Forum Index : Microcontroller and PC projects : MMBasic core: bug in cmd_gosub()
Posted: 04:35pm 21 Jan 2023
Peter, Geoff,
You may not care, but:
Currently:
void cmd_gosub(void) {
   if(gosubindex >= MAXGOSUB) error("Too many nested GOSUB");
   errorstack[gosubindex] = CurrentLinePtr;
   gosubstack[gosubindex++] = nextstmt;
   LocalIndex++;
   if(isnamestart(*cmdline))
       nextstmt = findlabel(cmdline);
   else
       nextstmt = findline(getinteger(cmdline), true);
   IgnorePIN = false;
   CurrentLinePtr = nextstmt;
IMO it should be:
   const char *return_to = nextstmt;
   else
   IgnorePIN = false;
   errorstack[gosubindex = CurrentLinePtr;
   gosubstack[gosubindex++ = return_to;
   LocalIndex++;
This way if findlabel/findline fail (which they can) the stacks and the LocalIndex don't get clobbered.
Observation: I didn't expect LocalIndex and LOCAL variables to work with GOSUB ... I don't mind, I just thought LOCAL was part of the SUB/FUNCTION structured programming rather than the older GOSUB style. Note that in general there is scope for clobbering here because no setjmp is installed to recover if you are skipping errors and call GOSUB. I'll leave it as an exercise for the reader (or not), as GOSUB isn't really something I would ever use with MMBasic.
Posted: 04:55pm 21 Jan 2023
Can you provide an example of how/where this matters and your change improves things?
From the manual FYI
  Quote  Obsolete Commands and Functions
Detailed Listing
These commands and functions are mostly included to assist in converting programs written for Microsoft
BASIC. For new programs the corresponding modern commands in MMBasic should be used.
Note that these commands may be removed in the future to recover memory for other features.
GOSUB target Initiates a subroutine call to the target, which can be a line number or a label.
The subroutine must end with RETURN.
New programs should use defined subroutines (i.e. SUB…END SUB).
Edited 2023-01-22 02:55 by matherp
Posted: 06:24pm 21 Jan 2023
  matherp said  Can you provide an example of how/where this matters and your change improves things?
Try this (demonstrated with MMB4W):
> list
Option Explicit On
foo()
End
Sub foo()
 Local x% = 1
 On Error Skip 1
 Gosub no_such_label
 x% = 2
 Print "Caught: " Mm.ErrMsg$
End Sub
> run
Caught: Error in line 9: Cannot find label
Error in line 10: X is not declared
Note that
 a) X is declared.
 b) if X hadn't been declared then its error should be the only one displayed before the program aborts.
Also try commenting out line 10 "x% = 2" to see:
> run
MMB4L which contains my suggested fix produces this output for both cases:
> run
The problem is because as-written cmd_gosub() updates the state as if the GOSUB had occurred before checking whether the GOSUB is even possible.
It's not really very significant for the majority of users (possibly ALL-1 users) and I wouldn't have encountered it myself but for the fact that I am trying to write comprehensive tests for labels before switching MMB4L to use hash lookup for them.
However I tell you about this stuff because I see it, and in this case I even have a simple fix for it, it's up to you and Geoff whether you act on it or not.
  thwill said  Note that in general there is scope for clobbering here because no setjmp is installed to recover if you are skipping errors and call GOSUB.
I'm no longer so sure about that, I think I was letting myself get carried away with speculation, I should restrict myself to errors I have actually experienced .
  matherp said  From the manual FYI ...
Yes, and makes sense, though if you removed them then you would lose compatibility with a host of legacy non-MMBasic programs.
Edited 2023-01-22 04:37 by thwill
twofingers
Posted: 06:41pm 21 Jan 2023
@Tom, in my opinion it's easy to replace with Sub/End Sub. For me "Gosub" is a dinosaur.
Best regards
Michael
Posted: 07:01pm 21 Jan 2023
  twofingers said  @Tom, in my opinion it's easy to replace with Sub/End Sub. For me "Gosub" is a dinosaur.
Absolutely, it's a dinosaur, and it would make life simpler if it was removed from MMBasic ... however in those mythical sunlit uplands where a young person is pried from their phone/tablet/VR headset/vape and persuaded there might be some merit in typing in some creaky old BASIC program it might happen to contain a GOSUB statement as it is pretty much a BASIC staple [pun intended].
twofingers
Posted: 07:15pm 21 Jan 2023
I understand both sides, but I wouldn't be sad if it were removed.
Justplayin
Posted: 07:58pm 21 Jan 2023
I wish people would stop trying to turn BASIC into C. I believe GOSUB is a critical part of BASIC.  BASIC is supposed to simple to use, which GOSUBs are and SUBs are not so much.  Yes I do use SUBs but I prefer GOSUB when I'm doing a quick bit of code.
Posted: 08:41pm 21 Jan 2023
Oh, I dunno - they are much of a muchness if you treat them similarly. It's just that you have the option of making SUBs more powerful - you don't need to.
'main routine
myloop:
 do something here
 GOSUB asubroutine
 'do something else
GOTO myloop
asubroutine:
 'do something here
RETURN
--- or ---
'main routine
DO
 'do something here
 dothisroutine
 'do something else
LOOP
SUB dothisroutine
 'do something here
END SUB
Nimue
Posted: 08:48pm 21 Jan 2023
  Justplayin said  I wish people would stop trying to turn BASIC into C. I believe GOSUB is a critical part of BASIC.  BASIC is supposed to simple to use, which GOSUBs are and SUBs are not so much.  Yes I do use SUBs but I prefer GOSUB when I'm doing a quick bit of code.
The debate between (precise) historical preservation of (programming) languages vs reinterpreting old languages in light of more modern paradigms is an interesting one.
Line numbers (either present or "hidden") are a good example.  When I learned to program in BASIC, I was never really aware of what the point of line numbers was, just that I needed to use them.   This persisted into my Spectrum / BBC Basic day - then QBasic rocked my world.
BUT.... whilst Gosubbing to a "label" seemed so powerful, students ability to Return to a different part of the code than where it was called from pretty much reinvented spaghetti coding of the "GOTO" days. From what I remember back in the day students could not understand their own code 48hrs after it was written.  So when we embraced SUB and CALL that tidied that up.
Depending on the students (and teachers) I often use "LOGO" as a starting point for teaching "coding".  Interesting LOGO has many calls/functions that are often missing / removed depending on the interpretation. For example, OPENREAD filename -- yes, LOGO has file i/o but this is often left out - presumably in an attempt to make LOGO even more beginner friendly.
My point (clumsily made) is that teaching "structured programming" concepts (if/then/else, iteration, subroutines/functions) is what matters, not how to actually implement in a specific language.
For the record - I've got no residual love for GOSUB.
Nimue
twofingers
Posted: 11:33pm 21 Jan 2023
FYI:
For me surprising: Gosub/Return is tree times faster than a Sub/End Sub.
I don't mean to say that it has practical relevance in every case or very often!
'Test for execution time Gosub vs Sub()
Option explicit
Dim float  t, t_L, t_P
Dim integer i, loops = 100000
Timer =0
For i = 1 To loops
Next
t= Timer
Timer =0
For i = 1 To loops
GoSub L_test
Next
t_L= Timer-t
Timer =0
For i = 1 To loops
P_test
Next
t_P= Timer-t
Print
Print "Time for "loops " loops"
Print "empty loop   ||   Gosub   ||   Sub()"
Print t, t_L, t_P
End
Sub P_test' test procedure
End Sub 'end test procedure
L_test: ' label test gosub
Return ' return test gosub
End '******************************
Result:
Time for  100000 loops
203.196         509.118         1437.068
Edited 2023-01-22 09:45 by twofingers
Posted: 11:41pm 21 Jan 2023
  twofingers said  FYI:
For me surprising: Gosub/Return is t[h]ree times faster than a Sub/End Sub ...
Nice observation.
SUB/END SUB does a great deal more book-keeping than GOSUB/RETURN because, for example, it needs to deal with the possibility of the SUB having parameters. Possibly it could be optimised ... possibly not.
Of course you are testing an extreme case, if you were actually doing anything in the "subroutine" the relative difference due to the overhead would be much less.
Edited 2023-01-22 09:42 by thwill
twofingers
Posted: 11:50pm 21 Jan 2023
  thwill said  Of course you are testing an extreme case, if you were actually doing anything in the "subroutine" the relative difference due to the overhead would be much less.
I see that exactly the same way!
Kind regards
Michael
Goksteroo
Posted: 06:53am 22 Jan 2023
Why the t_L= Timer-t and t_P= Timer-t since you have zeroed the timer before each test? Oops!
Add some work to each routine and you get more 'real world' results.
Option explicit
Dim integer i,pp, loops = 100000
Timer =0
For i = 1 To loops
pp=100
do
inc pp,-1
loop until pp<1
Next
t= Timer
Timer =0
For i = 1 To loops
GoSub L_test
Next
t_L= Timer
Timer =0
For i = 1 To loops
P_test
Next
t_P= Timer
Print
Print t, t_L, t_P
End
pp=100
do
inc pp,-1
loop until pp<1
pp=100
do
inc pp,-1
loop until pp<1
gives these results....
1528.6083      1524.8994    1549.1483
DaveJacko
Posted: 11:00pm 23 Jan 2023
Loosely related to this thread..
has anyone else noticed that..
you accidentally code 2 subs with the same name,
MMBasic helps you, and throws an error - fab!
if you are thick like me, and type two line labels with the same name,
MMBasic just goes to the first one, no error!
this set my OBD2 ELM 327 reader project back quite a bit.
(is this called a hashing table thing issue?)
Thanks you lot !
Try swapping 2 and 3 over
