Forum Index : Microcontroller and PC projects : Use of JSON for BoM (Aus.) Weather AND Forecast
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Hi, I'm getting back into MMBasic after a short break. I'm spurred on by Peter's work on the Pico-W and am about to make the leap from a Pico with an ESP8266, to the Pico-W. I had been using Openweather for weather but hadn't really succeeded with its forecasts (any help/clues would be welcome). Do any of you access the Australian Bureau of Meteorology (BoM) for JSON data for 'weather' and 'forecasts', if so how? and; is it any better than Openweather? Cheers, Andrew |
Somewhere on the BOM website I saw information about setting up a feed. That was many years ago but I reckon the feature is still available. Jim VK7JH MMedit |
Thanks Jim. I saw it too but couldn't make any sense of it. I'm hoping someone has done it already . . .? If not I'll find it again and try harder. The Pico-W will make it easier because my use of ESP8266 was a bit hit and miss. Andrew |
It looks like the BOM data is only retrieved by ftp When you do get it, the format is xml which is very similar to json but not quite the same. Here is a snipit of the Victorian observations. <observations> <station wmo-id="95936" bom-id="086338" tz="Australia/Melbourne" stn-name="MELBOURNE (OLYMPIC PARK)" stn-height="7.53" type="AWS" lat="-37.8255" lon="144.9816" forecast-district-id="VIC_PW007" description="Melbourne (Olympic Park)"> <period index="0" time-utc="2023-02-10T04:20:00+00:00" time-local="2023-02-10T15:20:00+11:00" wind-src="OMD"> <level index="0" type="surface"> <element units="Celsius" type="apparent_temp">22.3</element> <element units="Celsius" type="delta_t">5.1</element> <element units="km/h" type="gust_kmh">24</element> <element units="knots" type="wind_gust_spd">13</element> <element units="Celsius" type="air_temperature">24.1</element> <element units="Celsius" type="dew_point">15.6</element> <element units="hPa" type="pres">1004.0</element> <element units="hPa" type="msl_pres">1004.0</element> <element units="hPa" type="qnh_pres">1004.9</element> <element units="%" type="rel-humidity">59</element> <element units="km" type="vis_km">40</element> <element type="wind_dir">SSW</element> <element units="deg" type="wind_dir_deg">207</element> <element units="km/h" type="wind_spd_kmh">19</element> <element units="knots" type="wind_spd">10</element> <element start-time-local="2023-02-10T09:00:00+11:00" end-time-local="2023-02-10T15:22:00+11:00" duration="382" start-time-utc="2023-02-09T22:00:00+00:00" end-time-utc="2023-02-10T04:22:00+00:00" units="mm" type="rainfall">0.0</element> <element start-time-local="2023-02-09T09:00:00+11:00" end-time-local="2023-02-10T09:00:00+11:00" duration="1440" start-time-utc="2023-02-08T22:00:00+00:00" end-time-utc="2023-02-09T22:00:00+00:00" units="mm" type="rainfall_24hr">0.0</element> <element start-time-local="2023-02-10T06:00:00+11:00" end-time-local="2023-02-10T21:00:00+11:00" start-time-utc="2023-02-09T19:00:00+00:00" end-time-utc="2023-02-10T10:00:00+00:00" units="Celsius" type="maximum_air_temperature" instance="running" time-utc="2023-02-10T03:42:00+00:00" time-local="2023-02-10T14:42:00+11:00">25.0</element> <element start-time-local="2023-02-09T18:00:00+11:00" end-time-local="2023-02-10T09:00:00+11:00" start-time-utc="2023-02-09T07:00:00+00:00" end-time-utc="2023-02-09T22:00:00+00:00" units="Celsius" type="minimum_air_temperature" instance="running" time-utc="2023-02-09T17:21:00+00:00" time-local="2023-02-10T04:21:00+11:00">16.2</element> <element start-time-local="2023-02-10T00:00:00+11:00" end-time-local="2023-02-11T00:00:00+11:00" start-time-utc="2023-02-09T13:00:00+00:00" end-time-utc="2023-02-10T13:00:00+00:00" units="knots" type="maximum_gust_spd" instance="running" time-utc="2023-02-10T04:08:00+00:00" time-local="2023-02-10T15:08:00+11:00">14</element> <element start-time-local="2023-02-10T00:00:00+11:00" end-time-local="2023-02-11T00:00:00+11:00" start-time-utc="2023-02-09T13:00:00+00:00" end-time-utc="2023-02-10T13:00:00+00:00" units="km/h" type="maximum_gust_kmh" instance="running" time-utc="2023-02-10T04:08:00+00:00" time-local="2023-02-10T15:08:00+11:00">26</element> <element start-time-local="2023-02-10T00:00:00+11:00" end-time-local="2023-02-11T00:00:00+11:00" start-time-utc="2023-02-09T13:00:00+00:00" end-time-utc="2023-02-10T13:00:00+00:00" type="maximum_gust_dir" instance="running" time-utc="2023-02-10T04:08:00+00:00" time-local="2023-02-10T15:08:00+11:00">SSW</element> </level> </period> </station> The VIC file is 300k long so you will need a lot of elbow room. I will look further when time permits. VK7JH MMedit |
Jim, Don't put yourself out (too far) but any help is appreciated. How did you get the observations? I guess I could use INSTR to read the values for the key fields. The data is the same as on the BoM website for Victorian observations so I can check I'm getting the right fields and data. (I have seen reference to JSON on the site so I'll go looking.) (We've been in a hotel for 10 months and they are upgrading their network this WEEK! so WiFi keeps dropping out - it has never been any good. Cheers, Andrew |
Jim, I Googled "BoM JSON" and amongst many links found this. It look very useful. Andrew |
Your link does work but it is https. I am not sure if http would work. Jim VK7JH MMedit |
OK Jim how about this one? (This one is for Viewbank which is OK for me) Andrew |
