Local Time 00:40 16 May 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bubble Universe Demo
Goksteroo
Posted: 01:27am 15 Nov 2022
I found this little bit of basic code on Discord (Bubbles Demo and converted it to MMBasic. The result on my PC with MMB4W is spectacular. The code should run in any version of MM Basic's hardware - just need to change the mode it is to run in.
mode 11 'change to suit your monitor/hardware and MMB version
cls rgb(black)
n=255
r=(2*pi)/235
x=0
'y=0
v=0
t=0
sz=200
s=0
scrw=mm.hres
scrh=mm.vres
sw=scrw/sz
sh=scrh/sz
offset=scrh/4.5
do
page write 1
   cls
   for i=50 to n
     for j=50 to n
      u=sin(i+v)+sin(r*i+x)
      v=cos(i+v)+cos(r*i+x)
      x=u+t
      pixel scrw/2+u*offset,scrh/2+v*offset,rgb(i,j,100)
   next j
   next i
   t=t+.025
page copy 1 to 0,B
loop
uTube Video (washed out colours!)
OA47
Posted: 02:25am 15 Nov 2022
Like to check out the video but it is reporting it is private.
OA47
scruss
Posted: 02:51am 15 Nov 2022
Here's a video that is public for the BBC BASIC version to give you the idea: Bubble Universe
Goksteroo
Posted: 05:22am 15 Nov 2022
OOps... public video now
Pluto
Posted: 06:18am 15 Nov 2022
Thanks Goksteroo! Nice.
By commenting out (removing) following lines in your program:
-mode 11 'change to suit your monitor/hardware and MMB version
-page write 1
and
-page copy 1 to 0,B
it works on PicoMite (cheaper black module with WS2812 LED on board). Not tested with the "standard" green RP2040 modules.
> option list
PicoMite MMBasic Version 5.07.05RC8
OPTION FLASH SIZE 4194304
OPTION CPUSPEED (KHz) 378000
OPTION DISPLAY 50, 91
OPTION LCDPANEL ST7789_320, LANDSCAPE,GP17,GP20,GP21
Fred
Amnesie
Posted: 09:35am 15 Nov 2022
Tested it on the PICO, impressive!
Posted: 10:13am 15 Nov 2022
Very pretty .
Posted: 01:37pm 15 Nov 2022
Amazing !
So few lines of code, such a beautiful result. This has similar magic as "mandelbrot" and "life". Too bad the pico cannot produce color in 640x480.
This would be what the researchers at CERN observe,,,
Edited 2022-11-15 23:38 by Volhout
Goksteroo
Posted: 05:57am 16 Nov 2022
Add this little bit of code to the above between the lines in bold:
t=t+.025
select case k
 case 128
   inc scrh,-4
 case 129
   inc scrh,4
 case 130
   inc scrw,-4
 case 131
   inc scrw,4
 case 65,97
   inc offset,4
 case 90,122
   inc offset,-4
end select
page copy 1 to 0,B
... to add zoom with [A] and [Z] and move display with the arrow keys.
note: no error checking!!
Posted: 08:31am 16 Nov 2022
  Goksteroo said  Add this little bit of code to the above between the lines in bold:
t=t+.025
select case k
end select
page copy 1 to 0,B
Looks like k is never set. INKEY or some such?
Goksteroo
Posted: 09:35am 16 Nov 2022
Yeh.... I'm blaming a bad copy and paste.... k=keydown(1) goes immediately before the above code.
As agent 86 would say..."Missed it by that much."
stanleyella
Posted: 01:32pm 20 Nov 2022
works on picomite lcd
https://www.youtube.com/watch?v=9hnGAgYMIv0
Bleep
Posted: 10:18am 21 Nov 2022
Hi,
I've optimised this code for a LCD display, it now runs at approx 2Hz on a Pico running at 378MHz. I've reduced the number of plotted pixels, each pixel is drawn, then at the next iteration un_drawn, rather than doing a complete screen clear, I've also made them larger, to be more visible on a small screen, it's still managing to display about 1700 point per screen update.
Bubble video
Unfortunately it does make the code more unreadable. :-(
' Bubble Universe
Dim Float u,y,a,b,p,q,s,g,v=0, z=0, t=0, x=0
Dim Integer i,j,tt,c(41),d(41),e(41),f(41),l(41),m(41)
Const w=MM.HRes/2, h=MM.VRes/2, o=h/2, n=255
Const k=RGB(black), r=(2*Pi)/235
CLS RGB(black):Backlight 95
Math Add m(),3,m():t=Rnd*10':tt=t+3
g=t:Inc t,0.025
For i=50 To n Step 5
b=0
For j=50 To n Step 5
 a=r*i:p=i+z:q=a+y
 u=Sin(p)+Sin(q):z=Cos(p)+Cos(q)
 y=u+g:f(b)=w+u*o:l(b)=h+z*o
 p=i+v:q=a+x
 u=Sin(p)+Sin(q):v=Cos(p)+Cos(q)
 x=u+t:c(b)=w+u*o:d(b)=h+v*o
 e(b)=RGB(i,j,130):Inc b,1
Next
Box f(),l(),m(),m(),0,,k
Box c(),d(),m(),m(),0,,e()
Next i
Loop ' Until t>tt
Edited 2022-11-21 20:29 by Bleep
Posted: 12:56pm 21 Nov 2022
Hi Bleep,
Why are you calculating the f() and l() coordinates ? Could you copy them from c() and d() ? Using MATH ADD c(),0,f()
Bleep
Posted: 02:34pm 21 Nov 2022
Hi Volhout,
You could, but you would then only get 41 pixels at any one time. Currently it calculates 41x41 (i&j) in the for loops, which then progressively update 41 pixels at a time. I did look at saving all the points in an array, but the array used to much memory, because all variables use 64bits only, I also looked at saving 2 or 4 smaller integers in each array element by masking & shifting, but even then the array was too big, though that was before I reduced the number of pixels displayed, so may now be possible, but may not gain a huge amount, because of the slowness of the serial data transfer to the display.
Regards Kevin.
stanleyella
Posted: 04:00pm 21 Nov 2022
I changed CLS RGB(black)'Backlight 95 and it runs continuously but the original looked nicer imho.
I commented the second cls in the do loop and version 1 runs continuously.
Edited 2022-11-22 02:31 by stanleyella
Bleep
Posted: 04:40pm 21 Nov 2022
Hi Volhout,
Here you go, it is very fractionally faster, but still basically 2Hz update, however the two arrays use up 28kB of memory, in theory the update should be smoother as it now updates a pixel at a time.
' Bubble Universe
Dim Float u,a,p,q,t,v=0, x=0
Dim Integer b,i,j,c(1764),d(1764)
Const r=(2*Pi)/235, o=h/2
Backlight 95:CLS RGB(black)
t=Rnd*10
Inc t,0.025:b=0
For i=50 To 255 Step 5
For j=50 To 255 Step 5
 Box c(b),d(b),3,3,0,,0
 a=r*i:p=i+v:q=a+x
 Box c(b),d(b),3,3,0,,RGB(i,j,130):Inc b,1
Next
Next i
Posted: 05:11pm 21 Nov 2022
Doesn't this now assume that the "pixel" you are zeroing doesn't sit where a new pixel has been previously placed?
Here is my version 375mSec per update  @ 378MHz
' Bubble Universe
Dim Integer b,i,j,c(1764),d(1764),e(1764),f(1764),cc(1764),dd(1764)
Math set 3,e()
t=Rnd*10
Timer =0
b=0
   f(b)=RGB(i,j,130)
   Inc b
 Next j
Next i
 Print Timer
 Timer =0
 Inc t,0.025:b=0
   a=r*i
     p=i+v:q=a+x
     x=u+t:cc(b)=u*o+w:dd(b)=v*o+h
     Inc b
   Next
 Next
 Box c(),d(),e(),e(),0,,0
 Box cc(),dd(),e(),e(),0,,f()
 Math scale  cc(),1,c()
 Math scale dd(),1,d()
Edited 2022-11-22 04:04 by matherp
stanleyella
Posted: 06:19pm 21 Nov 2022
ili version
cls rgb(black)
n=255:r=(2*pi)/235:x=0:v=0:t=0:sz=200:s=0:sw=scrw/sz:sh=scrh/sz:offset=scrh/4.5
scrw=320 'mm.hres
scrh=240 'mm.vres
do
  for i=50 to n
    for j=50 to n
     x=u+t
    next j
  next i
  t=t+.025
loop
Bleep
Posted: 06:26pm 21 Nov 2022
Smarty Pants ;-)
Yes there will be a small number that get overwritten, but hopefully this is minimal, I certainly don't notice it.
However I definitely missed the fact that 'a' was being calculated in the wrong place and the fact that the colours could be pre-calculated. :-(
The reason I was doing it incrementally was to stop the fact that the whole pattern disappears and is then re-drawn, each iteration, I wanted it to look more fluid.
I've modified mine, to include the moved 'a' calculation and pre-calculated the colours, so it's improved to 480mS, still not as good as yours, but over a 50mS improvement on my previous. Thanks :-) Any other tips?
Regards, Kevin.
Edited 2022-11-22 04:30 by Bleep
