Forum Index : Microcontroller and PC projects : On the Road again
Martin H.![]() Guru ![]() Joined: 04/06/2022 Location: GermanyPosts: 1220 |
Hi vegipete brilliant ... ![]() sky movement is correct, the only thing is, that the framerate slows a little(but visible in the Bordercolor movement) in the curvature comparing to the straight road... I wouldn't like to waste cpu time with waitstates, rather one could speed up the animation of the borders in the curvature but this is complaining at a high level.. Great Job Mart!n meanwhile I prepare the next sprites Edited 2022-10-23 18:39 by Martin H. 'no comment |
Hi vegipete i ve done some little changes in your code and added the new Protagonist. 'modyfied by vegipete 'AutoSave Dim Col%(15),Xofs%(2,160) Restore colors:For f%=1 To 15:Read Col%(f%):Next f% 'SH% and SW% Displayresolution 'SH%=240:SW%=320 - use MM.HRES and MM.VRES instead dist%=0:Speed%=20 Option Break 4: On Key 3, on_break MODE 2 FRAMEBUFFER create FRAMEBUFFER WRITE F read_sprites 'Precalc the Curve For f%=0 To 159 Xofs%(1,159-f%) = ((160*Exp(f%/50))/20)-8 Xofs%(2,159-f%) = -Xofs%(1,159-f%) Next 'Precalc the Bordercolors Dim Bcol%(8,120) For dst%=0 To 7:For f%=0 To 120 bcol%(dst%,f%)=col%(7-3*((Sin((((120-f%)/40)^3)+dst%*.75))>0)) Next :Next :dst%=0 ' CLS COL%(1): Load image "sky.bmp" HW%=MM.HRes/2:HH%=MM.VRes/2 '-------endless loop ----------------------- ' n is degree of bend n%=0 ' current curvature - start off straight t%=Timer:fcnt=0 restore TrackData Do Read turn%,dur% If dur% < 0 Then t%=(Timer-t%)/1000:Text 1,1,Str$(fcnt/t%,3,3) ' show framerate t%=Timer:fcnt=0 Restore TrackData Continue Do ' restart the track EndIf If n% < turn% Then ' adjust curvature towards left For i = n% To turn% Step Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% ElseIf n% > turn% Then ' more to right For i = n% To turn% Step -Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% Else ' continue along path For i = 1 To dur% 'Step -Speed%/dur% DrawTrack n%:do_car -Sgn(n%):Mov_sky -Sgn(n%):FRAMEBUFFER COPY F,N:Inc fcnt Next EndIf Loop '------------------------------ 'b1x% left x position of the left Border 'b2x% right x position of the left Border and left x position of the street 'b3x% right x position of the street and left x position of the right Border 'b4x% right x position of the right Border 'BB% Border broad 'bc% Border Color (red or white) calculated over Sinus Function 'HH% Half Screen y-Res HW% Half Screen x-Res 'xofs%() Pre calculated Curve over Exponetial function 'ofsx% how much has the Curve to be bended Sub DrawTrack curv Box 0,hh%+2,MM.HRes,hh%-2,,COL%(2),COL%(2) For F%=2 To HH% bc%=bcol%(dst%,f%):ofs%=xofs%(2,f%)*curv/100:y%=hh%+f%:BB%=f%/4 b1X%=HW%-F%-bb%+ofs%:b2x%=HW%-F%+ofs% b3x%=HW%-F%+ofs%+2*f%:b4x%=b1x%+(2*bb%+2*f%) Line b1x%,y%,b4x%,y%,,bcol%(dst%,f%) Line b2x%,y%,b3x%,y%,,0 Next Inc dst%:dst%=dst% And 7 End Sub '--- Moves the Sky while driving a curve Sub Mov_sky dir% Local mv1%=1,mv2%=2 If dir%=0 Then Exit Sub ' driving straight so sky doesn't change ' need to adjust time to draw nothing EndIf If dir%>0 Then Sprite read #31,0,28,mv2%,22 Sprite Mv2%,28,0,28,320-mv2%,22 Sprite write #31,320-mv2%,28 Sprite read #31,0,50,mv2%,22 Sprite Mv1%,50,0,50,320-mv1%,22 Sprite write #31,320-mv1%,50 Sprite read #30,0,102,mv2%,10 Sprite Mv2%,102,0,102,320-mv2%,10 Sprite write #30,320-mv2%,102 Else Sprite read #31,320-mv2%,28,mv2%,22 Sprite 0,28,mv2%,28,320-mv2%,22 Sprite write #31,0,28 Sprite read #31,320-mv2%,50,mv2%,22 Sprite 0,50,mv1%,50,320-mv1%,22 Sprite write #31,0-mv1%,50 Sprite read #30,320-mv2%,102,mv2%,10 Sprite 0,102,mv2%,102,320-mv2%,10 Sprite write #30,0,102 EndIf 'Sprite CLOSE 31 End Sub Sub do_car dir% If dir%=0 Then If dst% Mod 2 Then Sprite write #1,132,200 Else Sprite write #2,132,200 EndIf Else Sprite write #3,132,200,(dir%<0) EndIf End Sub Sub read_Sprites Local nr%,p%,n%,byt$,m$ '--- Read/Create Sprites Restore car For p%=1 To 31 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$)/2 m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Pixel 56-n%,p%,COL%(Val("&H"+m$)) m$=Mid$(Byt$,Len(Byt$)-(n%-1),1) Pixel n%-1,32+p%,COL%(Val("&H"+m$)) Pixel 56-n%,32+p%,COL%(Val("&H"+m$)) Next Next Sprite read #1,0,0,56,32:Sprite read #2,0,32,56,32 ' Sprite load "Car3.spr",3 Restore car3 For p%=0 To 30 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$) m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Next Next Sprite read #3,0,0,56,30 End Sub Function expand$(pxl$) Local n%,nmb%,tmp$,co$ For n%=1 To Len(pxl$) If Asc(Mid$(pxl$,n%,1))< 71 Then ' asc("G") = 71 tmp$=tmp$+Mid$(pxl$,n%,1) Else ' run length encoded - 1st char is pixel colour+71, 2nd is count-1 co$=Hex$(Asc(Mid$(pxl$,n%,1))-71) Inc n%:nmb%=Val("&H"+Mid$(pxl$,n%,1)):tmp$=tmp$+String$(nmb%+1,co$) EndIf Next expand$=tmp$ End Function Sub on_break Sprite CLOSE all: FRAMEBUFFER CLOSE MODE 1: Option Break 3 End End Sub colors: '--Colorscheme accordung to matherp Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED) Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE) Data RGB(MYRTLE),RGB(COBALT),RGB(MIDGREEN),RGB(CERULEAN) Data RGB(RUST),RGB(FUCHSIA),RGB(BROWN),RGB(LILAC) car: Data "GFGFGFG7","GFGFGFG7","GFG9P3GFG9","GFG8917719GFG8","G8N3GA91J319GAN3G8" Data "G7788087G5EECF11M311FCEEG5780887G7" Data "G678FF00800FDCFC48F11M311F84CFCDFG77G6" Data "G67G5DD4U2C4B107M3701B4CU24DDG2FF07G6","G67G4U6C4B107M3701B4CU6G47G6" Data "G67G3U8AB1U71BAU8G37G6","G67G2U24CU4AAU9AAU4C4U2G27G6" Data "G6700U3KFKBU3007G6","00N5U54OFO94U5N500","07788G6EEKFKBEEG688770" Data "078G9E4OB44OB4EGA70","0700FF0V3001KAEK3EKA1GA70" Data "07GA14HAK3HA4100V30FF0070","07GA14019R255911K311955R291041GA70" Data "07GA5119R2L2911K3119L2R29115G9770","07GA551R3L2911K3119L2R3155G9770" Data "07GAL99V79L9G9770","077G9L99V79L9GA70","077G9551R3L29B8R38B9L2R3155G9770" Data "077G9519R3L29B891198B9L2R3915G9770" Data "07GA919BB9H259B891198B95H29BB919GA70","07GA791BBH49B8R38B9H4BB197GA70" Data "07GA70819H49B8R38B9H491807GA70","07GA7G2H489O9H5007GA70" Data "078G887G4H2GBH2G478G8870","0778G6877GFGB778G68770","00NAGFGDNA00" car3: 'uncompressed by now data "00000000000000000000000000000000000000000000000000000000" data "00000000000000000000000000000000000000000000000000000000" data "00000000000000000000000001111000000000000000000000000000" data "00000000000000000000000011771100000000000000000000000000" data "00000000000000000000000113333110000000000000000000000000" data "0000000000000000000000011366611BBBBB00000000000000000000" data "00000000000000000007778113666116BBB334000000000077777000" data "0000000000000000007FF011B6666611BB3344400000000700000700" data "000000000000000000700011B6666611B3344444E00000700FF00070" data "0000000004440000007000EEEEEEEEEE334444EEEEE555700000B070" data "00000000444444444444EEEEEEEEEEEE44444EEEEEEE45500000B070" data "000000048888888888844444444444444444EEEEEEE444400000B070" data "00777774444444444448888888888884444EEEEEEEE444400000B070" data "07800004888888888844444444444444444E8888800008700000B070" data "78000004444444444444E8888888888444480000000008800000B070" data "70FFF0F4444401111144E444444444444400FFF0F000000800000070" data "7000000044005B5B114444441111111444000000000009B000000700" data "7000000000055B5B114444441195555B44000000000019B077777000" data "700000000055555B114444441195555BBB000000000019B070000000" data "700000000055555BFF4444441195555BBB000000000019B070000000" data "700000000055555BFF44444FFF95555555000000000019B070000000" data "70000000F055555B3FFFFFFFFF95555555000000000019B070000000" data "70000000F0055B5B38BBBF8FFF95555BBB00000000F019B070000000" data "700000000000111938911983F395555BBB00000000F019B070000000" data "70000000000111113891198333951119BB00000000F019B070000000" data "700000000001111138BBBB8333911111B9000000000009B070000000" data "780000000081111138BBB88333911111B90000000000000070000000" data "0780000008791110888BB88333911111178000000000000870000000" data "00777777777000000008888888901110007800000000008700000000" data "00000000000000000000000000000000000777777777777000000000" TrackData: ' encoded track ' first value is amount of curve, negative = right, 100 is just off screen ' second value is duration of segment, negative = end of track, restart Data 0,200 ' straight for a bit Data 50,500 ' start turn to the left Data 50, 50 ' hold turn to the left Data 0,400 ' return to straight Data 0, 30 ' straight for a bit Data -100,1000 ' turn to right Data -200,500 ' turn even sharper to right Data -100,300 ' reduce right turn Data -10,500 ' reduce turn even more Data -10, 25 ' hold gentle right turn Data 200,250 ' turn hard left! Data 0,200 ' return to straight Data 0, 50 ' straight for a bit Data 100,150 ' turn left - chicane Data 0,100 ' return to straight Data 0, 10 ' straight for a bit Data -100,100 ' turn right Data 0,100 ' return to straight Data 0,100 ' straight for a bit Data 40,650 ' bend to the left Data 40, 50 ' hold bend to the left Data 75,250 ' more bend to the left - double apex Data 0,400 ' return to straight Data 0,-200 ' end of track 'no comment |
stanleyella![]() Guru ![]() Joined: 25/06/2022 Location: United KingdomPosts: 2535 |
I like your code but it is really more suited to mmb vga not lcd. It is 7 fps with a 32 pixel high scrolling background. The mmb vga version is a bit too niche for me but a great hobby idea. A touch lcd seems more relevant than a trs80 clone. |
7 FPS is really not very pleasant. On the other hand, I think it's very good that you're so interested in the code, so it would be a shame if you gave up. Some valuable insights are gained by studying foreign program-codes. So even if you can only get it running at 7 fps, you've certainly gained a lot of experience. ![]() btw. I just ordered a ARCELI 2.4" ILI9341 240X320 TFT LCD Display so I will have a look, how to get it to run on non VGA Picomite at the End of the week Edited 2022-10-25 16:29 by Martin H. 'no comment |
Mixtel90![]() Guru ![]() Joined: 05/10/2019 Location: United KingdomPosts: 7858 |
A SSD1963 with parallel interface would be the way to go if you want an LCD display. It's *far* faster than a SPI interface and the fact that it uses a lot of pins isn't terribly important here. There's enough for the keyboard. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
compressing the Sprite Data --- Mart!ns little Toolbox So far I've used a text editor to search and replace repeating parts of the Sprite Data strings with the compressed form. which is quite laborious. Example : find "0000000000000000" replace with "GF" find "000000000000000" replace with "GE" find "00000000000000" replace with "GD" ... find "000" replace with "G2" and that for all 16 colors. You can do something like this 2-3 times, but it's boring and a real punishment. So I thought, the pico can do that much faster and with less effort so let him do the work Function compress$(search$) found=0 For f%=0 To 15 For n%=16 To 3 Step -1 from$=String$(n%,Hex$(f%,1)) zu$=Chr$(71+f%)+Chr$(128+Asc(Hex$(n%-1,1))) 'addition of 128 prevents the results from 'being incorrectly counted in a further search Do search$=replace$(from$,zu$,search$) If found=0 Then Exit Loop Next n% Next f% compress$="" For f%=1 To Len(search$) n%=Asc(Mid$(search$,f%,1)) n%=n%-128*(n%>128):'sub the 128 if needed compress$=compress$+Chr$(n%) Next End Function ' Function replace$(sr$,repl$,sear$) Local n%,tmp$ tmp$=" "+sear$+" " found=Instr(tmp$,sr$) If found=0 Then replace$=sear$:Exit Function tmp$=Left$(tmp$,found-1)+repl$+Right$(tmp$,Len(tmp$)-(found+Len(sr$))+1) replace$=Mid$(tmp$,2,Len(tmp$)-2) End Function there is certainly still something to optimize, but it works. ![]() the following compressed output resulted from the data of the program above These strings as data result in the following lines car3: data "GFGFGFG7","GFGFGFG7","GFG8H3GFGA","GFG7117711GFG9" data "GFG611J311GFG8","GFG6113M211R4GFG3" data "GFG2N28113M2116R2334G9N4G2","GF007FF011BM411BB33K2G77G4700" data "GF007G211BM411B33K4EG4700FFG270","G8K2G57G2U933K3U4L27G4B070" data "G7KBUBK4U6455G4B070","G64OAKF4U6K3G4B070" data "00N4KBOBK3U7K3G4B070","078G34O9KF4EO4G387G4B070" data "78G4KCEO9K38G888G4B070","70V20FK40H444EKC00V20FG58G570" data "7G644005B5B11K5H6K2GA9BG5700","7G955B5B11K5119L3B44G919B0N4G2" data "7G8L4B11K5119L3R2G919B07G6","7G8L4BFFK5119L3R2G919B07G6" data "7G8L4BFFK4V29L6G919B07G6","7G6F0L4B3V89L6G919B07G6" data "7G6F0055B5B38R2F8V29L3R2G7F019B07G6" data "7GAH2938911983F39L3R2G7F019B07G6","7G9H43891198J295H29BBG7F019B07G6" data "7G9H438R38J29H4B9GA9B07G6","78G78H438R288J29H4B9GD7G6" data "078G5879H20O2BB88J29H578GB87G6","00N8G7O690H2G278G987G7","GFGFG2NBG8" in combination with the sprite read and expand routine you can save quite a few kilobytes. happy pixel counting ![]() Cheers Mart!n Edited 2022-10-26 01:47 by Martin H. 'no comment |
Amnesie Guru ![]() Joined: 30/06/2020 Location: GermanyPosts: 637 |
This is cool! I didn't know that one can compress data this way! Much to learn from your code! Greetings Daniel |
Not cheap considering vga displays are usually £5 if not thrown out. Not cheap though https://www.ebay.co.uk/itm/294562294939?hash=item449547ec9b:g:D4UAAOSwWjxhl9a1&amdata=enc%3AAQAHAAAA4ElfrU9%2Bo7%2FfF2pHcZXfsm4J3wvVhqrFZZOkxv0rjv5SLvARa4e7gJGmB8Wd1IcUMYbXlaXfHi786gOwRETS80m172JXANMkXaOng9d02POI6%2BPywIrj%2Bss5cLvRgLdrJ%2FDuW33sdBfuRA4nWQ88tQTscBPZqIoBiu%2BFNn%2B7fXKXyuScly7uCm3tu67rr5ewipCdRaal2WnUfKTwOFoS%2Fo7hImTquUI%2BrESqWZ%2FgGGUY0HdiBENgIUAZk9JwV%2F%2FAF4uxTS8uw0VsyDTl3v0yCp1BeBIydx9EsWbREBOm%2BHGe%7Ctkp%3ABk9SR8ru1_-BYQ There was one Tandy (aka radio shack) shop in Cardiff and it sold a trs80 but no one I knew had one. Maplin outlived Tandy. |
You pays your money, you takes your choice, I'm afraid. If you want a fast display you can't use a SPI interface on the PicoMite. "Ye canna change the laws of physics Jim!" Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
"Ye canna change the laws of physics Jim!" Scotty always called him captain ![]() Nothing stopping me trying the vga version. A bit too niche hobbyist but think it is very impressive, I got loads of vga monitors and 14" tv with vga, so cheap and plenty of keyboards, it is the space for another pc/display/keyboard. I like the way you can make an old pooter for £10. The ili9341 and sd card and touch and graphics work better than anything else I have used. How many people want to use a picomite to code lcd games? |
Probably not many. LCD display games usually means portable, so battery powered. The PicoMite doesn't have a low power mode so that, together with a backlight, tends to clobber batteries. It's a pity really. The LCD display really comes into its own for control systems, where touch control can be really useful and save on a lot of confusing buttons and switches. Power consumption is rarely a problem. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
I never got into hand held games and that applies now with smart phone games. I can see a picomite and vga as a cheap computer setup for a real world application. Same with mmb lcd, it has real uses. People forget for the price a rpipico is same price as an arduino nano and are good for robots, etc. I like @Martins graphics. Plenty to learn. I looked up trs 80 emulator. |
A new Dimension I updated vegipetes modyfied Version with another component, When you Press "o" or "p" the Car stays where it is but Background moves perspectively left or right :-) 'modyfied by vegipete ' Dim Col%(15),Xofs%(160) Restore colors:For f%=1 To 15:Read Col%(f%):Next f% MODE 2:SH%=MM.VRes:SW%=MM.HRes:HW%=SW%/2:HH%=SH%/2 dist%=0:Speed%=20:PPos%=0 Option Break 4: On Key 3, on_break FRAMEBUFFER create:FRAMEBUFFER WRITE F read_sprites 'Precalc the Curve For f%=0 To 159:Xofs%(159-f%)=-((160*Exp(f%/50))/20)-8:Next 'Precalc the Bordercolors Dim Bcol%(8,120) For dst=0 To 7:For f%=0 To 120 bcol%(dst,f%)=col%(7-3*((Sin((((120-f%)/40)^3)+dst*.75))>0)):Next :Next :dst=0:spt=1 CLS COL%(1): Load image "sky.bmp" '-------endless loop ----------------------- ' n is degree of bend n%=0 ' current curvature - start off straight t%=Timer:fcnt=0 Restore TrackData Do Read turn%,dur% If dur% < 0 Then t%=(Timer-t%)/1000:Text 1,1,Str$(fcnt/t%,3,3) ' show framerate t%=Timer:fcnt=0 Restore TrackData Continue Do ' restart the track EndIf If n% < turn% Then ' adjust curvature towards left For i = n% To turn% Step Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% ElseIf n% > turn% Then ' more to right For i = n% To turn% Step -Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% Else ' continue along path For i = 1 To dur% 'Step -Speed%/dur% DrawTrack n%:do_car -Sgn(n%):Mov_sky -Sgn(n%):FRAMEBUFFER COPY F,N:Inc fcnt Next EndIf Loop '------------------------------ 'b1x% left x position of the left Border 'b2x% right x position of the left Border and left x position of the street 'b3x% right x position of the street and left x position of the right Border 'b4x% right x position of the right Border 'BB% Border broad 'bc% Border Color (red or white) calculated over Sinus Function 'HH% Half Screen y-Res HW% Half Screen x-Res 'PDist% Shift relative to Car Position PPos% 'xofs%() Pre calculated Curve over Exponetial function 'ofsx% stregth of the bend Sub DrawTrack curv Box 0,hh%+2,sw%,hh%-2,,COL%(2),COL%(2) For F%=2 To HH% PDist%=PPos%*f%/HH% bc%=bcol%(dst,f%):ofs%=xofs%(f%)*curv/100:y%=hh%+f%:BB%=f%/4 b1X%=HW%-F%-bb%+ofs%:b2x%=Pdist%+HW%-F%+ofs% b3x%=Pdist%+HW%-F%+ofs%+2*f%:b4x%=Pdist%+b1x%+(2*bb%+2*f%):Inc b1x%,PDist% Line b1x%,y%,b4x%,y%,,bcol%(dst,f%):Line b2x%,y%,b3x%,y%,,0 Next Inc dst,spt:dst=dst And 7 End Sub '--- Moves the Sky while driving a curve ' spt adjusts the border speed to draw nothing Sub Mov_sky dir% Local mv1%=1,mv2%=2 If dir%=0 Then spt=1:Exit Sub ' driving straight so sky doesn't change spt=1.4 If dir%>0 Then Sprite read #31,0,28,mv2%,22:Sprite Mv2%,28,0,28,320-mv2%,22 Sprite write #31,320-mv2%,28 Sprite read #31,0,50,mv2%,22:Sprite Mv1%,50,0,50,320-mv1%,22 Sprite write #31,320-mv1%,50 Sprite read #30,0,102,mv2%,10:Sprite Mv2%,102,0,102,320-mv2%,10 Sprite write #30,320-mv2%,102 Else Sprite read #31,320-mv2%,28,mv2%,22:Sprite 0,28,mv2%,28,320-mv2%,22 Sprite write #31,0,28 Sprite read #31,320-mv2%,50,mv2%,22:Sprite 0,50,mv1%,50,320-mv1%,22 Sprite write #31,0-mv1%,50 Sprite read #30,320-mv2%,102,mv2%,10:Sprite 0,102,mv2%,102,320-mv2%,10 Sprite write #30,0,102 EndIf End Sub Sub do_car dir% If dir%=0 Then If dst Mod 2 Then Sprite write #1,132,200,4 Else Sprite write #2,132,200,4 EndIf Else Sprite write #3,132,200,4+(dir%<0) EndIf ' move with "o" and "p" key$=Inkey$ Select Case key$ Case "o" Inc PPos%,8:If PPos%>160 Then PPos%=160 Case "p" Inc PPos%,-8:If PPos%<-160 Then PPos%=-160 End Select End Sub Sub read_Sprites Local nr%,p%,n%,byt$,m$ '--- Read/Create Sprites Restore car For p%=1 To 31 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$)/2 m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Pixel 56-n%,p%,COL%(Val("&H"+m$)) m$=Mid$(Byt$,Len(Byt$)-(n%-1),1) Pixel n%-1,32+p%,COL%(Val("&H"+m$)) Pixel 56-n%,32+p%,COL%(Val("&H"+m$)) Next Next Sprite read #1,0,0,56,32:Sprite read #2,0,32,56,32 CLS :' Sprite load "Car3.spr",3 Restore car3 For p%=0 To 30 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$) m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Next Next Sprite read #3,0,0,56,30 End Sub Function expand$(pxl$) Local n%,nmb%,tmp$,co$ For n%=1 To Len(pxl$) If Asc(Mid$(pxl$,n%,1))< 71 Then ' asc("G") = 71 tmp$=tmp$+Mid$(pxl$,n%,1) Else ' run length encoded - 1st char is pixel colour+71, 2nd is count-1 co$=Hex$(Asc(Mid$(pxl$,n%,1))-71) Inc n%:nmb%=Val("&H"+Mid$(pxl$,n%,1)):tmp$=tmp$+String$(nmb%+1,co$) EndIf Next expand$=tmp$ End Function Sub on_break Sprite CLOSE all: FRAMEBUFFER CLOSE MODE 1: Option Break 3 End End Sub colors: '--Colorscheme accordung to matherp Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED) Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE) Data RGB(MYRTLE),RGB(COBALT),RGB(MIDGREEN),RGB(CERULEAN) Data RGB(RUST),RGB(FUCHSIA),RGB(BROWN),RGB(LILAC) car: Data "GFGFGFG7","GFGFGFG7","GFG9P3GFG9","GFG8917719GFG8","G8N3GA91J319GAN3G8" Data "G7788087G5EECF11M311FCEEG5780887G7" Data "G678FF00800FDCFC48F11M311F84CFCDFG77G6" Data "G67G5DD4U2C4B107M3701B4CU24DDG2FF07G6","G67G4U6C4B107M3701B4CU6G47G6" Data "G67G3U8AB1U71BAU8G37G6","G67G2U24CU4AAU9AAU4C4U2G27G6" Data "G6700U3KFKBU3007G6","00N5U54OFO94U5N500","07788G6EEKFKBEEG688770" Data "078G9E4OB44OB4EGA70","0700FF0V3001KAEK3EKA1GA70" Data "07GA14HAK3HA4100V30FF0070","07GA14019R255911K311955R291041GA70" Data "07GA5119R2L2911K3119L2R29115G9770","07GA551R3L2911K3119L2R3155G9770" Data "07GAL99V79L9G9770","077G9L99V79L9GA70","077G9551R3L29B8R38B9L2R3155G9770" Data "077G9519R3L29B891198B9L2R3915G9770" Data "07GA919BB9H259B891198B95H29BB919GA70","07GA791BBH49B8R38B9H4BB197GA70" Data "07GA70819H49B8R38B9H491807GA70","07GA7G2H489O9H5007GA70" Data "078G887G4H2GBH2G478G8870","0778G6877GFGB778G68770","00NAGFGDNA00" car3: Data "GFGFGFG7","GFGFGFG7","GFG8H3GFGA","GFG7117711GFG9" Data "GFG611J311GFG8","GFG6113M211R4GFG3" Data "GFG2N28113M2116R2334G9N4G2","GF007FF011BM411BB33K2G77G4700" Data "GF007G211BM411B33K4EG4700FFG270","G8K2G57G2U933K3U4L27G4B070" Data "G7KBUBK4U6455G4B070","G64OAKF4U6K3G4B070" Data "00N4KBOBK3U7K3G4B070","078G34O9KF4EO4G387G4B070" Data "78G4KCEO9K38G888G4B070","70V20FK40H444EKC00V20FG58G570" Data "7G644005B5B11K5H6K2GA9BG5700","7G955B5B11K5119L3B44G919B0N4G2" Data "7G8L4B11K5119L3R2G919B07G6","7G8L4BFFK5119L3R2G919B07G6" Data "7G8L4BFFK4V29L6G919B07G6","7G6F0L4B3V89L6G919B07G6" Data "7G6F0055B5B38R2F8V29L3R2G7F019B07G6" Data "7GAH2938911983F39L3R2G7F019B07G6","7G9H43891198J295H29BBG7F019B07G6" Data "7G9H438R38J29H4B9GA9B07G6","78G78H438R288J29H4B9GD7G6" Data "078G5879H20O2BB88J29H578GB87G6","00N8G7O690H2G278G987G7","GFGFG2NBG8" TrackData: ' encoded track ' first value is amount of curve, negative = right, 100 is just off screen ' second value is duration of segment, negative = end of track, restart Data 0,200 ' straight for a bit Data 50,500 ' start turn to the left Data 50, 50 ' hold turn to the left Data 0,400 ' return to straight Data 0, 30 ' straight for a bit Data -100,1000 ' turn to right Data -200,500 ' turn even sharper to right Data -100,300 ' reduce right turn Data -10,500 ' reduce turn even more Data -10, 25 ' hold gentle right turn Data 0, 30 ' straight for a bit Data 200,250 ' turn hard left! Data 0,200 ' return to straight Data 0, 50 ' straight for a bit Data 100,150 ' turn left - chicane Data 0,100 ' return to straight Data 0, 10 ' straight for a bit Data -100,100 ' turn right Data 0,100 ' return to straight Data 0,100 ' straight for a bit Data 40,650 ' bend to the left Data 40, 50 ' hold bend to the left Data 75,250 ' more bend to the left - double apex Data 0,400 ' return to straight Data 0,-200 ' end of track Link to the background Image the Framerate is between 24.5 and 25.5 fps but the Movement is still smooth. The subjective impression of the speed depends more from the speed of the color change of the bars than from the frame rate Edited 2022-10-28 22:02 by Martin H. 'no comment |
Volhout Guru ![]() Joined: 05/03/2018 Location: NetherlandsPosts: 5056 |
Hi Martin, With the increasing detail it becomes more real than ever. May I be so blunt to point at one thing that could be improved ? The road is either straight, or some form of an arc. But with the progress on a straight, the curve should appear in the distance, and come closer, before the road changes to an curve (arc). Maybe this is most obvious when the straight road changes abruptly to a strong curve. I have no clue how to turn the algorytm to make a curve come closer from the distance, but you may be able to work around it by not making abrupt changes from straight to strong curve. By the way, did you notice that you (and vegipete) are turning a proof of concept into an actual game ??? Please continue, I like this !!! Regards, Volhout P.S. what happened to the frog ? Do you want me to debug the NES controller drift on the river ? Or is it stalled, to be picked up later ? PicomiteVGA PETSCII ROBOTS |
At the moment, the curve is precalculated via an exponential function to and bend the straight road more or less as required. I have no idea, right now, how to do it differently, so that the transition would takes place from top to bottom. However, if one designs the track accordingly, it is not noticeable ![]() Hey it is the approach of a Racing game written in Basic on a 4€ Microcontroller. Who would have thought that such a thing would be possible? And whoever wants to turn this PoC into a real Game, feel free to do so. Due to the 3D MonsterMaze idea of stanleyella, I am currently trying to convert a C++ routine into MM Basic to make a raycaster Version of this old Game ![]() 3DSage_Raycaster_v1.c ... also my ILI9341 display arrived yesterday which unfortunately has different names than usual on the connections. So I have to guess how to connect it. https://m.media-amazon.com/images/I/715-XBOQh5L._AC_SX569_.jpg Edited 2022-10-28 23:48 by Martin H. 'no comment |
I think those have come up before, Martin. I don't think they are MMBasic compatible. It looks like a 8-bit parallel display designed for Arduino only to me. Edited 2022-10-29 00:14 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
I like this road idea. It could be shapes following the curve and more outer space "car". More like Nintendo "FireFox". You guys show what can be done. I got to sort the vga version and hope one of my ps2 keyboards is 3.3V compatible. Why not? costs little. cheap hobby. |
ok,if there is actually no way to serially drive the display, Maybee I could Update one of my 3d Printers to color display. They are Arduino controlled and, as far as I know, there are already Marlin extensions for ILI9341 ![]() Edited 2022-10-29 00:58 by Martin H. 'no comment |
Optimizes the hell out of the DrawTrack Algorhythm. ![]() Not really readable anymore (I wouldn't understand it anymore) but, including all features, it now runs with 31.792 FPS at 378000 KHz ![]() 'modyfied by vegipete ' Option explicit Dim Col%(15),Xofs%(160),Bcol%(8,120) As integer Dim f%,n%,sh%,sw%,t%,hh%,hw%,dist%,speed%,ppos%,turn%,dur% As integer Dim bb%,bc%,b1x%,b2x%,b3x%,b4x%,ofs%,PDist%,y% As integer Dim dst,spt,fcnt,i As float Dim mv1%=1,mv2%=2 Restore colors:For f%=1 To 15:Read Col%(f%):Next f% MODE 2:SH%=MM.VRes:SW%=MM.HRes:HW%=SW%/2:HH%=SH%/2 dist%=0:Speed%=20:PPos%=0 Option Break 4: On Key 3, on_break FRAMEBUFFER create:FRAMEBUFFER WRITE F read_sprites 'Precalc the Curve For f%=0 To 159:Xofs%(159-f%)=-((160*Exp(f%/50))/20)-8:Next 'Precalc the Bordercolors For dst=0 To 7:For f%=0 To 120 bcol%(dst,f%)=col%(7-3*((Sin((((120-f%)/40)^3)+dst*.75))>0)):Next :Next :dst=0:spt=1 CLS COL%(1): Load image "sky.bmp" '-------endless loop ----------------------- ' n is degree of bend n%=0 ' current curvature - start off straight t%=Timer:fcnt=0 Restore TrackData Do Read turn%,dur% If dur% < 0 Then t%=(Timer-t%)/1000:Text 1,1,Str$(fcnt/t%,3,3) ' show framerate t%=Timer:fcnt=0 Restore TrackData Continue Do ' restart the track EndIf If n% < turn% Then ' adjust curvature towards left For i = n% To turn% Step Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% ElseIf n% > turn% Then ' more to right For i = n% To turn% Step -Speed%/dur%*100 DrawTrack i:do_car -Sgn(i):Mov_sky -Sgn(i):FRAMEBUFFER COPY F,N:Inc fcnt Next n%=turn% Else ' continue along path For i = 1 To dur% 'Step -Speed%/dur% DrawTrack n%:do_car -Sgn(n%):Mov_sky -Sgn(n%):FRAMEBUFFER COPY F,N:Inc fcnt Next EndIf Loop '------------------------------ 'b1x% left x position of the left Border 'b2x% right x position of the left Border and left x position of the street 'b3x% right x position of the street and left x position of the right Border 'b4x% right x position of the right Border 'BB% Border wight 'bc% Border Color (red or white) calculated over Sinus Function 'HH% Half Screen y-Res HW% Half Screen x-Res 'PDist% Shift relative to Car Position PPos% 'xofs%() Pre calculated Curve over Exponetial function 'ofsx% stregth of the bend '------------------------------ Sub DrawTrack curv Box 0,hh%+2,sw%,hh%-2,,COL%(2),COL%(2) For F%=2 To HH% PDist%=PPos%*f%/HH%:BB%=f%>>2:bc%=bcol%(dst,f%) ofs%=xofs%(f%)*curv/100:y%=hh%+f% b1x%=PDist%+HW%-F%-bb%+ofs%:b2x%=b1x%+BB%:b3x%=b2X%+(f%<<1):b4x%=b3x%+BB% Line b1x%,y%,b4x%,y%,,bc%:Line b2x%,y%,b3x%,y%,,0 Next Inc dst,spt:dst=dst And 7 End Sub '--- Moves the Sky while driving a curve ' spt adjusts the border speed when there is nothing to Move ' mv1% and mv2% are the differed Speeds for the "Paralax Effect" ' Sub Mov_sky dir% If dir%=0 Then spt=1:Exit Sub 'driving straight so sky doesn't change spt=1.4 If dir%>0 Then Sprite read 31,0,28,mv2%,22:Sprite Mv2%,28,0,28,320-mv2%,22 Sprite write 31,320-mv2%,28:Sprite read 31,0,50,mv2%,22 Sprite Mv1%,50,0,50,320-mv1%,22:Sprite write 31,320-mv1%,50 Sprite read 30,0,102,mv2%,10:Sprite Mv2%,102,0,102,320-mv2%,10 Sprite write 30,320-mv2%,102 Else Sprite read 31,320-mv2%,28,mv2%,22:Sprite 0,28,mv2%,28,320-mv2%,22 Sprite write 31,0,28:Sprite read 31,320-mv2%,50,mv2%,22 Sprite 0,50,mv1%,50,320-mv1%,22:Sprite write 31,0-mv1%,50 Sprite read 30,320-mv2%,102,mv2%,10:Sprite 0,102,mv2%,102,320-mv2%,10 Sprite write 30,0,102 EndIf End Sub Sub do_car dir% Local Key$ If dir%=0 Then If dst Mod 2 Then Sprite write #1,132,200,4 Else Sprite write #2,132,200,4 EndIf Else Sprite write #3,132,200,4+(dir%<0) EndIf ' move with "o" and "p" key$=Inkey$ Select Case key$ Case "o" Inc PPos%,8:If PPos%>160 Then PPos%=160 Case "p" Inc PPos%,-8:If PPos%<-160 Then PPos%=-160 End Select End Sub '---- Sub read_Sprites Local nr%,p%,n%,byt$,m$ '--- Read/Create Sprites Restore car For p%=1 To 31 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$)/2 m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Pixel 56-n%,p%,COL%(Val("&H"+m$)) m$=Mid$(Byt$,Len(Byt$)-(n%-1),1) Pixel n%-1,32+p%,COL%(Val("&H"+m$)) Pixel 56-n%,32+p%,COL%(Val("&H"+m$)) Next Next Sprite read #1,0,0,56,32:Sprite read #2,0,32,56,32 CLS :' Sprite load "Car3.spr",3 Restore car3 For p%=0 To 30 Read Byt$:Byt$=expand$(Byt$) For n%=1 To Len(Byt$) m$=Mid$(Byt$,n%,1) Pixel n%-1,p%,COL%(Val("&H"+m$)) Next Next Sprite read #3,0,0,56,30 End Sub Function expand$(pxl$) Local n%,nmb%,tmp$,co$ For n%=1 To Len(pxl$) If Asc(Mid$(pxl$,n%,1))< 71 Then ' asc("G") = 71 tmp$=tmp$+Mid$(pxl$,n%,1) Else ' run length encoded - 1st char is pixel colour+71, 2nd is count-1 co$=Hex$(Asc(Mid$(pxl$,n%,1))-71) Inc n%:nmb%=Val("&H"+Mid$(pxl$,n%,1)):tmp$=tmp$+String$(nmb%+1,co$) EndIf Next expand$=tmp$ End Function Sub on_break Sprite CLOSE all: FRAMEBUFFER CLOSE MODE 1: Option Break 3 End End Sub colors: '--Colorscheme accordung to matherp Data RGB(BLUE),RGB(GREEN),RGB(CYAN),RGB(RED) Data RGB(MAGENTA),RGB(YELLOW),RGB(WHITE) Data RGB(MYRTLE),RGB(COBALT),RGB(MIDGREEN),RGB(CERULEAN) Data RGB(RUST),RGB(FUCHSIA),RGB(BROWN),RGB(LILAC) car: Data "GFGFGFG7","GFGFGFG7","GFG9P3GFG9","GFG8917719GFG8","G8N3GA91J319GAN3G8" Data "G7788087G5EECF11M311FCEEG5780887G7" Data "G678FF00800FDCFC48F11M311F84CFCDFG77G6" Data "G67G5DD4U2C4B107M3701B4CU24DDG2FF07G6","G67G4U6C4B107M3701B4CU6G47G6" Data "G67G3U8AB1U71BAU8G37G6","G67G2U24CU4AAU9AAU4C4U2G27G6" Data "G6700U3KFKBU3007G6","00N5U54OFO94U5N500","07788G6EEKFKBEEG688770" Data "078G9E4OB44OB4EGA70","0700FF0V3001KAEK3EKA1GA70" Data "07GA14HAK3HA4100V30FF0070","07GA14019R255911K311955R291041GA70" Data "07GA5119R2L2911K3119L2R29115G9770","07GA551R3L2911K3119L2R3155G9770" Data "07GAL99V79L9G9770","077G9L99V79L9GA70","077G9551R3L29B8R38B9L2R3155G9770" Data "077G9519R3L29B891198B9L2R3915G9770" Data "07GA919BB9H259B891198B95H29BB919GA70","07GA791BBH49B8R38B9H4BB197GA70" Data "07GA70819H49B8R38B9H491807GA70","07GA7G2H489O9H5007GA70" Data "078G887G4H2GBH2G478G8870","0778G6877GFGB778G68770","00NAGFGDNA00" car3: Data "GFGFGFG7","GFGFGFG7","GFG8H3GFGA","GFG7117711GFG9" Data "GFG611J311GFG8","GFG6113M211R4GFG3" Data "GFG2N28113M2116R2334G9N4G2","GF007FF011BM411BB33K2G77G4700" Data "GF007G211BM411B33K4EG4700FFG270","G8K2G57G2U933K3U4L27G4B070" Data "G7KBUBK4U6455G4B070","G64OAKF4U6K3G4B070" Data "00N4KBOBK3U7K3G4B070","078G34O9KF4EO4G387G4B070" Data "78G4KCEO9K38G888G4B070","70V20FK40H444EKC00V20FG58G570" Data "7G644005B5B11K5H6K2GA9BG5700","7G955B5B11K5119L3B44G919B0N4G2" Data "7G8L4B11K5119L3R2G919B07G6","7G8L4BFFK5119L3R2G919B07G6" Data "7G8L4BFFK4V29L6G919B07G6","7G6F0L4B3V89L6G919B07G6" Data "7G6F0055B5B38R2F8V29L3R2G7F019B07G6" Data "7GAH2938911983F39L3R2G7F019B07G6","7G9H43891198J295H29BBG7F019B07G6" Data "7G9H438R38J29H4B9GA9B07G6","78G78H438R288J29H4B9GD7G6" Data "078G5879H20O2BB88J29H578GB87G6","00N8G7O690H2G278G987G7","GFGFG2NBG8" TrackData: ' encoded track ' first value is amount of curve, negative = right, 100 is just off screen ' second value is duration of segment, negative = end of track, restart Data 0,200 ' straight for a bit Data 50,500 ' start turn to the left Data 50, 50 ' hold turn to the left Data 0,400 ' return to straight Data 0, 30 ' straight for a bit Data -100,1000 ' turn to right Data -200,500 ' turn even sharper to right Data -100,300 ' reduce right turn Data -10,500 ' reduce turn even more Data -10, 25 ' hold gentle right turn Data 0, 30 ' straight for a bit Data 200,250 ' turn hard left! Data 0,200 ' return to straight Data 0, 50 ' straight for a bit Data 100,150 ' turn left - chicane Data 0,100 ' return to straight Data 0, 10 ' straight for a bit Data -100,100 ' turn right Data 0,100 ' return to straight Data 0,100 ' straight for a bit Data 40,650 ' bend to the left Data 40, 50 ' hold bend to the left Data 75,250 ' more bend to the left - double apex Data 0,400 ' return to straight Data 0,-200 ' end of track so, if we say, min. 20FPS is acceptable (with speeded up Borders), we have 1/3 Second (that is the speed of a non overclocked Pico) Headroom for A Game Logic. ![]() Edited 2022-11-05 00:09 by Martin H. 'no comment |
Wauw ! This is really super smooth.... Good work. Running it on RC8 at 252MHz. Volhout PicomiteVGA PETSCII ROBOTS |
