Local Time 12:40 01 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : bit swap in byte
twofingers
Posted: 06:28pm 27 Jul 2022
  matherp said  Just do it on each byte in turn and then swap the bytes end to end
Again: your solution is elegant.
I think we will lost the speed advantage if we do the operation 8 times.
8 * 15us would be 120us (or more) vs. 30us for the CSub solution.
Kind regards
Michael
EDIT:
Anyway a good solution for Gerald!
Edited 2022-07-28 04:30 by twofingers
ville56
Posted: 06:56pm 27 Jul 2022
indeed it is refreshing for my mind to see all the different solutions. It leads me away from my old and small paths of thinking for this particular problem. This forum is really world class with all its potential.
@twofingers: thanks for the cookbook to csub :-), i really appreciate it. Have to dive into it deeper, but at the moment i have to spend some time on servicing my motorbike for my annual statutorial inspection.
Regards and thanks,
Gerald
73 de OE1HGA, Gerald
twofingers
Posted: 06:58pm 27 Jul 2022
@Gerald
Viel Glück beim TÜV!
ville56
Posted: 07:45pm 27 Jul 2022
Danke!
twofingers
Posted: 11:43am 28 Jul 2022
Just to complete this topic. A version for 8-bits reversing:
8Bitorderreverse.zip
On a 378MHz PicoMite reversing the bit order for a Byte takes 12us.
Michael
edit:
Just to clarify: I think Peter's solution is the better one.
Edited 2022-07-28 22:24 by twofingers
toml_12953
Posted: 03:05pm 28 Jul 2022
Here's one way:
10 INPUT "Enter a number:",n:print
20 h$=right$("0000"+hex$(n),4)
30 PRINT h$
40 h$=right$(h$,2)+left$(h$,2)
50 nr=val("&h"+h$)
60 PRINT h$
70 PRINT nr
© JAQ Software 2025
