Forum Index : Microcontroller and PC projects : Poor mans RTS
Page 2 of 2 | |||||
Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5012 |
Hi ryanm Could you post that link, it didnt come up in the forum post. I've been pricing RTK kits and looking for more options. Thanks Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
ryanm Senior Member Joined: 25/09/2015 Location: AustraliaPosts: 191 |
Ha! That does look like a link, but it's actually the name of the product Here 3 & Here+ RTK Base (M8P) Combo. https://store.rfdesign.com.au/here-3-here-rtk-base-m8p-combo/ DISCLAIMER I've never actually used one of those GPS units, it's on my wishlist to replace the $20 chinese one I've got on my little plane at the moment, but I still crash to often to put that sort of money on it. You'll want to do a bit of reasearch and make sure you're getting suitable and compatible gear before buying. A lot of the autopilots on the market are super expensive because they're made for expensive drones so they have redundant co-proccessors and sensors. If you go on Aliexpress and look for Pixhawk there are a lot cheaper ones that should (I think) be plug and play with that GPS. Another trap for new players that got me is some of the cheaper autopilot hardware is based off an older proccessor and has a ceiling on the firmware version it can run. Although given you're using it for a mower you probably don't need LIDAR assisted landing for example so an older version might not be an issue. |
Looks like I'm a bit out of date. Been a few years since I've looked into this. There's a lot of really good info on this site about setting up a rover style autopilot. https://ardupilot.org/rover/docs/common-autopilots.html |
After a few failed tests with the GPS modules, and a lot of research, I bought a ArduSimple RTK2B-F9P development module for about $400. I found out there was a RTK CORS service about 15km away, meaning I only need one module, I can use the CORS service as the base station. The CORS service is free, you just need to set up a free membership. The ArduSimple module arrived today. I plugged in a good GPS antenna ( the crap you pick up at clearing sales ), and used the program u-center to chat to the module via USB. Set up the CORS log in information, selected the local base station, and I got a RTK solution in about 30 seconds. That narrowed my position down to about 20cm. A few seconds later I got a lock on the carrier wave, which improved accuracy to less than 2cm. Pretty happy with that. Next its a lot more research and testing. I'm hoping to use a ESP32 as the rovers flight computer, and I have a Pi on the network which I'll use to connect to the CORS and only send the correction data via wifi to the rover's ESP32. BIG learning curve. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Page 2 of 2 |
