Forum Index : Microcontroller and PC projects : Kustom Version of Picomite VGA Basic
| Rickard5 Guru Joined: 31/03/2022 Location: United StatesPosts: 463 |
I've been up all night playing with MMBasic on the Pico and trying to sort out my Picomite VGA Build, and while I do no not mean to Arrogant or rude, The Court said I am Special and Incompetent, so as such I need to compile my own Kustom Version of MMBasic, where the Syntax error is Replaced with the ID10T Error! There should be only 2 Error codes, the ID10T and the PEBKAC errors (the problem exists between keyboard and chair) I just got my first Kernal Picnic Error ( problem in chair, not in computer) LOL LOL I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
Are you sure you haven't been up all night drinking ? Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
No offence, your initial post was more than usually eccentric even for TBS. Best wishes, Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
No Offense taken Buddy, I'm a TEXAN you can't offend or embarrass us, I was / am Frustrated trying to figure out how to control a stepper motor from a Picomite, using a stepstick stepper driver, with a button, I know I can it can be done, but I just got to Read/learn more. I am having the best time playing with MMBasic and building Picomite stuff:) it's all like being in Jr. High again playing with 8bit computers and HeathKits. it's Kicked MY OCD in to Overdrive Great Respect Rickard I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
If you can post the datasheets for the stepper and the driver, I am sure someone can help you get it working. ![]() Plenty of people have had stepper motors running off MMBASIC in the past, including me, so it most certainly is possible, but we'd need the datasheets to help you further at this point. One thing I remember from when I was playing with stepper motors, is that you need to make allowances for ramping up and ramping down the spindle-speed if you are using the stepper motor as a rotational motor and not just native little steps. I found that if you don't ramp-up and ramp-down, the motor will either stall on its way to full speed or on its way down to stopped. You might not be wanting to do that kind of thing though, but I mention it, cos it caught me out at the time! ![]() Smoke makes things work. When the smoke gets out, it stops! |
| DaveJacko Senior Member Joined: 25/07/2019 Location: United KingdomPosts: 103 |
Ramping a stepper.. not yet done it with a micromite.. (really needs C or Assembler or some really clever Backshedder) however, with light loads and limited speeds, you can start at full speed. Have a look at my attempt on youtube: https://youtu.be/Buybf25-wbg Runs 2 axes simultaneously, fastest axis limit is 1000 steps per second. (might be poss to improve on this - use pulse output wire link to interrupt input?) The code is concise will post if you like. Steppers and Stepsticks are good fun.. regs, Dave Try swapping 2 and 3 over |
Yeah Dave any info you can post would be most helpful I don't care about ramping up I'm meow doing stuff like moving XY Tables , Rotary tables, spin indexers on my Sureline lathe-mill setup. the real goal is bit of kit that I can plug 2 or 3 steppers in to and have a button for each direction that moves the stepper a predetermine # of steps and a home button that resets the stepper the Big Reason I'm so Head strong on the Stepstick is they are cheep, I have like 50 of them, and if I can get a stepstick working then it's an easy change over to the big drivers like the ones on my Bridgeport Just Step and Direction. I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
Duplicate post Edited 2022-04-13 10:11 by Rickard5 I may be Vulgar, but , while I'm poor, I'm Industrious, Honest, and trustworthy! I Know my Place |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5930 |
You van controle a steppen motor from basic. a multi axis simultaneous control may require to use the picomite PIO sequencer. PicomiteVGA PETSCII ROBOTS |
Wow! the PicoMite PIO has amazing potential ! Here is my code for the project shown on the earlier youtube link. An XY plotter using string, 2 stepsticks and steppers, also a model RC servo. https://youtu.be/Buybf25-wbg I think it's not bad, but I did write it! ' Hello world in G-Code ' gantry plotter DPJ 2020 init Pin(enabpin)=0 ls=9333 'steps=350mm xnow=ls/2 'on the centre ynow=ls/2 '27=1mm l1now=ls*0.707 '1/sqr(2) l2now=ls*0.707 '=250mm mainlp: t$=Inkey$ If t$="" Then GoTo mainlp If t$=" " Then Pin(enabpin)=1:PWM 2,stop: End If t$="u" Then penup If t$="d" Then pendn If t$="p" Then plotdata a$=a$+t$ If Len(a$)>3 Then a$=Right$(a$,3) If a$=lc$ Then moveby -266,0 If a$=rc$ Then moveby 266,0 If a$=uc$ Then moveby 0,-266 If a$=dc$ Then moveby 0,266 GoTo mainlp Sub MoveTo(mtx,mty) '====== MoveTo moveby mtx-xnow,mty-ynow End Sub Sub MoveBy(mbx,mby) ' ====== Move By ' calc turns from mbx,y l1now=Sqr(xnow*xnow+ynow*ynow) 'maybe +residual l1now l2now=Sqr((ls-xnow)*(ls-xnow)+ynow*ynow) xtarg=xnow+mbx ytarg=ynow+mby l1targ=Sqr(xtarg*xtarg+ytarg*ytarg) l2targ=Sqr((ls-xtarg)*(ls-xtarg)+ytarg*ytarg) l1mov=l1targ-l1now l2mov=l2targ-l2now xnow=xtarg ynow=ytarg ' now turn motors by l1mov,l2mov 'directions.. If l1mov>0 Then Pin(dirxpin)=0 Else Pin(dirxpin)=1 If l2mov>0 Then Pin(dirypin)=1 Else Pin(dirypin)=0 'major axis is.. If Abs(l1mov)>=Abs(l2mov) Then 'l1 is major l1i=Sgn(l1mov) l2i=l2mov/Abs(l1mov) ni=Abs(l1mov) 'num of incs Else 'l2 is major axis l2i=Sgn(l2mov) l1i=l1mov/Abs(l2mov) ni=Abs(l2mov) EndIf l1acc=0:l2acc=0 For i=1 To ni ' do move l1acc=l1acc+l1i l2acc=l2acc+l2i If l1acc>=1 Then l1acc=l1acc-1:Pin(stpxpin)=1 If l1acc<=-1 Then l1acc=l1acc+1:Pin(stpxpin)=1 If l2acc>=1 Then l2acc=l2acc-1:Pin(stpypin)=1 If l2acc<=-1 Then l2acc=l2acc+1:Pin(stpypin)=1 wait1 Pin(stpxpin)=0 Pin(stpypin)=0 Next i End Sub Sub PlotData ' ====== plot G-Code Data Restore xb=xnow:yb=ynow gcloop: Read t$ If Left$(t$,3)="G00" Then penup If Left$(t$,3)="G01" Then pendn If t$="M02" Then GoTo exgc xcp=Instr(1,t$,"X") ycp=Instr(1,t$,"Y") 'can also find F's and Z's lcp=Len(t$) If xcp<>0 Then nx=Val(Mid$(t$,xcp+1,ycp-1)) ny=Val(Mid$(t$,ycp+1,lcp-ycp)) moveto xb+nx*30,yb-ny*30 EndIf GoTo gcloop exgc: End Sub Sub init '---- init stpxpin=2 stpypin=3 stpzpin=4 dirxpin=5 dirypin=6 dirzpin=7 enabpin=9 stoppin=15 'servopin=26 pwm SetPin 2,dout SetPin 3,dout SetPin 4,dout SetPin 5,dout SetPin 6,dout SetPin 7,dout Pin(9)=1 'enable off SetPin 9,dout SetPin 15,din,pullup 'int? e$=Chr$(27) 'escape uc$=e$+"[A" 'cursor keys dc$=e$+"[B" rc$=e$+"[C" lc$=e$+"[D" SetTick 1,int1ms 'timer Pause 100 End Sub Sub penup PWM 2,50,7 Pause 100 End Sub Sub pendn PWM 2,50,10 Pause 100 End Sub Sub int1ms ' --timer subs iflag=1 End Sub Sub wait1 w1lp: If Not iflag Then GoTo w1lp iflag=0 End Sub 'Hello World' 'in G-Code rendered with Stickfont 'converted with G-Code to Data prog.txt '- a simple program producing data statements for MMbas ' DPJ sept2020 Data "G00Z0.0" Data "X1.9048Y10.0" Data "G01Z0.0F0.0" Data "X1.9048Y0.0" Data "G00Z0.0" Data "X8.5714Y10.0" Data "G01Z0.0F0.0" Data "X8.5714Y0.0" Data "G00Z0.0" Data "X1.9048Y5.2381" Data "G01Z0.0F0.0" Data "X8.5714Y5.2381" Data "G00Z0.0" Data "X12.1764Y3.8095" Data "G01Z0.0F0.0" Data "X17.8907Y3.8095" Data "X17.8907Y4.7619" Data "X17.4145Y5.7143" Data "X16.9383Y6.1905" Data "X15.9859Y6.6667" Data "X14.5573Y6.6667" Data "X13.6049Y6.1905" Data "X12.6526Y5.2381" Data "X12.1764Y3.8095" Data "X12.1764Y2.8571" Data "X12.6526Y1.4286" Data "X13.6049Y0.4762" Data "X14.5573Y0.0" Data "X15.9859Y0.0" Data "X16.9383Y0.4762" Data "X17.8907Y1.4286" Data "G00Z0.0" Data "X21.4462Y10.0" Data "G01Z0.0F0.0" Data "X21.4462Y0.0" Data "G00Z0.0" Data "X25.3545Y10.0" Data "G01Z0.0F0.0" Data "X25.3545Y0.0" Data "G00Z0.0" Data "X31.1675Y6.6667" Data "G01Z0.0F0.0" Data "X30.2152Y6.1905" Data "X29.2628Y5.2381" Data "X28.7866Y3.8095" Data "X28.7866Y2.8571" Data "X29.2628Y1.4286" Data "X30.2152Y0.4762" Data "X31.1675Y0.0" Data "X32.5961Y0.0" Data "X33.5485Y0.4762" Data "X34.5009Y1.4286" Data "X34.9771Y2.8571" Data "X34.9771Y3.8095" Data "X34.5009Y5.2381" Data "X33.5485Y6.1905" Data "X32.5961Y6.6667" Data "X31.1675Y6.6667" Data "G00Z0.0" Data "X43.9436Y10.0" Data "G01Z0.0F0.0" Data "X46.3245Y0.0" Data "X48.7055Y10.0" Data "X51.0864Y0.0" Data "X53.4674Y10.0" Data "G00Z0.0" Data "X58.5256Y6.6667" Data "G01Z0.0F0.0" Data "X57.5732Y6.1905" Data "X56.6208Y5.2381" Data "X56.1446Y3.8095" Data "X56.1446Y2.8571" Data "X56.6208Y1.4286" Data "X57.5732Y0.4762" Data "X58.5256Y0.0" Data "X59.9541Y0.0" Data "X60.9065Y0.4762" Data "X61.8589Y1.4286" Data "X62.3351Y2.8571" Data "X62.3351Y3.8095" Data "X61.8589Y5.2381" Data "X60.9065Y6.1905" Data "X59.9541Y6.6667" Data "X58.5256Y6.6667" Data "G00Z0.0" Data "X65.903Y6.6667" Data "G01Z0.0F0.0" Data "X65.903Y0.0" Data "G00Z0.0" Data "X65.903Y3.8095" Data "G01Z0.0F0.0" Data "X66.3792Y5.2381" Data "X67.3316Y6.1905" Data "X68.284Y6.6667" Data "X69.7125Y6.6667" Data "G00Z0.0" Data "X72.254Y10.0" Data "G01Z0.0F0.0" Data "X72.254Y0.0" Data "G00Z0.0" Data "X81.4004Y10.0" Data "G01Z0.0F0.0" Data "X81.4004Y0.0" Data "G00Z0.0" Data "X81.4004Y5.2381" Data "G01Z0.0F0.0" Data "X80.448Y6.1905" Data "X79.4956Y6.6667" Data "X78.067Y6.6667" Data "X77.1146Y6.1905" Data "X76.1623Y5.2381" Data "X75.6861Y3.8095" Data "X75.6861Y2.8571" Data "X76.1623Y1.4286" Data "X77.1146Y0.4762" Data "X78.067Y0.0" Data "X79.4956Y0.0" Data "X80.448Y0.4762" Data "X81.4004Y1.4286" Data "G00Z0.0" Data "M02" 'end of prog Try swapping 2 and 3 over |
