Local Time 03:18 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD card on TFT displays
Posted: 10:42am 22 May 2022
Posted: 10:51am 22 May 2022
Gday All,
I am designing a small Pi-Pico backPack board on 50mm square format for, primarily, my own purposes as due to the price of the pi-pico and it’s availability both being better than an MX170 chip itself it seems the best direction for me to go down.
I am wondering why no one seems to use the SD card that’s on the 14 pin SPI TFTs that are out there.
All the signals seem to be there on a 4 pin header so it would take less real estate to run a 4way cable to the TFT instead of adding a socket on the daughter board.
Am I missing something here?
Is it a bad idea for some reason?
Is there a compelling reason to have the SD socket on the daughter board?
Kind Regards,
Posted: 11:24am 22 May 2022
I've used one on one of the ILI9341 displays. Easy enough to use, but they put series resistors on the signal lines. I had problems getting a PicoMite to work with some SD cards until I shorted those out. Otherwise they are fine. I had to solder my own 4-pin header on though - it's not included.
I think the main problem with the display SD card sockets is that they are in a bit of an awkward place. Not much use if you want to mount the display behind a panel.
Kabron
Posted: 11:25am 22 May 2022
I do use it.
Sometimes some manipulations with resistors in signal paths required(delete/lower/increase).
Posted: 11:42am 22 May 2022
My ILI9341 SDcard works flawlessly
Posted: 11:54am 22 May 2022
Thanks All,
My TFT seems to have no resistors but I will recheck that.
Thank you all,
