Local Time 02:24 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Picomite(VGA) V5.07.07 betas - bug fixes + focus on PIO
     Page 1 of 16
Posted: 01:25pm 13 Jan 2023
Picomite(VGA) V5.07.07b1
Bug fix to ON ERROR SKIP (thanks Tom)
New functions
MM.INFO(EXISTS FILE fname$) ' see CMM2 manual for details
MM.INFO(EXISTS DIR dname$) ' see CMM2 manual for details
PIN(FLEVEL pio [,sm, DIR]) ' dir can be RX or TX. If specified gives the level of the specific fifo
PIO (SHIFTCTRL push_threshold [,pull_threshold] [,autopush] [,autopull] [,in_shiftdir] [,out_shiftdir] [,FJOIN_RX] [,FJOIN_TX]) 'additional optional parameters to create 8-word RX or TX FIFOs
PIO CLEAR now clears all the FIFOs for the pio specified
PIO INIT and PIO START clear the specific FIFOs for the pio and sm specified
New Command
NB: RX and TX are from the Basic code perspective
PIO INTERRUPT pio, sm [,RXinterrupt] [,TXinterrupt]
Use the value 0 for RXinterrupt or TXinterrupt to disable an interrupt
Omit values not needed
e.g
PIO INTERRUPT 1,0,,myTXinterrupt
PIO INTERRUPT 1,0,,0
PIO INTERRUPT 1,0,myRXinterrupt
PIO INTERRUPT 1,0,0
PIO INTERRUPT 1,0,myRXinterrupt,myTXinterrupt
PIO INTERRUPT 1,0,0,0
The RX interrupt triggers whenever a word has been "pushed" by the PIO code into the specified FIFO. The data MUST be read in the interrupt to clear it. The interrupt will re-trigger if a second word arrives and the interrupt only processes one.
The TX interrupt triggers whenever the specified FIFO has been FULL and the PIO code has now "pulled" it
PIO interrupts have priority have keyboard interrupts but before anything else. As with all interrupts interrupt conditions are processed one at a time.
NB: I am not convinced about the utility of the TX interrupt. Would it be better to have an interrupt on say half full  when it was previously more than half. This would allow the Basic code to keep the FIFO topped up and know how many writes were allowed NB: the enhanced PIO(FLEVEL ...) function makes it easy for the Basic code to know the FIFO status before writing
Posted: 02:03pm 13 Jan 2023
Will try this weekend !! Looks very promising. I see a 3 phase sine wave generator on the horizon....
  matherp said  Picomite(VGA) V5.07.07b1
I Guess this is a typo....
PIO(FLEVEL pio [,sm, DIR])
Posted: 02:06pm 13 Jan 2023
  Quote  I Guess this is a typo....
No: it says you can specify just the pio, or all of the pio, statemachine and direction
  matherp said  Picomite(VGA) V5.07.07b1 ...
Thanks for your confidence Peter, I hope it proves to be justified.
  matherp said  New functions
Great, I'd been hoping for those for a while.
Could I push my luck and ask for:
       MM.INFO(EXISTS file_or_dir_name$)
Which both MMBasic for Windows and MMB4L already have, but not the CMM2 ... but perhaps that could have too ?
Edited 2023-01-14 00:07 by thwill
Posted: 02:09pm 13 Jan 2023
  Quote  Could I push my luck and ask for:
Isn't that effectively there with MM.INFO(filesize fname$) which returns -2 if it is a directory
Edited 2023-01-14 00:11 by matherp
Posted: 02:18pm 13 Jan 2023
Isn't that there with MM.INFO(exists file fname$) which returns -2 if it is a directory
Are you talking historically, in which case I think it is MM.INFO(FILESIZE fname$) which has that behaviour, or did, you may have changed it to report an error the last time I got on this hobby horse .
Or are you talking about what you've just done, in which case I'll have to take a look, though I'd still appreciate consistency between all the MMBasic platforms.
Maybe I should just let this slide until I've got my tests running on the PicoMite and then I will be able to quibble from a position based more on facts than supposition.
Thanks for the new additions,
Posted: 02:21pm 13 Jan 2023
OK, you edited, and no, on some platforms that now throws an error.
This is the passing test code from when I checked about a week ago (but not with PicoMite):
Sub test_filesize_given_directory()
 If Mm.Device$ = "MMB4L" Then
   assert_int_equals(-2, Mm.Info(FileSize Mm.Info$(Directory)))
   assert_int_equals(-2, Mm.Info(FileSize Mm.Info$(Path)))
   assert_int_equals(-2, Mm.Info(FileSize "/"))
   assert_int_equals(-2, Mm.Info(FileSize "\"))
   assert_int_equals(-2, Mm.Info(FileSize "."))
   assert_int_equals(-2, Mm.Info(FileSize ".."))
   assert_int_equals(-2, Mm.Info(FileSize "A:/"))
   assert_int_equals(-2, Mm.Info(FileSize "A:\"))
   assert_int_equals(-2, Mm.Info(FileSize "C:/"))
   assert_int_equals(-2, Mm.Info(FileSize "C:\"))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$(TMP$, "/", "\")))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$(TMP$, "\", "/")))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$("A:" + TMP$, "/", "\")))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$("A:" + TMP$, "\", "/")))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$("C:" + TMP$, "/", "\")))
   assert_int_equals(-2, Mm.Info(FileSize str.replace$("C:" + TMP$, "\", "/")))
 Else
   assert_filesize_fails(Mm.Info$(Directory))
   assert_filesize_fails(Mm.Info$(Path))
   assert_filesize_fails("/")
   assert_filesize_fails("\")
   assert_int_equals(Choice(Mm.Device$ = "MMBasic for Windows", -2, -1), Mm.Info(FileSize "."))
   assert_int_equals(Choice(Mm.Device$ = "MMBasic for Windows", -2, -1), Mm.Info(FileSize ".."))
   assert_filesize_fails("A:/")
   assert_filesize_fails("A:\")
   assert_filesize_fails("C:/")
   assert_filesize_fails("C:\")
 EndIf
End Sub
Sub assert_filesize_fails(f$)
 On Error Skip 1
 Local size% = Mm.Info(FileSize f$)
 assert_raw_error("Invalid file specification")
 On Error Clear
End Sub
Posted: 02:29pm 13 Jan 2023
The Picomite behaves the same as the CMM2. Sets the error message if a directory but does not throw an error
MMB4W is slightly different so should probably change but will still return -2 for a directory. It only errors if the filename ends in / or \
Edited 2023-01-14 00:33 by matherp
Posted: 02:34pm 13 Jan 2023
  matherp said  The Picomite behaves the same as the CMM2. Sets the error message if a directory but does not throw an error
MMB4W is slightly different so should probably change but will still return -2 for a directory. It only errors id the filespace ends in / or \
OK, I had not noticed this. Can I officially go on the record as saying that setting MM.ERRMSG$ outside of throwing an ERROR completely breaks "The Principle of Least Surprise" ?
If I can be so bold, "least suprise" suggests that:
- If MM.ERRMSG$ <> "" then an error has been thrown ... and the CMM2 should not be setting it to "Success" which it sometimes does.
- If MM.ERRNO <> 0 then an error has been thrown ... I think this is always the case.
- At all times either (MM.ERRMSG$ <> "" AND MM.ERRNO <> 0) OR (MM.ERRMSG$ = "" AND MM.ERRNO = 0)
Edited 2023-01-14 00:39 by thwill
Posted: 02:43pm 13 Jan 2023
As with all this stuff I think it is only you who ever looks at errormsg or errno so completely irrelevant for most users
Posted: 02:46pm 13 Jan 2023
  matherp said  As with all this stuff I think it is only you who ever looks at errormsg or errno so completely irrelevant for most users
That does appear to be the state of affairs.
Pluto
Posted: 02:48pm 13 Jan 2023
Tried to download Picomite(VGA) V5.07.07b1. When extracting: "Archive corrupt!"
Posted: 02:51pm 13 Jan 2023
  Pluto said  Tried to download Picomite(VGA) V5.07.07b1. When extracting: "Archive corrupt!"
Same for me.
Posted: 02:56pm 13 Jan 2023
In that it shouldn't be
PIN(...
but instead
PIO(...
Does look like a typo.
Posted: 03:38pm 13 Jan 2023
It's amazing how you can't see your own errors but everyone else can
PIO(FLEVEL pio [,sm, DIR]) ' dir can be RX or TX. If specified gives the level of the specific fifo
  Quote  Tried to download Picomite(VGA) V5.07.07b1. When extracting: "Archive corrupt!"
Please try again
Edited 2023-01-14 01:44 by matherp
Posted: 04:23pm 13 Jan 2023
Forgot to mention also in b1
The PWM command is modified as follows:
PWM channel, frequency, [dutyA] [,dutyB] [,phase] [,deferredstart]
Phase is a new parameter that causes the waveforms to be centred such that a wave form with a shorter duty cycle starts and ends equal times from a longer one. Use 1 to enable this mode and 0 (or omit) to run as normal
The new parameter "deferredstart" when set to 1 prepares the PWM channels as before but does not start the output running. This is to avoid any undesirable startup artefacts
There is a new sub command
PWM SYNC [channel0offset] [,channel1offset] .......[channel7offset]
This initiates the PWM on channels where a deferred start was defined or just syncs exisitng running channels. However, the power comes in the ability to offset the channels one to another (defined as a percentage of the time period as per the duty cycle - can be a float)
You can use an offset of -1 to omit a channel from the synch
Edited 2023-01-14 02:44 by matherp
Posted: 06:33pm 13 Jan 2023
Download now OK, thanks.
Bleep
Posted: 08:46pm 13 Jan 2023
  matherp said  PIO (SHIFTCTRL push_threshold [,pull_threshold] [,autopush] [,autopull] [,in_shiftdir] [,out_shiftdir] [,FJOIN_RX] [,FJOIN_TX]) 'additional optional parameters to create 8-word RX or TX FIFOs
Hi Peter,
I've just tried using the FJOIN_TX, this is for my Basic code sending out data to the FiFo for transmission by the PIO, however I've found I actually have to use:-
f0=Pio(shiftctrl 0,0,0,1,0,0,1,0) 'Set Auto Pull at 32bits (0) & Extend Tx  FiFo
Which would seem to me to be using FJOIN_RX, so either I'm not understanding the TX RX direction, or I'm doing something wrong. If I actually set FJOIN_TX my code locks up, presumably because there is no FiFo for it to write to.
Regards, Kevin.
Posted: 11:31pm 13 Jan 2023
37us per word on fifo is pushing the limit of what mmbasic on fifo can do.
Interrupt gives you freedom for your main code
Posted: 11:49pm 13 Jan 2023
Edit
Ignore, this new Pico has faulty GP0. Does not drive low, just goes high Z. Adding a pull-down resistor enables normal DOUT to work, adequate on PWM. Has 16MB flash yet cost less than regular Pico, now I know why!
On an old Pico it works well.
Playing with the new PWM commands.
PWM channel 0 phase shift seems wrong. This three phase sequence works perfectly if using PWM channels 1,2,3 but not with PWM channels 0,1,2
> LIST
' Three phase motor drive - not quite right
SetPin gp0,pwm  'CH 0a
SetPin gp1,pwm  'CH 0b
SetPin gp2,pwm  'CH 1a
SetPin gp3,pwm  'CH 1b
SetPin gp4,pwm  'CH 2a
SetPin gp5,pwm  'CH 2b
PWM 0, 50, 33.33, -66.66, 1, 1
PWM 1, 50, 33.33, -66.66, 1, 1
PWM 2, 50, 33.33, -66.66, 1, 1
PWM sync 0, 100/3, 200/3
> LIST
' Three phase motor drive - perfect
SetPin gp6,pwm  'CH 3a
SetPin gp7,pwm  'CH 3b
PWM 3, 50, 33.33, -66.66, 1, 1
PWM sync 0, 0, 100/3, 200/3
Edited 2023-01-14 15:02 by phil99
     Page 1 of 16
