Forum Index : Microcontroller and PC projects : CMM2: Manual Error - Nunchuk function
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1693 |
Sometime after CMM2 MMBasic V5.06.00 the Nunchuk function description in the manual changed from: NUNCHUK(funct [, channel]) to: NUNCHUK(channel, funct) This appears to be wrong. As the manual says, the channel is optional and if omitted it will default to channel 3 which is the one used for the front connector on the original CMM2. The CMM2 does not accept the second version of the command. Bill Keep safe. Live long and prosper. |
Found more problems in the CMM2 manual. The CALL function is missing from the bookmarks although the description is there. Between the MEMORY and MID$ command bookmarks there are a couple of misplaced bookmarks which take you to the middle of a description. Bill Keep safe. Live long and prosper. |
Additional CMM2 manual issues: - the description of the CLASSIC() function says "T returns the ID code of the controller - should be hex &H4200101" ... that's incorrect it is hex &HA4200101. - MEMORY COPY and MEMORY SET are undocumented. Best wishes, Tom Edited 2022-11-18 20:25 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
