Forum Index : Microcontroller and PC projects : Whoops... Oh dear
| IanRogers Senior Member Joined: 09/12/2022 Location: United KingdomPosts: 152 |
Hello all.. Running this lil pico with putty as my terminal editor. As you now I'm just playing at the mo. I have been working on a rather large program AND!! I assumed each time I run the program is safe inside.. I have no way at the moment to save a copy on the PC (I'm sure there is, but still learning ) I created my first interrupt, it was for a numberbox and generated a #ref and hit F2, towit a message appeared stating a 0 isn't valid and ( 1 to 9 ) was. Realizing I have miss spelled the ref went back to edit..... All gone and memory wiped.. Ho Hum... I am going to use a different term program as putty will not allow you to save any text on the screen. Ian I'd give my left arm to be ambidextrous |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 8895 |
I wonder what else was in your program? That error message is one that I would associate with working with flash slots. Pressing F2 should run the program (which lives in flash slot 0). If you think this might be a bug, what version number of the PicoMite firmware is it? If you'd like to try a different terminal program then Tera Term is excellent with the PicoMite if you are running Windows. It supports XMODEM so you can save files from the PicoMite to the PC. Alternatively, you could try MMedit which is very popular. Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 5920 |
Hi IanRogers, - I have seen this once before. Never could duplicate. Typically you can store your program in a flash slot inside the picomite. That (in my case) survived the "crash". FLASH SAVE 1 (or 2 or ....5) - Using MMEdit is definitely preferable. Since you store your programs on the PC. Highly recommended. Volhout PicomiteVGA PETSCII ROBOTS |
LOL... it was just a simple screen that loaded a jpg from SD with a button to enter config mode..(working fine) I then placed 6 controls to access different menu options, one option to quit the program.. ( working) The last option was to change a variable used in the main screen some thing like this sub entry ' remove gui controls GUI DELETE menu1,menu2,menu3,menu4,menu5 CLS 0 GUI INTERRUPT myBut, myBut ' same interrupt text 20,30, "SELECT","LM", white, black GUI NUMBERBOX nbox1 20,50, 100, 37, white, black GUI NUMBERBOX ACTIVATE nbox1 touched = 0 ' as interrupt key down had fired do if touched = 1 then ( save ctrlval and redraw previous screen ) exit sub endif loop end sub I set the interrupt before this sub BUT the control was actually named nbox and not nbox1 I also set up the GUI INTERRUPT just befor I'd give my left arm to be ambidextrous |
I trust that you allocated some memory for GUI stuff? Always safer to save progs, especially when messing with interrupts I've found. They usually behave but you never know. :) Mick Zilog Inside! nascom.info for Nascom & Gemini Preliminary MMBasic docs & my PCB designs |
Yup I'll not need more that 10 so I set it to 10 controls... It won't let you use them if it's undefined. print mm.ver gives 5.0704 I'm downloading MMedit as we speak.. I'd give my left arm to be ambidextrous |
MMedit downloaded and running. Lets hear no more of my madness... Ian Bit Later on..... Back to where I was ( ish) lets try the interrupt again.. BTW.. I like MMedit.. I like Textpad and I'd like to run that loader program direct from textpad... I couldn't be a simple as passing the whole text to MMCC.. Guess I'll try. Edited 2022-12-23 04:04 by IanRogers I'd give my left arm to be ambidextrous |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6536 |
Yes, it could. Jim VK7JH MMedit |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3284 |
As you have an SD card attached... Save "Ver 1.x.BAS" before RUN. |
Cheers Jim. I have used Textpad as an IDE for years.. It has the ability to setup a compiler to grab the text and compile... Similar as the MMedit. However!! As MMedit is working sooo well, I'll just use that...( I don't want to introduce errors, not until I'm conversant with this topic..) Ian @phil99 Actually, as Peter has a Flash file system, it would make sense to use the new version and stick it on flash... But using MMedit is tons easier than using a term program.. Cut and paste is a boon when duplicating lines of code.. I'd give my left arm to be ambidextrous |
Okay.. Back to where I was.. The issue is GUI NUMBERBOX ACTIVATE ttext I used the Const ttext = 7 If I use an interrupt sub to increase a variable touched all works fine Ie... sub mybut touched = touched + 1 end sub I can pick up that when touched = 2 the enter key was pressed. But that's not what I want.. I want the number keypad to activate The error on screen said my syntax is incorrect! It is typed as above.. I'd give my left arm to be ambidextrous |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11475 |
If we are talking about the PicoMite then GUI Numberbox activate has been removed as it had intractable issues (also formatbox activate and textbox activate). The manual for 5.07.06 won't include it |
Okay.. I'll set a dummy interrupt and just use it as is. Thanks for the heads up Peter. Ian I'd give my left arm to be ambidextrous |
Is there any way to falsify and generate an interrupt! All I need is the keypad to pop up normally..Without interaction. Ian I'd give my left arm to be ambidextrous |
| plover Guru Joined: 18/04/2013 Location: AustraliaPosts: 306 |
I am just curious, is this topic still going? |
Clearly not I have decided to make my own keypad and text control... Maybe in the future? I'll not push as Peter has his hands full with the flash storage at the mo. I'd give my left arm to be ambidextrous |
