Forum Index : Microcontroller and PC projects : Programming Challenge - Compressing a Masterpiece
I pondered earlier if I should offer some hints and techniques I've used for compressing a program. I've decided to do just that here. Perhaps it will be of interest to some. As an aside, I will point out that, in my opinion, contests like this do NOT encourage good program style. A heavily compressed program becomes a largely incomprehensible blob of characters. Yes, the MMBasic challenge rewards points for legibility, but my personal goal is to get as close to zero in that category as possible. Instead, I want to jam as much in there as possible for maximum wow factor. (Also, my preference is to write code using a text editor on a windoze box. Notepad++ works well for me, and includes extra features such as character and word counting, advanced search and replace and other useful tools. Another useful setting is terminating lines with a single [CR] character instead of the common [CR][LF]. This saves as many characters as there are lines in your program.) ============= I see a few avenues for code compaction: 1) Remove unnecessary characters - this has a few stages. A: all unnecessary white space gone B: all names squashed to 1 character, 2 if alphabet gets fully used. C: combine repeated statements and initialize when defined. D: change longer identifiers to something shorter ie, use 800 instead MM.HRES if useful, and if 800 appears many times, assign it to a variable, say, e=800. This turns MM.HRES into a single character. Program maintenance goes out the window, but that's the price you pay. E: comments gone - yikes! 2) Remove duplicated code Turn repeated code into subroutines so it only appears once. If code sections are almost the same, use double subroutines. Also, move single use subroutines in line. 3) Improve data storage with algorithm changes. Although not applied to the above bouncing ball program, a good possibility involves the drawing of the steps. The data statements for each step appear in lines 25 to 80 (859 characters worth,) giving the 4 corners of each step. However, each step is exactly the same size. So instead, the step location data, lines 187 to 200, could be used to draw a step at each required location. 4) Use subtle MMBasic quirks to trim a few more characters. This one requires experimentation. For example, changing FUNCTIONs to SUBroutines can save a bunch of space. Variables can be returned by reference if used carefully, with 9 characters saved between FUNCTION D(x,y):D=x+y:END FUNCTION compared to SUB D r,x,y:r=x+y:END SUB (Watch out for variable type, though.) So, consider the program that appears at the bottom, written for the CMM2. It's some 4722 characters long over 242 lines. It shrinks as follows after the first few steps above: 1A) - 4336 characters, 216 lines 1B) - 4065 characters, 216 lines 1C) - 3347 characters, 113 lines - combining DATA statements 1D) - not done, however example use g=rgb(lightgrey) 1E) - 2301 characters, 91 lines 2) - 1904 characters, 70 lines - change read data loops to subroutine The resulting programs at these stages is contained in this zip file. As you can see, the program shortens dramatically, but legibility and maintainability pretty much vanish out the window. I can't say for sure as I didn't finish the program before compression started, but my "Stellar Battle in the 7 Green Hills Zone" entry could have been approaching the 20,000 character size. Some serious squashing was called for and there has since been even more so that an onscreen title might yet be possible. 'autosave "test01.bas" ' Follow the Bouncing Ball ' It's a long way to the bottom. Will the ball every get there? ' ' by Vegipete, June 2022 option default integer dim xp(20),yp(20) xoffset = 100 ' shift the image towards center - bottom of screen yoffset = 200 ' Create the ball on page 2 page write 2 : cls for i = 0 to 5 circle 100-1.5*i,100-2*i,34-3*i,1,1,rgb(0,32*(i+2),0),rgb(0,32*(i+2),0) next i ' Put ball image into a BLIT slot blit read 1,65,65,70,70 ' Draw the staircase on page 2 cls ' steps, counterclockwise starting a farthest (highest on screen) data 391, 68 ' 1 data 454, 37 data 391, 6 data 328, 37 data 328, 86 ' 2 data 391, 55 data 328, 24 data 265, 55 data 265,104 ' 3 data 328, 73 data 265, 42 data 202, 73 data 202,122 ' 4 data 265, 91 data 202, 60 data 139, 91 data 139,140 ' 5 data 202,109 data 139, 78 data 76,109 data 76,158 ' 6 data 139,127 data 76, 96 data 13,127 data 139,176 ' 7 data 202,145 data 139,114 data 76,145 data 202,194 ' 8 data 265,163 data 202,132 data 139,163 data 265,212 ' 9 data 328,181 data 265,150 data 202,181 data 328,230 ' 10 data 391,199 data 328,168 data 265,199 data 391,248 ' 11 data 454,217 data 391,186 data 328,217 data 454,203 ' 12 data 517,172 data 454,141 data 391,172 data 517,158 ' 13 data 580,127 data 517, 96 data 454,127 data 454,113 ' 14 data 517, 82 data 454, 51 data 391, 82 ' read each step and draw it in visibility order for j = 1 to 14 for i = 0 to 3 read xp(i),yp(i) next i math add xp(),xoffset,xp() math add yp(),yoffset,yp() polygon 4,xp(),yp(),,0 next j ' Draw the walls under the steps ' outer left face data 13,176 data 13,127 ' +31 data 76,158 ' -13 data 76,145 ' +31 data 139,176 ' -13 data 139,163 ' +31 data 202,194 ' -13 data 202,181 ' +31 data 265,212 ' -13 data 265,199 ' +31 data 328,230 ' -13 data 328,217 ' +31 data 391,248 ' -13 data 391,365 for i = 0 to 13 read xp(i),yp(i) next i math add xp(),xoffset,xp() math add yp(),yoffset,yp() polygon 14,xp(),yp(),,rgb(lightgrey) ' outer right face data 391,365 data 391,248 data 454,217 data 454,203 data 517,172 data 517,158 data 580,127 data 580,271 for i = 0 to 7 read xp(i),yp(i) next i math add xp(),xoffset,xp() math add yp(),yoffset,yp() polygon 8,xp(),yp(),,rgb(grey) ' inner left face data 454, 37 data 391, 68 data 391, 55 data 328, 86 data 328, 73 data 265,104 data 265, 91 data 202,122 data 202,109 data 165,127 data 188,138 data 202,132 data 251,156 data 265,150 data 314,174 data 328,168 data 377,192 data 391,186 data 391, 82 data 454, 51 for i = 0 to 19 read xp(i),yp(i) next i math add xp(),xoffset,xp() math add yp(),yoffset,yp() polygon 20,xp(),yp(),,rgb(grey) ' face of last step data 454,113 data 517, 82 data 517, 96 data 454,127 for i = 0 to 3 read xp(i),yp(i) next i math add xp(),xoffset,xp() math add yp(),yoffset,yp() polygon 4,xp(),yp(),,rgb(grey) ' inner right wall pixel fill 444+xoffset,113+yoffset,rgb(lightgrey) ' face of 12th step pixel fill 444+xoffset,203+yoffset,rgb(lightgrey) ' step location - where the ball will bonce ' bottom center corner on screen data 391, 68 ' 1 data 328, 86 ' 2 data 265,104 ' 3 data 202,122 ' 4 data 139,140 ' 5 data 76,158 ' 6 data 139,176 ' 7 data 202,194 ' 8 data 265,212 ' 9 data 328,230 ' 10 data 391,248 ' 11 data 454,203 ' 12 data 517,158 ' 13 data 454,113 ' 14 for i = 0 to 13 read xp(i),yp(i) ' read the location of each step next i math add xp(),xoffset-40,xp() math add yp(),yoffset-96,yp() thisstep = 13 ' start the ball on 'last' step xstart = xp(thisstep) ystart = yp(thisstep) thisstep = thisstep - 1 xend = xp(thisstep) yend = yp(thisstep) page write 1 ' animate the ball do ' loop from step to step xrange = xend - xstart ' calculate ball base position from this step to the next yrange = yend - ystart xmid = (xend + xstart) / 2 ' find middle for i = xstart to xend step sgn(xrange) ' move x postion from start to end ' y position is somewhere along path, elevated with a parabolic arc DrawBall i,ystart + yrange * (i - xstart) / xrange - 171 + (i - xmid) ^ 2 / 6 next i ' finished this hop so figure out end points of next hop xstart = xend ystart = yend thisstep = thisstep - 1 ' advance to next step, wrap if required if thisstep < 0 then thisstep = 13 xend = xp(thisstep) yend = yp(thisstep) loop ' Redraw entire image with ball at requested location sub DrawBall x,y cls page copy 2,1 blit write 1,x,y,4 page copy 1,0,B end sub Visit Vegipete's *Mite Library for cool programs. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6118 |
Hi Vegipete, Thanks for sharing. This will be of interest to people that are still crunching their contribution for the programming challenge.... And I learned some things also... Volhout PicomiteVGA PETSCII ROBOTS |
| Mindwarp Newbie Joined: 13/02/2021 Location: CanadaPosts: 29 |
That's a great guide, thanks! |
