Local Time 15:59 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LOOP won't wait....
Posted: 04:54am 14 Oct 2022
Interesting loopy problem.
Have isolated it down to this bit of code, which if you run, it will NOT wait till the timer is greater then or equal to the delay period.  The loop exits within 2-3ms - it does not wait for 7000ms as I want it to.
MM2 chip, MMBASIC version 5.0501
Y=0
TIMER=0
DELAY=7000
Open "COM2:2400" as #2
Print TIMER,DELAY,LOC(#2)
DO
 If LOC(#2) THEN Y=1
 EXIT DO
LOOP UNTIL TIMER>=DELAY
Print "Hello."
Print Timer,DELAY,LOC(#2)
The code should NOT exit the do loop, if there is nothing in the COM2 buffer, and there isn't.  It is zero before the loop, and zero after the loop, but the loop just exits as though there IS something in there.
The debug print lines show 1     7000     0 at the start, and 4     7000     0 at the end, so the timer is only at 4ms, but the loop is exiting anyway, despite LOC(#2) still being zero.
Can someone please test this code snippet and tell me if they get the same issue.
The problem can be totally solved, if I simply comment out the two lines inside the loop that check if there is anything inside the serial port buffer, but I need to be checking this....
EDIT: Fixed it with a rewrite, but I would still like to know what I was doing wrong in the above.
The fix:
Y=0
TIMER=0
DELAY=7000
DO:LOOP UNTIL TIMER>=DELAY or LOC(#2)
Print "Hello."
Edited 2022-10-14 14:59 by Grogster
Posted: 05:15am 14 Oct 2022
i think the error may be in the two lines:
  If LOC(#2) THEN Y=1
  EXIT DO
they should be either:
  If LOC(#2) THEN Y=1: EXIT DO
or:
  If LOC(#2) THEN
    Y=1
    EXIT DO
  END IF
rob   :-)
Martin H.
Posted: 05:27am 14 Oct 2022
try this
t=Timer
delay=7000
Print Timer,delay
Loop Until Timer >=t+delay
Print "Hello."
(i left out the Com Section)
Reg.
Mart!n
Edited 2022-10-14 15:28 by Martin H.
'no comment
Turbo46
Posted: 05:29am 14 Oct 2022
Yes
DO
If LOC(#2) THEN Y=1
EXIT DO
EXIT DO is not controlled by the IF/THEN it is just the next statement to be executed
EDIT:
If LOC(#2) THEN : Y=1 : EXIT DO : endif
works
Bill
Edited 2022-10-14 15:39 by Turbo46
Posted: 05:43am 14 Oct 2022
  Turbo46 said  Yes
D'OH!!!
Damn it!
I should have seen that....
Thanks to everyone for all the suggestions.
Naturally, the damn code does EXACTLY what I told it to do, and exits the loop after checking the COM2 buffer!
Whoopsie!
I've spent too much time on code today.
CaptainBoing
Posted: 06:44am 14 Oct 2022
  Grogster said
DO
 If LOC(#2) THEN Y=1
 EXIT DO   <<<<<<<<< this always executes - not subject to the "IF"
Edit: memo to self... must read further into the post before replying - I just added my voice to the crowd
Edited 2022-10-14 16:47 by CaptainBoing
Posted: 12:25pm 14 Oct 2022
I'm guilty of doing THAT also, so I'm in good company!
Tinine
Posted: 10:52am 15 Oct 2022
@Grogster
But it's always nice to find that Mite hardware/firmware is not to blame.
Not a big deal to us but my client is still amazed that the only times that his E-100s get powered down is during Xmas and Summer breaks.
Not true for his megabuck Siemens/Windows laser machines.
Craig
Posted: 09:34am 16 Oct 2022
That's really nice to hear - that a wee E100 board with MMBASIC can basically out-perform the super expensive alternatives.
