Forum Index : Microcontroller and PC projects : dim var as byte
Page 2 of 16 | |||||
Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 5732 |
Yes - you can stuff arrays at the DIM statement. DIM a(4)=(0,1,2,3,4) will work. DIM a(4) a=(0,1,2,3,4) will not work as a() and a are different variables but have the same name. You'll get an error. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 3659 |
The manual looks correct - but your two lines don't do what it says. John |
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 1647 |
8 predefined in mmedit not 16 |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8591 |
It isn't |
TassyJim Guru Joined: 07/08/2011 Location: AustraliaPosts: 5907 |
The help file in MMEdit that mentions 8 predefined colours also states that the 8 colours are for the CMM version 1 - 10+ years old. Later versions of MMBasic have more predefined colours. Different devices can display a different number of colours at the same time. In many cases you can use colours other than the defined colours by using RGB to specify the 3 colour values. The help files in MMEdit are trying to cover all versions of MMBasic for an ever increasing number of different devices. I haven't kept up with it. I will never keep up with it, especially on an old version of MMEdit. Please refer to the manuals for the device you are using (and start with some simple code snippets until you understand the basics). It will make your life much easier. Jim PS The reason BYTE appeared as a keyword is because it is used in the PEEK and POKE commands. VK7JH MMedit  MMBasic Help |
lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3016 |
Why not try these things in MMBasic for Windows, if you don't have a PicoMite handy. But as said multiple times, MMBasic doesn't support multi-line statements. You can do this: > new > option list OPTION CPUSPEED (KHz) 378000 OPTION DISPLAY 70, 240 > dim integer b=rgb(black),y=rgb(yellow),c=rgb(cyan),w=rgb(white),l=rgb(blue),r=rgb(red),m=rgb(magenta) > dim integer i,cannon(120) > dim integer x(60)=(b,b,b,b,b,w,w,b,b,b,b,b,b,b,b,b,y,c,c,y,b,b,b,b,b,b,b,y,c,w,w,c,y,b,b,b,b,b,b,y,c,c,c,c,y,b,b,b,b,b,y,y,c,w,w,c,y,y,b,b,b) > dim integer z(58)=(b,y,c,c,c,c,c,c,y,b,b,b,y,l,l,l,r,r,l,l,l,y,b,y,y,l,l,l,r,r,l,l,l,y,y,b,b,y,r,r,r,r,r,r,y,b,b,b,b,b,y,m,m,m,m,y,b,b,b) > for i=0 to 60: cannon(i)=x(i): next > for i=0 to 58: cannon(i+61)=z(i): next It's MODE 16 that gets you 240 characters per line. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Thanks. This looks like it will work. I got to sort running it on rpi pico from mmedit.. copy to teraterm?? so much to learn. If no multiline then dim word sprite1(256)=(wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh}+ (bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk)+ etc. ?? CONST BLACK=bk const white=wh const blue=bl const green=gr const cyan=cy const red=re const magenta=ma const yellow=ye const brown=br Start: Randomize dim word sprite1(256)=(wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk bk,bk,bl,re,re,re,bl,bk,bk,bl,re,re,re,bl,bk,bk bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk) ' dim word sprite2(256)=(bl,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,bl bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk bk,bk,bl,wh,wh,re,bl,bk,bk,bl,re,wh,wh,bl,bk,bk bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk bk,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,bk bk,bk,bk,bk,bk,ye,ye,bk,bk,ye,ye,bk,bk,bk,bk,bk bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk bk,bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk,bk bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk bk,bk,bk,ye,ye,bk,bk,bk,bk,bk,bk,ye,ye,bk,bk,bk bk,bk,bk,bk,ye,ye,bk,bk,bk,bk,ye,ye,bk,bk,bk,bk bk,bk,bk,bk,bk,ye,bk,bk,bk,bk,ye,bk,bk,bk,bk,bk bk,bk,bk,bk,bk,bk,ye,bk,bk,ye,bk,bk,bk,bk,bk,bk) ' dim word cannon(120)=(bk,bk,bk,bk,bk,wh,wh,bk,bk,bk,bk,bk, bk,bk,bk,bk,ye,cy,cy,ye,bk,bk,bk,bk, bk,bk,bk,ye,cy,wh,wh,cy,ye,bk,bk,bk, bk,bk,bk,ye,cy,cy,cy,cy,ye,bk,bk,bk, bk,bk,ye,ye,cy,wh,wh,cy,ye,ye,bk,bk, bk,bk,ye,cy,cy,cy,cy,cy,cy,ye,bk,bk, bk,ye,bl,bl,bl,re,re,bl,bl,bl,ye,bk, ye,ye,bl,bl,bl,re,re,bl,bl,bl,ye,ye, bk,bk,ye,re,re,re,re,re,re,ye,bk,bk, bk,bk,bk,ye,fu,fu,fu,fu,ye,bk,bk,bk) ' dim word missile(16)=(wh,wh re,re ye,ye wh,wh wh,wh ye,ye re,re wh,wh) |
No multi-line at all. No way to do it. You simply have to work out another way to achieve what you want. When I'm working on code and I'm not really sure of what I am doing, I rarely write more than a half-dozen lines without trying it on a real 'Mite. That's the best way to figure out what you can and can not do. ~ Edited 2022-08-03 09:22 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
stanleyella, Commands cannot extend over more than one line. No matter how many different ways you present it, IT WILL NOT WORK. Can I please suggest that you get the Picomite working with MMEdit first and start with small examples as lizby suggested. Start your program with: OPTION BASE 0 ' 0 based arrays OPTION DEFAULT NONE ' Don't assume a type for variables OPTION EXPLICIT ' Force variables to be declared in advance with ' DIM, LOCAL, CONST or STATIC Note that OPTION BASE 0 is the default but it does clarify the situation Also note that because there is a zero entry in the array, you don't have to use it as in Mick's example below. Try Mick's example: DIM INTEGER a(5), b(3), c(4) RESTORE first for i-1 to 5 READ a(i) next RESTORE third for i=1 to 4 read c(i) next RESTORE second for i=1 to 3 READ b(i) next first: DATA 10,20,30,40,50 second: DATA 100,200,300 third: DATA 101,102,103,104 You don't have to use the RESTORE command if you are reading the data sequentially. The data pointer will stay ready to read the next piece of date so the following should also work. DIM INTEGER a(5), b(3), c(4) ' first for i-1 to 5 READ a(i) next ' second for i=1 to 3 READ b(i) next ' third for i=1 to 4 read c(i) next first: DATA 10,20,30,40,50 second: DATA 100,200,300 third: DATA 101,102,103,104 Get this working and build your program up from there. Bill Keep safe. Live long and prosper. |
dim word missile(16) You have just created a variable called word and an array called Missile() Because you didn't specify a 'type' they will both be floating point. Not what you are after. Because it's not the first time you created a variable called 'word' the interpreter will not be happy. Read the manual about DIM CONST BLACK=bk const white=wh const blue=bl const green=gr const cyan=cy I think what you are trying to do is create constants for the colours. The code to do that looks like: CONST bk = RGB(BLack) etc If your colour is not one of the predefined ones, use RGB(rrr, ggg, bbb) The predefined colours for the picomite (Not picomiteVGA) are: WHITE RGB(255, 255, 255) YELLOW RGB(255, 255, 0) LILAC RGB(255, 128, 255) BROWN RGB(255, 128, 0) FUCHSIA RGB(255, 64, 255) RUST RGB(255, 64, 0) MAGENTA RGB(255, 0, 255) RED RGB(255, 0, 0) CYAN RGB(0, 255, 255) GREEN RGB(0, 255, 0) CERULEAN RGB(0, 128, 255) MIDGREEN RGB(0, 128, 0) COBALT RGB(0, 64, 255) MYRTLE RGB(0, 64, 0) BLUE RGB(0, 0, 255) BLACK RGB(0, 0, 0) BROWN RGB(255, 128, 0) GRAY RGB(128, 128, 128) LITEGRAY RGB(210, 210, 210) ORANGE RGB(255, 165, 0) PINK RGB(255, 160, 171) GOLD RGB(255, 215, 0) SALMON RGB(250, 128, 114) BEIGE RGB(245, 245, 220) Edited 2022-08-03 12:45 by TassyJim VK7JH MMedit  MMBasic Help |
Download this: https://geoffg.net/Downloads/Maximite/Programming_with_the_Colour_Maximite_2.pdf It is written for the CMM2 but most is directly compatible with the picomite. VK7JH MMedit  MMBasic Help |
Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 903 |
how abaout a string to store the sprite data? so you use one byte per pixel. From the example Dim Col%(15) Restore colors For f%=1 To 15:Read Col%(f%):Next f% MODE 2 '---- CLS For y%=0 To 15 Read line$ For x%=1 To Len(line$) Pixel x%-1,y%, Col%(Val("&H"+Mid$(line$,x%,1))) Next x% Next y% For y%=0 To 15 Read line$ For x%=1 To Len(line$) Pixel x%+15,y%,Col%(Val("&H"+Mid$(line$,x%,1))) Next x% Next y% For y%=0 To 9 Read line$ For x%=1 To Len(line$) Pixel x%+31,y%,Col%(Val("&H"+Mid$(line$,x%,1))) Next x% Next y% For y%=0 To 7 Read line$ For x%=1 To Len(line$) Pixel x%+47,y%,Col%(Val("&H"+Mid$(line$,x%,1))) Next x% Next y% ' here you can read it with the BLIT/Sprite read Command Print @(0,64); colors: '--Colorscheme accordung to matherp Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED) Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE) Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN),RGB(RUST) Data RGB(FUCHSIA),RGB(BROWN),RGB(LILAC) spriteData1: Data "7111100000011117" Data "0144411001144410" Data "0014441001444100" Data "0001471001741000" Data "0000171001710000" Data "0000011001100000" Data "0000000000000000" Data "0000666006660000" Data "0006000000006000" Data "0660000000000660" Data "0600000000000060" Data "6000000000000016" Data "6000000000000006" Data "6000000000000006" Data "0600000000000060" Data "0060000000000600" spriteData2: Data "1111100000011111" Data "0144411001144410" Data "0017741001477100" Data "0001471001741000" Data "0000171001710000" Data "0000011001100000" Data "0000000660000000" Data "0000066006600000" Data "0000660000660000" Data "0000600000060000" Data "0006000000006000" Data "0060000000000600" Data "0006600000066000" Data "0000660000660000" Data "0000060000600000" Data "0000006006000000" cannonData: Data "000007700000" Data "000063360000" Data "000637736000" Data "000633336000" Data "006637736600" Data "006333333600" Data "061114411160" Data "661114411166" Data "006444444600" Data "0006DDDD6000" missileData: Data "77" Data "44" Data "66" Data "77" Data "77" Data "66" Data "44" Data "77" Edited 2022-08-03 16:10 by Martin H. 'no comment |
toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 326 |
No, it's longer than one screen line so it won't work. |
but wait, there is more with a little "Compression" of repeating pixels you can save some more Bytes Dim Col%(15) Restore colors For f%=1 To 15:Read Col%(f%):Next f% MODE 2 '---- CLS For y%=0 To 15 Read ln$:Ln$=expand$(ln$) For x%=1 To Len(ln$) Pixel x%-1,y%, Col%(Val("&H"+Mid$(ln$,x%,1))) Next x% Next y% For y%=0 To 15 Read ln$:Ln$=expand$(ln$) For x%=1 To Len(ln$) Pixel x%+15,y%,Col%(Val("&H"+Mid$(ln$,x%,1))) Next x% Next y% For y%=0 To 9 Read ln$:Ln$=expand$(ln$) For x%=1 To Len(ln$) Pixel x%+32,y%,Col%(Val("&H"+Mid$(ln$,x%,1))) Next x% Next y% For y%=0 To 7 Read ln$:Ln$=expand$(ln$) For x%=1 To Len(ln$) Pixel x%+48,y%,Col%(Val("&H"+Mid$(ln$,x%,1))) Next x% Next y% ' From here you can read them with the "BLIT/Sprite read" Command Print @(0,64); '------------------------------------ 'simple Compressien of repeating Pixels: 'if a Pixel repeats more than two times, Colors replaced from '0123456789ABCDEF 'to 'GHIJKLMNOPQRSTUV 'followed by the number (single Hex value) of repeats-1 ' 'for example "GF" is a row of 16 Pixels in Black/Transparent (just 2 Bytes) 'or "T3" a row of 4 Pixels in "Fuchsia" ' Function expand$(pxl$) Local n%,nmb%,tmp$,co$ For n%=1 To Len(pxl$) If Asc(Mid$(pxl$,n%,1))< 71 Then tmp$=tmp$+Mid$(pxl$,n%,1) Else co$=Hex$(Asc(Mid$(pxl$,n%,1))-71) Inc n% nmb%=Val("&H"+Mid$(ln$,n%,1)) tmp$=tmp$+String$(nmb%+1,co$) EndIf Next n% expand$=tmp$ End Function colors: '--Colorscheme accordung to matherp Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED) Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE),RGB(MYRTLE) Data RGB(COBALT) ,RGB(MIDGREEN),RGB(CERULEAN),RGB(RUST) Data RGB(FUCHSIA),RGB(BROWN),RGB(LILAC) spriteData1: Data "7H3G5H37" Data "01K2110011K210" Data "001K21001K2100" Data "G21471001741G2" Data "G317100171G3" Data "G4110011G4" Data "GF" Data "G3M200M2G3" Data "G26G76G2" Data "066G9660" Data "06GB60" Data "6GC16" Data "6GD6" Data "6GD6" Data "06GB60" Data "006G9600" spriteData2: Data "H4G5H4" Data "01K2110011K210" Data "0017741001477100" Data "G21471001741G2" Data "G317100171G3" Data "G4110011G4" Data "G6M2G6" Data "G4660066G4" Data "G366G366G3" Data "G36G56G3" Data "G26G76G2" Data "006G9600" Data "G266G566G2" Data "G366G366G3" Data "G46G36G4" Data "G56006G5" cannonData: Data "G477G4" Data "G36336G3" Data "G2637736G2" Data "G26I36G2" Data "006637736600" Data "006I5600" Data "06H244H260" Data "66H244H266" Data "006K5600" Data "G26T36G2" missileData: Data "77" Data "44" Data "66" Data "77" Data "77" Data "66" Data "44" Data "77" it reads the data as usual as long as the Value is 0 to F; but but because we use a string, we can also use other values to use them as a special Character. In the example, 0123456789ABCDEF will get to GHIJKLMNOPQRSTUV to mark, that there is a compressed Block, the length -1 (as we dont have Pixels with a lenghth of 0) is the hexvalue of the next Character in the string. Compressing the data is just a search and replace process in the Text editor so replace 0000000000000000 with GF 000000000000000 with GE ... 000 with G2 and so on. Edited 2022-08-03 19:26 by Martin H. 'no comment |
Here's another way to do it: dim integer i,cannon(120) dim string ch,s="bbbbbwwbbbbbbbbbyccybbbbbbbycwwcybbbbbbyccccybbbbbyycwwcyybbbbyccccccybbbylllrrlllybyylllrrlllyybbyrrrrrrybbbbbymmmmybbb" for i=1 to 120 ch=mid$(s,i,1) select case s case "b": cannon(i-1)=rgb(black) case "y": cannon(i-1)=rgb(yellow) case "c": cannon(i-1)=rgb(cyan) case "w": cannon(i-1)=rgb(white) case "l": cannon(i-1)=rgb(blue) case "r": cannon(i-1)=rgb(red) case "m": cannon(i-1)=rgb(magenta) case "g": cannon(i-1)=rgb(green) end select next i With TeraTerm connected to your Picomite, you can select and copy that code, in TeraTerm press F10 (AUTOSAVE), paste with either Ctrl-V or maybe Alt-V, Ctrl-Z to end, then save the file. (Note: that "DIM string ch,s=" etc. is all one line.) Some people like MMEdit; others like to use their preferred editor, like Notepad++, and move code to the 'mite using the F10 and paste method. ~ Edited 2022-08-03 20:56 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on fruitoftheshed |
Thank you all for advice, I have learnt a lot. I do try to sort code myself and not bother the forum but switching from one basic to another there's a learning curve. I am only bothering with mmbasic on rpi pico RP2040 as I'm impressed with it using ili9341. Much faster than compiled 8bit pic or even lgt380 which is 32MHz (Mega328p is 16MHz) using same display. It has inbuilt display functions like a Nextion display but cheaper and I never liked the Nextion gui. Using sin and cos to draw dials is not fun. |
@Tassyjim-in the manual Arrays can also be initialised when they are declared by adding an equals symbol (=) followed by a bracketed list of values at the end of the declaration. For example: DIM INTEGER nbr(4) = (22, 44, 55, 66, 88) you said- dim word missile(16) You have just created a variable called word and an array called Missile() Because you didn't specify a 'type' they will both be floating point. Not what you are after. it was dim word missile(16)=(wh,wh re,re ye,ye wh,wh wh,wh ye,ye re,re wh,wh) but seems you can only DIM integers,strings and floats. |
Is there any difference to using RP2040 aka rpi-pico to picomite,maximite? Am I a beta tester or is it established on rpi? ps thanks @Jim CONST bk = RGB(BLack) etc Edited 2022-08-04 00:35 by stanleyella |
The PicoMite doesn't have the WORD type. INTEGER is 64-bit signed (accurate up to 19 decimal digits) FLOAT is double precision (starts to lose accuracy after 14 decimal digits) STRING has 256 characters unless you DIM them using LENGTH. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
pwillard Senior Member Joined: 07/06/2022 Location: United StatesPosts: 274 |
PicoMite, Maximite, and PicoMiteVGA will all have some minor differences. Some minor things you can do with a standard PICOMITE are unavailable on PicoiMiteVGA, for example, because it has some VGA-specific things it does instead. Maximite is a larger family of devices and some minor things are different (meaning you might have to tweak some code written for Maximite to get it to run on Picomite) Are you a Beta Tester? I would say "No". |
Page 2 of 16 |
