Local Time 18:19 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite file handling in mmbasic
JLewis
Posted: 07:15pm 15 Jun 2022
Firstly, I just want to say hi!
I'm done with lurking in the forums and just got my PicoMite VGA up and running yesterday. The last time I programmed in BASIC was around 25 years ago with AMOS on the Commodore Amiga, so needless to say, I'm a little rusty!
Whilst feeling waves of nostalgia, I converted a load of cool Sinclair ZX Spectrum artwork into RGB 1-2-1 bitmaps to see how they look on the PicoMite VGA - surprisingly good, I have to say. I decided I'd program a simple slideshow to show them off...
I dumped a ton of bitmaps with descriptive filenames into a folder on the SD card, thinking I'd be able to get the Pico to check the folder and automatically load each image one by one. And that's as far as I have got! Precisely nowhere lol.
I thought that I would be able to scan the entire folder, then store the filenames, for example into an array, rather than explicitly name each one in the program.
I don't know which command to use. Please could somebody point me in the right direction?
Jamie
Ps. I was going to ask about how to achieve indexed colours yesterday but spotted a nice example in somebody's Mandelbrot demo
Posted: 08:14pm 15 Jun 2022
Hi Jamie,
Welcome onboard.
Sounds like you want the DIR$() function.
Edited 2022-06-16 06:14 by thwill
twofingers
Posted: 08:58pm 15 Jun 2022
Need more help?
This (or something similar) should do the trick, a simple example:
CONST MAXFILES=100
DIM f$(MAXFILES) ' each string takes 255 Bytes!
DIM i as integer
 i=1
 f$(i) = LCase$(Dir$("*.*", FILE))
 Do While f$(i) <> "" And i<MAXFILES
   i=i+1
   f$(i) = LCase$(Dir$())
   'PRINT f$(i)
 ' You can add a string sort if you want
Best regards
Michael
JLewis
Posted: 08:49am 16 Jun 2022
Oops! Feel a bit silly now. I completely missed the DIR$ function
Thanks for the heads up guys
