Forum Index : Microcontroller and PC projects : MMB4L - current status
Hi Tom, Can you please advise the current status of MMB4L? ... and what/where is the latest version? I am running Mint 20.1 and am very interested in your project. Also if I can assist in any way with testing, am very happy to do. Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Hi Doug, MMB4L is currently version 2022.01.00 alpha 4, but to all intents and purposes I'm considering it to just be version 0.4, and I'll be calling the next release plain-old 0.5. Documentation: https://github.com/thwill1000/mmb4l Releases: https://github.com/thwill1000/mmb4l/releases - look at the "Assets" under each release for the downloads for x86, x86_64 and armv6l (Raspberry Pi's) It strives to have language compatibility with the core* language of MMBasic 5.07 though is currently missing a couple of the latest additions to the MATH and MEMORY commands that Peter put in the PicoMite f/w. * At this time it doesn't have GPIO support or high-res graphics. Development of version 0.5 is well advanced (https://github.com/thwill1000/mmb4l/tree/thwill-alpha5) but it's basically just bug-fixes, tweaks and improvements under the hood c.f. alpha 4. The one "headline item" (though it hardly deserves that accolade) is that it will do Tab completion of paths at the command prompt. I have confidence it will work on that platform, if it doesn't then please let me know. Thanks, but I think it's the nature of MMB4L that for the foreseeable future every release will be a test release so there isn't any great point in providing "early access", it would just add to my overhead. Best wishes, Tom Edited 2023-01-25 05:40 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
With the qualification that this now-deprecated (but not replaced and not likely to go away) I/O method works: Digital output to pins on a Pi Zero W with MMB4L One reason this is deprecated is that there is nothing in Linux to prevent a program from trying to do I/O on a pin which another program is already using. For hobby use cases, this issue can probably be ignored. (I don't remember whether there is any clean-up if a program has failed.) ~ Edited 2023-01-25 00:23 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Seems the wrong URL. Maybe this? John |
Yes, thanks. I thought I even previewed it. Specifically, here . PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
