Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICO: Serial CSUB's?
Posted: 07:01am 04 Jul 2022
Hello all.
Do any CSUB's exist for the PicoMite, that bitbang serial?
I'm looking for the equivalent of the SerialTx and SerialRx Cfunctions for the standard MM series of chips.
I often need MORE then two COM ports, and this is a bit of a brickwall for me at the moment with the PICO - only two COM ports.
I'm grateful for the two that DO exist, but has anyone - Peter? - done serial TX and RX CSUB's for the Pico module?
The TX one is the one I use the most.
Posted: 10:44am 04 Jul 2022
Try this experimental version on a PicoMite (not VGA)
PicoMite.zip
BITBANG SERIALTX pinno, baudrate, ostring$
BITBANG SERIALRX pinno, baudrate, istring$, timeout_in_ms, status% [,nbr] [,terminators$]
e.g.
BITBANG SERIALTX 4, 115200, "Hello world"
BITBANG SERIALRX 5, 115200, a$, 10000, s%, ,chr$(10)
status% returns:
-1 = timeout (NB: use len(s$) to see number received)
2 = number of characters requested satisfied
3 = terminating character satisfied
Edited 2022-07-05 01:38 by matherp
Posted: 11:38pm 04 Jul 2022
Wow - thank you.
I have jobs to do today, but I will check this out and report back later tonight.
EDIT: The serialtx one seems to work perfectly.
Have tested a few baudrates up to 115k2, all of which are working fine.  Not sure if there is an upper limit to the baudrate?
I will have a play with the serialrx one now, and will post back with results.
EDIT: Serialrx also works beautifully.
Any chance this can be added to the standard firmware and also the VGA version Peter?
Edited 2022-07-05 15:04 by Grogster
Posted: 06:26am 05 Jul 2022
+1
Posted: 10:51am 05 Jul 2022
These are CSubs so they don't need to be "added to the standard firmware", you can just include them in your program.
I can add them to the PicoMite download.
Posted: 11:07am 05 Jul 2022
@Geoff,
Unless I am mistaken, the CSUB's are already part of beta #14. Peter is faster than lightning...
Flash....
Posted: 11:14am 05 Jul 2022
They actually needed quite a lot of work as they depend on tight timing and fast I/O so the CSUBs wouldn't have worked and it was easier to incorporate them into the firmware
Posted: 06:09am 06 Jul 2022
Agah, my mistake.
