Local Time 19:03 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM-Basic Sprite Editor
Martin H.
Posted: 03:06pm 01 Dec 2022
To make the work a little easier I wrote a small sprite editor.
Sprites can be loaded in the own program by Using the SPRITE LOAD Command
It is controlled via the keyboard:
Cursor to select the Pixel
0 to f  set the Pixelcolor
F1      Load Sprite
F2      Save Sprite
n       New Sprite
q w o k move the Sprite
s       save to Clipboard
p       past from Clipboard
l       Rotate Left
R       Rotate Right
H       Flip horizontal
V       Flip Vertical
Rotation might fail if the Sprite is not squared
Tested on PicomiteVGA and MMB4W
so it should also run on ColorMaximite
Here the Code with some example Sprites:
SprEd.zip
Have Fun
 Mart!n
Edited 2022-12-02 01:11 by Martin H.
'no comment
Posted: 03:18pm 01 Dec 2022
Very nice. Thank you.
Posted: 03:55pm 01 Dec 2022
+1 from me too.
Can we hope for Lemmings on the PicoMite ?
Martin H.
Posted: 04:22pm 01 Dec 2022
  thwill said  +1 from me too.
sure, if we get DMA Design,and/or Psygnosis to program in mm-Basic
 Mart!n
'no comment
Amnesie
Posted: 08:57pm 01 Dec 2022
Really really cool! Can't wait to try it tomorrow! :)
-Daniel
Posted: 10:34am 02 Dec 2022
Nice Martin !!!
This will definitely help in designing new games...
I already see use for it for the new programming challenge.....
Martin H.
Posted: 10:39am 02 Dec 2022
  Amnesie said  Really really cool! Can't wait to try it tomorrow! :)
-Daniel
Hi Daniel,
have Fun crating some Icons / Sprites.
you will see, there is not a single GOTO in the Sourcecode
reference to your Video
V 1.001 will also have LCD Support(ILI9341) for PicoMite (non VGA)..
a view little optical Changes and, (if i can remove my thinking block) the ability to rotate non Squared Sprites.
cu
 Mart!n
'no comment
Martin H.
Posted: 10:49am 02 Dec 2022
  Volhout said  Nice Martin !!!
I was missing such a small tool, and since I haven't found it, I just programmed it myself.
btw.: isn't it a part of the challenge-rules, that you have to use one single File?
But ok, it should be no problem for you to store them in Data Statements
with a little practice you can get something like this in 15 minutes
44,1,32
0000000000000000000000000000000CCCCCC0000000
00000000000000000000000000000CCCCCCCCC000000
0000000000000000000000000000CCCCCCCEEE000000
000000000000000000000000C444CCCCCEEEEEE00000
0000000000000000000004444CCCCCCCEEEE77E00000
000000000000000000044CCCCCCCCEECCEEE7CECC000
0000000000000000004CCCCCCCCCEEEECCEEEEEEEE00
000000000000000004CCCC44CCCCEEEECCCEEEEEEEE0
00000000000000004CCCCC4CCCCCCCECCCCCEEEEEEE0
00000000000000004CCCCC4CCCCCCCEECCCEEEEEEEEE
0000000000000004CCCCCC4CCCCCCCCEECEEEECCCCCE
0000000000000004CCCCCC4CCCCCCCCCEEEEECEEEEE0
0000000000000004CCCCCC4CCCCCCCCCCEEECEEEEE00
0000000000000044CCCCCC44CCCCCCCCCEEEEEEEE000
000000000000004CCCCCCCC4CCCCCCCCCCEEEE000000
000000000000044CCCCCCCC44CCCCCCCCCC000000000
0000000000004CCCCCCCCCCC44CCCCCCCCCC00000000
000000000004CCCCCCCCCCCCC44CCCCCCCCC00000000
0000000000CCCCCCCCCCCCCCCC44CCCCCCCCC0000000
000000000CCCCCCCCCCCCCCCCCEECCCCCCCCC0000000
00000000CCCCCCCCCCCCCCCCCCEEECCCCCCCCC000000
00000000CCCCCCCCCCCCCCCC444E4ECCCCCCCCC00000
00000000CCCCCCCCCCCCCC444444EE0CCCCCCCC00000
00000044CCCCCCCCCCCC444444EEECC0CCCCCCCC0000
00ECC44CCCCCCCCCCC4444444ECCCCCC0CCCCCCCEEE0
04ECCCCCCCCCCCCCC4444444CCCCCCCC00CCCCCEEEE0
04EECCCCCCCCCCCCC44444CCCCCCCCCCC00CCCCCEE00
04EECCCCCCCCCCCC00000000CCCCCCCCC00CCCCCEE00
04ECCCCCCCCCCCC000000000CCCCCCCC0000CEEEEEE0
00ECECCC000000000000000CCEECCECCE4E00EEE4EEE
00EEECEEE00000000000000CEEEEEEEECE4E00EEE4EE
000EEE4E4E0000000000000EEEEEEEEEEE4E0000EEE0
Mart!n
Edited 2022-12-02 22:04 by Martin H.
'no comment
Posted: 01:20pm 02 Dec 2022
  Martin H. said  btw.: isn't it a part of the challenge-rules, that you have to use one single File?
We allowed multiple files up to 5K for the 2022 Challenge.
Martin H.
Posted: 01:40pm 02 Dec 2022
Hi Tom
Ok, then I misunderstood.
But to keep the 5k limit, it would be better to compress the Sprites
As I mentiond in the "on The Road again" Post
best
Mart!n
'no comment
Posted: 02:02pm 02 Dec 2022
  Martin H. said  But to keep the 5k limit, it would be better to compress the Sprites
Yes, so there's your first feature request, add sprite compression to your utility ;-)
Martin H.
Posted: 02:39pm 02 Dec 2022
ok, this comes on the enhancement List for V 1.001
Merging my compress Function wouldn't be a big deal,
*but I have to write a full user Dialog.
*we will lose the SPRITE LOAD compatiblity with those Files
 As we can only use them in combination  with the Expand Function.
also seen in the On the Road again Post
I would'nt have the Time for this, this weekend as I'll went 61 tomorrow
 Mart!n
Edited 2022-12-03 00:43 by Martin H.
'no comment
Posted: 02:42pm 02 Dec 2022
  Martin H. said  I would'nt have the Time for this, this weekend as I'll be 61 tomorrow
Many happy returns for tomorrow then!
Posted: 04:37pm 02 Dec 2022
Congratulations Martin.!
Martin H.
Posted: 10:59am 03 Dec 2022
  Volhout said  Congratulations Martin.!
Thank you ..
btw here is the dissolution of the picture puzzle above:
'no comment
Martin H.
Posted: 02:48pm 07 Dec 2022
V1.01:
enhancement
* Added LCD ILI9341 Support
* Size now Up to 64x64 Pixel
Bugfix:
* Centered Sprite in Preview window
* fixed Rotaton for non squared Sprites
sprEdV101.zip
'no comment
Hans
Posted: 09:50pm 07 Dec 2022
  Martin H. said  To make the work a little easier I wrote a small sprite editor.
Mart!n
Thank you sooooooooo much for this fabulous program Martin!
Hans ...
Martin H.
Posted: 04:32pm 12 Dec 2022
So here it is:
New in V1.02:
Enhancement
*Save and load Sprites to/from compressed Sprite Format
*selectable BG Color for New Sprite
Bugfix
* removed an unnessecary "ELSE" Statement
SprEd.V1.02.zip
Mart!n
Edited 2022-12-13 22:50 by Martin H.
'no comment
Posted: 12:55pm 12 Jun 2023
Hi Martin,
This is a GREAT tool !!! I used it for 1 week now, and really appreciate it. This really works well. The only negative point I found so far is that <ctrl-C> is needed to Quit (I did not find any other way so far).
Is there any documentation on the "compressed format" ?
So I can implement the compressed sprite reader in MMbasic in my program.
hhtg1968
Posted: 01:50pm 12 Jun 2023
hello. my picomitevga will be ready in a few days. i tried to start your programm on my cmm2. the colours myrtle, cobalt etc. are no keywords for mmbasic on cmm2. where can i get the numbers for the colour names?
