Forum Index : Microcontroller and PC projects : Picomite(VGA) V5.07.07 betas - bug fixes + focus on PIO
Page 7 of 16 | |||||
Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 3521 |
Not really... [300] PIO DMA RX 1,0,&hFFFFFFFF,packed%(),ReadyInt,32,samples% 'start DMA ring bf Error : -1 is invalid (valid is 0 to 2147483647) PicomiteVGA PETSCII ROBOTS |
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 8578 |
V5.07.07b11 - specially for Volhout https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip New capabilities for PEEK function peek(bp n%) ' returns the byte at address n% and increments n% to point to the next byte peek(sp n%) ' returns the short at address n% and increments n% to point to the next short peek(wp n%) ' returns the word at address n% and increments n% to point to the next word These make it very efficient for basic code to step through a packed array e.g. dim s$="123456" a%=peek(varaddr s$)+1 'point to the start of the string data for i%=1 to 6 print peek(bp a%) next i% PIO DMA TX and PIO DMA RX now allow up to &HFFFFFFFF transfers Edited 2023-02-01 20:49 by matherp |
JanVolk Regular Member Joined: 28/01/2023 Location: NetherlandsPosts: 96 |
Gentlemen and Matherp I am new to this forum and have encountered something strange after version V5.07.07b5. I am using self-compiled code partly from this forum for an i2c scanner which worked well until V5.07.07b5 and after V5.07.07b7 it stops working and stops at I2C Read i,0,1,temp. Error : Cannot find Temp. And system crashes and ** Fatal Error ** What am I doing wrong or has something changed in the firmware? ' I2C scanner detect aangesloten modules Print " ****************** I2C SCANNER ********************" Print " Input/Output PCF8575 Adres: Dec: 32 Hex:0x20" Print " Input/Output MCP23017 Adres: Dec: 32 Hex:0x20" Print " LCD 20x4 5V0 HD44780 Adres: Dec: 32 Hex:0x20" Print " Licht Lux BH1750 Adres: Dec: 35 Hex:0x23" Print " Temp/%RV DHT20 Adres: Dec: 56 Hex:0x38" Print " LCD 16x2 5V0 KS0066 Adres: Dec: 56 Hex:0x38" Print " Oled 128x64 SSD1306 Adres: Dec: 60 Hex:0x3C" Print " ADC/DAC 8Bit PCF8591 Adres: Dec: 72 Hex:0x48" Print " ADC 4x 16Bit ADS1115 Adres: Dec: 72 Hex:0x48" Print " EEPROM 32K AT24C32 Adres: Dec: 87 Hex:0x57" Print " Klok RTC 3V3 DS3231 Adres: Dec:104 Hex:0x68" Print " Klok RTC 5V0 DS1307 Adres: Dec:104 Hex:0x68" Print " Temp/%RV/Druk BMP280 Adres: Dec:118 Hex:0x76" Print " Opm: Indien module 5V dan pullups extern aan 3V3!" Print " Of een level shifter voor SDA en SCL gebruiken." Print " Dec Hex Hex" For i = 0 To 127 ' Te testen adressen decimaal. I2C Read i, 0, 1, temp ' I2C READ addr, option, rcvlen, rcvbuf. If MM.I2C = 0 Then ' MM.I2C 0=Adres gevonden 1=Geen Adres. Print " Gevonden adres "; Str$(i,3)," &h"; Hex$(i,2); " 0x"; Hex$(i,2) EndIf Next i Print " HEX 0 1 2 3 4 5 6 7 8 9 A B C D E F" For y = 0 To 7 Print " "; Hex$(y, 1); "0: "; For x = 0 To 15 addr = y * 16 + x ' Bereken adres. I2C Write addr, 0, 1, &H00 ' Schrijf nul naar dat adres If MM.I2C = 0 Then ' Controleer op fouten. If addr = 0 Then Print "-- "; ' Addr is 00 dan "-- " If addr > 0 Then Print Hex$(addr, 2);" "; ' Een gevonden! 2=cijfers Else Print "-- "; ' Niets hier.. EndIf Next x Next y End > option list PicoMite MMBasic Version 5.07.07b5 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION SYSTEM I2C GP4,GP5 OPTION COLOURCODE ON OPTION DISPLAY 42, 90 OPTION LCDPANEL SSD1306I2C, LANDSCAPE OPTION SDCARD GP22 OPTION RTC AUTO ENABLE Sorry for Dutch. I translate most of the time because my English is not very good and "Translate" is my best friend and the actual code is English. For example, I translated the PicoMite Basic manual into Dutch for myself with many examples and additions. (>360 pages so far) and also the PIO course by Volhout (172 pages) Jan Volk |
TassyJim Guru Joined: 07/08/2011 Location: AustraliaPosts: 5901 |
Welcome to the forum. Your English is much better than my Dutch! You need to define the temp variable before using it. dim temp After that, your code runs on the latest beta firmware. Jim VK7JH MMedit MMBasic Help |
Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 329 |
This happens after running Volhout's Logic Analyzer. >files Error : Not enough memory > option list The same as Volhout also pointed out in an earlier post. Was this something that you also wanted to address in the latest update? I just updated the firmware to the latest version (Option list says b12; download says b11). https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip PicoMiteVGA MMBasic Version 5.07.07b12 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION KEYBOARD IT OPTION CPUSPEED (KHz) 378000 OPTION DEFAULT MODE 2 OPTION DISPLAY 60, 106 OPTION DEFAULT FONT 7, 1 > /Pluto |
Jim, I tried with Dim temp and the first time it worked, but by re-running several times I get an error and reset the program and even ** panic ** Edit no longer works. Can only be fixed by re-flashing program, but problem in firmware is still present. Previously temp was probably automatically declared? JanVolk |
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 3656 |
What happens if you go back to an old MMBasic? Does it then work? John |
John, See my first post. With PicoMite MMBasic version V5.07.07b5 everything worked fine. Then the problems started. Raspberry Pi Pico is my first microcontroller with MMBasic and have been using it for a year now. JanVolk |
Will fix in next beta |
Matherp, Thank you in advance. |
PicoMite(VGA)V5.07.07b14 https://geoffg.net/Downloads/picomite/PicoMite_Beta.zip Fixes bug introduced in I2C Fixes instability introduced in B10 Significant change in the way memory is organised - please report any unusual issues |
BishopXXL Newbie Joined: 13/01/2019 Location: GermanyPosts: 17 |
Significant change in the way memory is organised - please report any unusual issues Hi Peter, I think I've found a difference between the B14 and the B10. I haven't tried all GP IOs yet, but in the V14 the current is too small to drive an LED (GP09). In B10 everything goes wonderfully. Is the current normally set to 4mA? I use such a LowCurrent LED (1-2mA)! Or is the error again between Monitor and chair. Cheers Thomas P.S. It is : PicoMiteV5.07.07b14 - 06.02.2023 10:34 Edited 2023-02-07 00:57 by BishopXXL |
Thomas, there has been no change in this area so don't know why there would be a difference. Even if the drive strength was only set to 4mA that should be plenty for your LED. I'll test with my LEDs later today. |
ville56 Regular Member Joined: 08/06/2022 Location: AustriaPosts: 68 |
Interestingly, b14 throws an error on SetPin gp1, gp0, com1 'define PCR-comm pins Open "com1:9600,256,ser_int2,1" As pcr_chan [305] Open "com1:9600,256,ser_int2,1" As pcr_chan Error : Pins not set for COM1 Has something changed in respect to setpin statement? It works that way in b8 but i have no versions in between to check any further. Regards, Gerald 73 de OE1HGA, Gerald |
Hi Peter, Tested picomite VGA 50707b14. I had several unexplained problems with the latest version. Sometimes I could not edit after stopping the program with ctrl C, sometimes a "out of memory" erro message. Anyway, with b14 this all stopped. Thanks for fixing this. I have not seenany of these artefacts since. I blaimed myself for being so anoying brining up several issues that where actually my own fault that I did not mention these (felt ashame). But now we are at it, there is one thing you could give you opinion on. When I run the logic analyzer code at 126MHz CPU the PS2 keyboard is misreading keys sometimes (i.e. you press a cursor key, and the key value is that of nummber key "4". I know the CPU is busy running MMBasic, graphics, some PIO, DMA etc... So it is possible the system is too busy. But the USB (serial terminal) does not make these false key readings. When I run CPU at 252MHz this does not happen. I am currently trying to make the LA work with 126MHz since I hear that some people have problems running new pico's at 200MHz or higher. Is the keyboard issue caused by the PS2 interrupt priority changed ? Regards, Volhout PicomiteVGA PETSCII ROBOTS |
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 1781 |
Attempted to replicate but no error. PicoMiteVGA MMBasic Version 5.07.07b14 > pcr_chan=1 > SetPin gp1, gp0, com1 > Open "com1:9600,256" As pcr_chan > |
Hi Peter, I tested I2C with V5.07.07b14 with the i2c_scanner.bas and it works fine now and also works with the i2c_lcd_lib.bas (This is a lib for 16x2 and 20x4 lcd screens). I have tested I2C with V5.07.07a3 with the i2c_scanner.bas and now works fine and also works with the i2c_lcd_lib.bas. Jan |
@Phil99: that is really strange ... retested the setpin issue. Cleared flash with clear_flash.uf2, reloaded b14 and did not set any options just to be sure, but got the same error. Is there anything else I can "reset/clear/erase" which may cause the issue? Regards, Gerald 73 de OE1HGA, Gerald |
Flashed another Pico with non-VGA b14 and the error appears. update firmware PicoMite MMBasic Version 5.07.07b14 Copyright 2011-2023 Geoff Graham Copyright 2016-2023 Peter Mather > pcr_chan = 1 > SetPin gp1, gp0, com1 > Open "com1:9600,256" As pcr_chan Error : Pins not set for COM1 > > option list PicoMite MMBasic Version 5.07.07b14 OPTION FLASH SIZE 16777216 OPTION CPUSPEED (KHz) 378000 OPTION DISPLAY 60, 132 > Edit But this works... > SetPin gp1,off > SetPin gp0,off > SetPin gp0, gp1, com1 'swap pins > Open "com1:9600,256" As pcr_chan > Edited 2023-02-07 09:59 by phil99 |
Please check if this fixes the issue and then I'll issue a new release - I think the problem was a non-initialised area of memory following the changes I made to the memory handling. Would only happen before a program was run. PicoMite.zip |
Page 7 of 16 |
