Forum Index : Microcontroller and PC projects : SD Card on Pico System SPI
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 531 |
Hi all, as i'm new to the forum let me just briefly introduce myself. I'm a retired IT (Industry and Banking) pro and have programmed for many years in Basic (VAX/VMS) and also have a reasonable background in electronics. I also have a ham radio license (OE1HGA) and this leads to my current project. I want to revive my ICOM IC-PCR1000 broadband receiver and the Pico with PicoMite Basic is a good platform to achieve this goal. Revive, because the Windows software to control the device is making more and more problems with every version of Windows, even if running on virtual host. The pico software has already take shape and many basic functions are running and let me control the receiver in wide parts via touch screen. Having the least number of buttons, pots and encoders is also a goal. The problem i have is using a SD Card interface on the system SPI pins (clk, mosi, miso). The scope shows that CS is asserted, clk is running for some periods but no level change on mosi and miso. Files command says that there is no SD card. A lcd screen on the same pins works like a charm, CS of course, is different. SD card on other pins than system SPI works without problems. But this is not my preferred solution as, i fear, i will run out of pins for any further extensions. Are there some limitations i have overlooked or any known problems with running SD card on system SPI? The effect is the same on the current version as on the current beta. I'v tried it with different lcd-screens, even without lcd to no avail. So it appears as not to be tied to the hardware i'm using. Running out of ideas now .... Any help is welcome. Regards, Gerald 73 de OE1HGA, Gerald |
If the LCD has touch then this must be configured otherwise it will corrupt SD transfers. If the LCD is a ILI9488 then MISO should not be connected (or connected via a 680ohm resistor). More info on your configuration would be helpful |
Hi Gerald, There are 2 different builds for the picomite. One with VGA, and one without. If you are using the pico with VGA, you can, and have to, assign the sd card pins in an OPTION SDCARD This is because the VGA picomite does not have a system spi bus. The normal picomite has support for a spi lcd display, and can share the spi bus with the sd card. For the normal picomite you have to assign the system spi bus, and appart from that assign the sdcard CS pin. This is described in the user manuals. But you can get confused if you read the normal picomite manual and try to use the examples on the VGA picomite. PicomiteVGA PETSCII ROBOTS |
Hi Gerald, There are 2 different builds for the picomite. One with VGA, and one without. If you are using the pico with VGA, you can, and have to, assign the sd card pins in an OPTION SDCARD This is because the VGA picomite does not have a system spi bus. The normal picomite has support for a spi lcd display, and can share the spi bus with the sd card. For the normal picomite you have to assign the system spi bus, and appart from that assign the sdcard CS pin. This is described in the user manuals. But you can get confused if you read the normal picomite manual and try to use the examples on the VGA picomite. If you describe your connections, we may be able to help in more detail. PicomiteVGA PETSCII ROBOTS |
Hi Volhout, thanks for your swift response. I'm NOT using the VGA build. The options I used in one example are: OPTION SYSTEM SPI GP10,GP11,GP12 OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13 option SDCARD GP22 So IMHO I proberly share LCD and SD card bus (clk, mosi, miso) AND both are on system SPI. This works for LCD but NOT for SD card. I've tried a similar setting with a different LCD (ST7789_320), but SD is also not working. 73 de OE1HGA, Gerald |
If the LCD has touch then this must be configured otherwise it will corrupt SD transfers. Manual page 37 Edited 2022-06-14 22:17 by matherp |
I've tried to avoid any false response, also any signal collisions 1) the LCD with the ST7789_320 controller has no touch 2) I've also tried to avoid any false response or any signal collisions by stripping down the hardware. Even LCD/touch is physically not attached and only SD is attached, SD is not working. On the scope you can see data transfer to the (not connected) LCD with TEXT commands but no data transfer on FILES command (only cs and clk are asserted) 73 de OE1HGA, Gerald |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3290 |
As @matherp previously noted "If the LCD has touch then this must be configured otherwise it will corrupt SD transfers. If the LCD is a ILI9488 then MISO should not be connected (or connected via a 680ohm resistor)." That 680ohm resistor is essential if you have connected MISO to the display. Touch and SD card connect directly to MISO. That particular display has a defect that keeps its Data Out pin active. If directly connected to MISO it blocks SD and touch. |
in my 2nd testcase there is no LCD panel physically connected to the Pico, just the SD card. So there is no way for the LCD to block MISO. And as long as you do just write to the LCD, the MISO is not used. At least the Basic interpreter does not complain about the unconnected LCD and clocks out the data. 73 de OE1HGA, Gerald |
The sd initialisation sends clock pulses and expects the card to pull MISO high. Unless it sees MISO go high then nothing else will happen. The fact that your SD works on other pins suggests something is holding MISO low (or the pin itself is faulty) What version is your ST7789_320? The Waveshare version has touch and is configured OPTION SYSTEM SPI GP10,GP11,GP12 OPTION LCDPANEL ST7789_320, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 408, 3901, 900, -646 OPTION SDCARD GP22 The Waveshare ILI9488W is configured OPTION SYSTEM SPI GP10,GP11,GP12 OPTION LCDPANEL ILI9488W, LANDSCAPE,GP8,GP15,GP9,GP13 OPTION TOUCH GP16,GP17 GUI CALIBRATE 0, 3998, 242, -1281, 860 OPTION SDCARD GP22 I've tested both these with the release firmware and both work perfectly |
Thanks to all supporters, problem solved, mea culpa! The config was currently exactly as specified by matherp, so i could sort out config problems. Reformatting the SD card did solve it. FAT and FAT32 do work. Must have been formatted to something else, but i could swear i did it right the first time. This still does not explain to me why i did not see any data on mosi/miso when accessing the SD card. Had the scope on single shot to trigger on level change. Will re-investigate that later. Maybe i'm already too senile to properly use a scope ... growing old isn't for cowards. You are great !!! Thanks again and regards, Gerald 73 de OE1HGA, Gerald |
You have to watch Windows. It has a tendency to format largish USB stuff to exFAT rather than extended capacity FAT32 - and doesn't give you the option to use FAT or FAT32. That can mess a lot of things up. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
