be there Monday morning @ 8:00 am to get $1.33 part I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
Wow... you're taking this *really* seriously. lol I'd order something similar (i.e. as described by Peter above) from ebay/Amazon and in the meantime power the PicoMite via its USB socket. (Don't fit the 3V3EN link on a 1.3 board). The onboard SMPS will easily supply enough 3V3 unless you plug in a load of expansion stuff. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
RickardS, I just mentioned Mouser because I thought you were going to pickup the Adafruit MicroSD 3.3 volt breakout board from Mouser also. You board will probably work fine without it. |
wow Mouser has the SD Board, Now it becomes worth the drive :) I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
Might as well get the parts for Mick’s PicoMite VGA game PCB a few posts down… |
