Local Time 07:31 22 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bubble universe
Posted: 04:51am 06 Jan 2023
Needs the speed of MMB for Windows
I believe the original code was written by Paul Dunn - developer of SpecBas.
It has done the rounds of many languages including QB64 and PureBasic
'bubble universe MMB4W
 OPTION EXPLICIT
 OPTION DEFAULT FLOAT
 DIM r,t,u,v,x,n, TAU
 DIM INTEGER i, j, hw, hh, col
 MODE 1
 n = RND()*100+300
 TAU = 6.283185307179586
 r = TAU / (RND()*100+235)
 hw = MM.HRES / 2
 hh = MM.VRES / 2
'Cls(RGB(0, 0, 0))
 PAGE WRITE 1
 DO
   CLS(RGB(0, 0, 0))
   FOR i = 0 TO n
     FOR j = 0 TO n
       u = SIN(i + v) + SIN(r * i + x)
       v = COS(i + v) + COS(r * i + x)
       x = u + t
       Col = RGB(i AND &hFF, j AND &hFF, 99)
       PIXEL hw + u * hw * 0.4, hh + v * hh * 0.4, Col
     NEXT
   NEXT
   t = t + 0.01
   PAGE COPY 1 TO 0
 LOOP UNTIL INKEY$ <>""
Edited 2023-01-06 14:53 by TassyJim
Posted: 06:53am 06 Jan 2023
Very beautifull.
There was a thread about this before, it also runs on the picomite. Although not near as beautifull as on mmb4w
Posted: 10:55am 06 Jan 2023
  Quote  There was a thread about this before, it also runs on the picomite
I must have missed it the first time.
It runs very nicely with a compiled Basic.
Amazing what can be done with a few lines of code.
Goksteroo
Posted: 01:42pm 14 Jan 2024
Original Post re Bubble Universe for MMBasic.
ebbandflow
Posted: 01:47pm 14 Jan 2024
How did I not see this post!?! lol go figure. Love the images this code produces!
stanleyella
Posted: 03:36pm 14 Jan 2024
1 fps on pico even vga but pretty.
' Bubble Universe credit to who posted it
mode 2
option autorun on
Dim Float u,a,p,q,t,v=0, x=0
Dim Integer g,b,i,j,c(41),d(41),e(41),n(41)
Dim Integer f(41,41),l(41,41),m(41,41)
Const w=MM.HRes/2, h=MM.VRes/2
Const r=(2*Pi)/235, o=h/2
FRAMEBUFFER CREATE F
FRAMEBUFFER WRITE f
CLS RGB(black)':Backlight 95
t=Rnd*10:math set 2,e()'Math set 3,e()
For g=0 to 41
for b=0 to 41
  m(g,b)=rgb(g*6,b*6,128*(g+b>30)*(g+b<60))
Next:Next
Inc t,0.025:g=0:Timer =0
For i=50 To 255 Step 5
b=0
a=r*i
Math Slice f(),g,,c()
Math Slice l(),g,,d()
Box c(),d(),e(),e(),0,,0
For j=50 To 255 Step 5
p=i+v:q=a+x
u=Sin(p)+Sin(q):v=Cos(p)+Cos(q)
x=u+t:c(b)=w+u*o:d(b)=h+v*o
Inc b
Next
Math Slice m(),g,,n()
Box c(),d(),e(),e(),0,,n()
Math Insert f(),g,,c()
Math Insert l(),g,,d()
Inc g
Next i
FRAMEBUFFER COPY f,N
'Print Timer
ps what's mmb4w?
Edited 2024-01-15 01:51 by stanleyella
javavi
Posted: 04:55pm 14 Jan 2024
' Bubble Universe
MODE 2
FRAMEBUFFER LAYER
FRAMEBUFFER WRITE L
RX=MM.HRes:RY=MM.VRes:CX=RX\2:CY=RY\2
r=(2*Pi)/25:x=0:v=0:t=0:SC=RY/4
Dim integer C(15)
For i=0 To 15: Read C(i): Next i
Data &H000000,&H0000FF,&H004000,&H0040FF
Data &H008000,&H0080FF,&H00FF00,&H00FFFF
Data &HFF0000,&HFF00FF,&HFF4000,&HFF40FF
Data &HFF8000,&HFF80FF,&HFFFF00,&HFFFFFF
Do :CLS
co=1
 For i=50 To 80 Step 2
   For j=50 To 70 Step 1
     u=Sin(i+v)+Sin(r*i+x)
     v=Cos(i+v)+Cos(r*i+x)
     x=u+t
     Pixel CX+u*SC,CY+v*SC,C(co)
   Next j
   Inc co: If co>15 Then co=1
 Next i
Inc t,.025
FRAMEBUFFER COPY L,N,B
stanleyella
Posted: 07:24pm 14 Jan 2024
javavi got error- framebuffer layer
error: cpuspeed=252000 for layers
> option cpuspeed 378000
Error : CpuSpeed 126000, 252000 only
> option list
PicoMiteVGA MMBasic Version 5.08.00b5
OPTION SYSTEM I2C GP4,GP5
OPTION AUTORUN  ON
OPTION KEYBOARD US
OPTION DISPLAY 20, 40
OPTION AUDIO GP0,GP1', ON PWM CHANNEL 0
is this a duff rpi?
stanleyella
Posted: 07:35pm 14 Jan 2024
javavi- Changed cpuspeed and works brill.. very fast. Others should try it.
nice one, stan
Posted: 07:58pm 14 Jan 2024
Top CPUSPEED on a VGA is 252, not 378.
stanleyella
Posted: 10:51pm 14 Jan 2024
  Mixtel90 said  Top CPUSPEED on a VGA is 252, not 378.
doh. probably says that somewhere.new to vga and never set cpuspeed on this.
does this mean non vga can be faster than vga?
Posted: 11:03pm 14 Jan 2024
It depends on the program. If it's processor intensive then yes.
If it is display intensive the VGA display is faster than a serial LCD.
Posted: 08:16am 15 Jan 2024
Yes, 378 is faster - and it's noticeably faster usually - but the increase is usually less than might be expected from the numbers. If there is any IO whatsoever (including memory access) many CPU(s) will have to slow down to the maximum speed of the IO channel(s).
Bleep
Posted: 12:46pm 15 Jan 2024
This is my current fastest Bubble Universe, using VGA, but it also works fine on a LCD if you remove the "Mode 2"; it will update just over 2000 points at a rate of 267mS (at 378Mhz using an older version of VGA Picomite) otherwise it'll be about 400ms per update @ 252Mhz.
Alternatively if you want more speed, increase the step size in the two main 'For' loops ("For i=" and or "For j=")
For example changing the i loop to 'step 7' looks quite nice and updates at 5hz or 3.5Hz.
Regards, Kevin.
' Bubble Universe
MODE 2
Dim Float u(51),w(51),a,p,q,t,v=0,x=0
Dim Integer g,b,i,j,c(51),d(51),e(51),n(51),nn,dd
Dim Integer f(13,41),l(13,41),m(26,41),y,z,cc,tt
Const r=(2*Pi)/235,k=255,s=50
CLS RGB(black)
t=Rnd*10:Math set 1,e()
't=1
nn=Peek(varaddr n())
dd=Peek(varaddr d())
cc=Peek(varaddr c())
For g=0 To 41
For b=0 To 51
  n(b)=RGB(g*6,b*5,128*(g+b>30)*(g+b<60))
  If g<26 And b<13 Then n(b)=RGB(0,128,0)
Next
Memory pack nn, Peek(varaddr m(0,g)),52,32
Next g
Inc t,0.01:g=0':Print Timer:Timer =0
For i=50To 255Step 5
b=0:a=r*i
z=Peek(varaddr f(0,g)):Memory unpack z,cc,52,16
y=Peek(varaddr l(0,g)):Memory unpack y,dd,52,16
Box c(),d(),e(),e(),0,,0'Pixel c(),d(),0
For j=50To 255Step 4:u(b)=Sin(i+v)+Sin(x):v=Cos(i+v)+Cos(x):x=u(b)+a+t:w(b)=v:Inc b:Next
Math Scale u(),70,c():Math Scale w(),60,d()
Math add c(),160,c():Math Add d(),120,d()
Memory unpack Peek(varaddr m(0,g)),nn,52,32
Box c(),d(),e(),e(),0,,n()'Pixel c(),d(),n()
Memory pack cc,z,52,16:Memory pack dd,y,52,16
Inc g
Next
Edited 2024-01-15 22:58 by Bleep
Posted: 01:00pm 15 Jan 2024
Wauw Kevin,
You are the king. I have never seen this run on a picomite so fast...
V50800RC3 at 252MHz.
Edited 2024-01-15 23:01 by Volhout
Bleep
Posted: 01:19pm 15 Jan 2024
Most of the time is in the Sin and Cos functions, if there was a way of optimising those it could possibly be a lot faster. ;-)
If you want to run it on an LCD it is worth increasing the size of the drawn box, so change the line 'Math set 1,e()' to use 2 or 3, it makes the points bigger and easier to see on the smaller screen.
Regards, Kevin.
Martin H.
Posted: 01:44pm 15 Jan 2024
  Bleep said  :-)
The values that uses SIN and COS in this Program are integers.
So you can precalculate a "lookup Table" with all results of 0 to 359
dim Sin1(360),Cos1(360)
for f=0 to 356:Sin1(f)=sin(f):Cos1(f)=Cos(f):next
then replace the Sin and Cos in the Program with Sin1 and Cos1.
if it is out of range, a MOD360 would help
I have no Idea if this is faster ;-)
'no comment
javavi
Posted: 06:40pm 15 Jan 2024
Bubble Universe for PicoMiteVGA @252MHz
color optimization added a little speed
MODE 2
FRAMEBUFFER LAYER
FRAMEBUFFER WRITE L
r=(2*Pi)/25:x=0:v=0:t=0:SC=RY\4
Dim integer CV(15)
For i=0 To 15: Read CV(i): Next i
Do :CLS :c=1
   For j=50 To 100 Step 1
     x=u+t
   Next j
   Inc c: If c>15 Then c=1
   Colour CV(c)
 Next i
Inc t,.025
Edited 2024-01-16 04:44 by javavi
Posted: 02:53am 16 Jan 2024
For those wanting to run Bubble Universe at 378MHz on a PicoMiteVGA load this .OPT file. Remove or change any Options that don't suit your setup with:
OPTION xxxxx DELETE
Then load your options.
PicoMiteVGA_5.08.00RC3_378MHz.zip
> option list
PicoMiteVGA MMBasic Version 5.08.00RC3
OPTION SYSTEM I2C GP6,GP7
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 378000
OPTION SDCARD GP13, GP10, GP11, GP12
OPTION RTC AUTO ENABLE
OPTION COUNT GP2,GP3,GP4,GP5
Refer to Peter's reasons for limiting the speed to 252MHz.
The use of certain new features may cause instability at 378MHz. Mainly, I think, things that make use of the second core.
The above programs are working fine for me.
