Local Time 18:20 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteWeb alphas - It had to be done
     Page 1 of 5
Posted: 07:09pm 29 Jan 2023
It's cold and dull in the UK and I was bored....
If you have a pico_w try the attached
PicoMiteWeb.zip
The firmware is identical to the PicoMite except for the following:
Removed
GUI command, CTRLVAL command and CTRLVAL function
Changes
Available memory - still to be tuned - may increase or decrease
Added
OPTION WIFI SSID,PASSWORD
To disable wifi use: OPTION WIFI "",""
WEB command with currently one sub-command
WEB NTP 'connects to an NTP server ("pool.ntp.org") and updates the system time and date
TBD
All the other WEB subcommands
Edited 2023-01-30 05:10 by matherp
Posted: 07:33pm 29 Jan 2023
This is another of those "dogs" that you won't be bothering with, I see.  ;)
Posted: 08:26pm 29 Jan 2023
It's exhausting trying to keep up.
I guess this must make it 12 months since MMB4W ?
Posted: 09:12pm 29 Jan 2023
I knew I purchased a wifi module for a reason.
(too soon to ask but) Will the WEB NTP command get a timezone parameter?
> OPTION LIST
PicoMite MMBasic Version 5.07.07a0
OPTION WIFI someplace, not_telling
> web ntp
ntp address 88.198.226.248
got ntp response: 29/01/2023 21:12:54
> print time$
21:13:25
k2backhoe
Posted: 02:30am 30 Jan 2023
WOW!  Very impressive.  I can't wait to see where this goes and I will be looking for any more examples or documentation as it develops.  Thanks enormously.
Zonker
Posted: 02:52am 30 Jan 2023
So then would you be able to access the pico with say firefox and serve up a simple webpage showing data being collected from connected devices..??
Posted: 03:14am 30 Jan 2023
Hey, now, Peter, you can't tease us all with that, and then not say what you had to do and how long it took you to make it work!
I distinctly recall you stating several times that the W would NEVER be supported.
This is wonderful news, but I really would love to have more DETAILS as to HOW you made it work, and how much effort it took.
I seem to recall the idea of supporting the W module was out of the question due to the size of the network stack or something that MMBASIC would have to support to be able to talk to the WiFi on the W module, making it impossible - or very difficult at least, so that idea was OUT.
I never bought any W modules, but I might just have to order a couple to play with this as it moves forward in development.
matherp - making the impossible possible.
Posted: 03:16am 30 Jan 2023
  Zonker said  So then would you be able to access the pico with say firefox and serve up a simple webpage showing data being collected from connected devices..??
That would be my guess, yes, once Peter has finished the code.  But that might be a little way off, as I am guessing this is very much still in alpha stage.  But the alpha is often the hardest one.  Once you have the essential system working, later releases tend to be bug-fixes and improvements, so I think you will be able to do that once he has finished - but the man himself will be the one to answer that for sure.
Plasmamac
Posted: 03:35am 30 Jan 2023
Cool and wonderfully News. Thx matherp
Plasma
Posted: 10:14am 30 Jan 2023
V5.07.07a1
PicoMiteWeb.zip
WEB NTP [adjust]
The optional parameter 'adjust' is a float between -12.0 and +14.0 and allows you to offset the time given by the NTP server to suit your timezone
WEB SCAN
Scans for wifi access points in the vicinity
NB: forgot to mention in the first post GP23, GP24, GP25, GP29 are now completely inaccessible from MMBasic as they are used by the pico_w to communicate with the cyw43. The LED on the pico_w is actually driven by an IO port on the cyw43.
You can also try
WEB HTTP SERVER OPEN. This will create an HTTP server on the pico_w on port 80 (NB: not HTTPS). Doesn't do anything at the moment but you can connect to it from a browser and you will see the diagnostics. You will need to reset the pico_w to get out of it.
Edited 2023-01-30 20:15 by matherp
Posted: 10:47am 30 Jan 2023
Hooray!
Figuring out what to support/allow & the syntax may be a challenge.
How to best allow TCP/IP & UDP, if at all?  Would sending email be useful?  Or ping?  Etc.
Edited 2023-01-30 20:50 by JohnS
IanRogers
Posted: 12:22pm 30 Jan 2023
"GUI command, CTRLVAL command and CTRLVAL function"
This kinda bothered me.. I was trying to use this command on the pico_W  Clearly this was "one of those incompatibility" things you mentioned..
Ah well
pwillard
Posted: 12:25pm 30 Jan 2023
Never say never, I guess.   Thanks for giving it a shot.
k2backhoe
Posted: 01:54pm 30 Jan 2023
Please forgive my ignorance, but I have a capacity question.  With all of the desireable features that Peter Mather is creating it feels like a hacker's Cornucopia with too small a horn.  Is the restriction because of the 2 MB flash or the 264 KB RAM?  If it is the flash memory, then would replacing the W25Q16JV external flash with a W25Q128JV (16 MB flash) on the Pico allow for all of the features to be included simultaneously?
Plasmamac
Posted: 03:35pm 30 Jan 2023
multiple listed some ssid , sry
Edited 2023-01-31 01:39 by Plasmamac
Plasma
Posted: 03:45pm 30 Jan 2023
  k2backhoe said  ... Is the restriction because of the 2 MB flash or the 264 KB RAM? ...
I believe it's the RAM. The PicoMite would really be cooking if there were 512K to play with ... more than that it probably doesn't need - though some will no doubt disagree.
Edited 2023-01-31 01:46 by thwill
Posted: 06:51pm 30 Jan 2023
It's the amount of RAM and the way it's selected, I think. There are only certain combinations of RAM blocks that can be in current address space. Or something like that. Chapter 2.6.2 of the RP2040 Datasheet is nice and confusing in an enlightening sort of a way. :)
Posted: 10:57pm 30 Jan 2023
Anyone coded against LWIP? Seems massively overcomplicated compare to the simple socket interfaces I've implemented on the Raspberry Pi and MMB4W. Any help appreciated
Posted: 12:34am 31 Jan 2023
  matherp said  Anyone coded against LWIP? Seems massively overcomplicated compare to the simple socket interfaces I've implemented on the Raspberry Pi and MMB4W. Any help appreciated
I don't wish to be negative about it. It is aimed as it says at systems with tens of KB free RAM (etc). Sort of not-very-LWIP, depending on the size of system with which a potential user is comfortable.  It is LW if you're used to GB or many MB of RAM.
It looks to have lots and lots of features, most of which I believe most users would never want.
I wonder if there's a tinyIP...
George H
Posted: 02:44am 31 Jan 2023
... W ordered ;)
     Page 1 of 5
