Local Time 18:15 21 Jun 2026 Privacy Policy
Forum Index : Other Stuff : Which water pump for reticulation?
greg199
Posted: 10:49am 12 Dec 2022
I'm looking to reticulate lawns via a large water tank and an electric water pump in order to replace an existing (failing) submersible bore pump. The low pressure (failing) bore pump will fill the tank and then the new above ground pump will supply high pressure water to the retic system a few times each week.
It's a guess but I think this new pump needs to deliver about 100 lpm at 200 kPa so that the Hunter brand pop up geared sprinklers work correctly. Up to 7 of these sprinklers are connected to one station/pipe. The existing retic controller would coordinate each of the stations/pipes and switch the new pump on/off.
Any suggestions for a brand and model for an electric pump, in Perth region WA, that can supply 100 lpm at 200kPa?
Posted: 08:12pm 12 Dec 2022
100L/min is higher than usual for domestic use.
I would suggest something from the Davey HM Series as one option. The HM160-15T has the specs you require.
I am sure that there are other Davey ranges and other brands that have a solution.
It is easier to visit a water pump shop and save time.
