Forum Index : Electronics : PS2 Mouse on original colour maximite
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 55 |
Dear Readers, I know you can use the PS2 mouse on the Original Colour Maximite. Which Pins on the 26 pin connector and a test program Kind Regards, RicM |
| wiseguy Guru Joined: 21/06/2018 Location: AustraliaPosts: 1296 |
Ric I assume you meant to post this under the other "Microcontrollers and PCs" instead of the "Electronics" ? If at first you dont succeed, I suggest you avoid sky diving.... Cheers Mike |
And read the manual. Look under the "CONTROLLER MOUSE OPEN" command VK7JH MMedit |
