Local Time 17:11 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomites and servos
Bill.b
Posted: 12:08am 09 May 2022
The servo command is not listed in the pico command table. Is this and omission or is this command unavailable of picos.  Is there an alterative way to drive servos i.e using pulse out.
Bill
Posted: 12:34am 09 May 2022
Quickest way to find out would be to hook one up and see if if the servo command makes it move. If you don't have a servo to hand connect an oscilloscope to the Pico. Another Pico running the Scope program would do.
PWM could be another way. Keep the frequency constant and adjust the pulse width to move the servo.
Tried it. "Error : Unknown command" so PWM it is.
Edited 2022-05-09 11:01 by phil99
Posted: 01:35am 09 May 2022
PWM works.
Posted: 06:51am 09 May 2022
The PicoMite doesn't have the SERVO command. This has come up before.
Posted: 07:04am 09 May 2022
The servo command is just a simple repackaging of the PWM command and therefore if included just wastes a command slot
PWM n,50,(position_as_a_percentage * 0.05 + 5)
Edited 2022-05-09 17:06 by matherp
Posted: 10:41am 09 May 2022
Some example code how you can use PWM to move a servo.
Servo's work at 50Hz (20mS) PWM
The actual math is in "program PWM's", the rest is just an explanation where the
numbers come from.
'defines
frequency=50            'hz
period= 1e6/frequency   'us
'servo characteristics (what PWM gives what angle)
PWMmin= 800             'us
PWMmax= 2200            'us
AngMin=-90              'degrees
AngMax=90               'degrees
'calculations
AngRange=AngMax-AngMin  'degrees
DCmin=100*PWMmin/period '%
DCmax=100*PWMmax/period '%
DCRange=DCmax-DCmin     '%
'system setup
PWM 0,off
SetPin GP0,pwm0a
SetPin GP1,pwm0b
'Control servo, give Angle0 and Angle 1
'for test
 Angle0=-45
 Angle1=45
'Program PWMs
DC0=DCmin + ((Angle0-AngMin)/AngRange)*DCRange
DC1=DCmin + ((Angle1-AngMin)/AngRange)*DCRange
PWM 0,frequency,DC0,DC1
So in essence the formula is (for those who like numbers):
DC=7.5 + Angle*0.044   'angle in degrees
PWM 0,50,DC
Edited 2022-05-11 03:22 by Volhout
